Car: 08 535i
Default Gurgling under dash. Only when stopped. Won't go away - 05-25-2017, 07:19 AM
Hello all,
Yesterday was my first day of driving since installing hotside intakes. Everything was fine, but after about 20 minutes a gurgle started in the dash when I came to a complete stop. The gurgle immediately goes away with any throttle action, even when stopped. I looked at my coolant temps and they were 210-221. I know this is air pockets in the system and it needs to be bled.
I have bled the system about 6 times per the Bently Manual and when the engine is cold it shows full everytime. This was not an issue before i drained the system to relocate the expansion tank.
How many times should I have to bleed the system?
Vogt.ryan's Avatar
Car: 2008 BMW 335i sport
Default 05-25-2017, 07:27 PM
Did you do the waterpump cycle?
2008 335i Sport Jb4, MHD BEF, Alpina flash, Uncatted *****, PE Mod, Injen Intake, v710's , Vogtland Springs
tho's Avatar
tho tho is offline
Car: 2011 335i Convertible
Default 05-26-2017, 01:12 PM
Where did you relocate the expansion tank to? Pics?
Car: 08 535i
Default 05-26-2017, 03:28 PM
Everytime I bled. After the like the ninth time it finally stopped. I also got a battery charger/maintainer.
Car: 08 535i
Default 05-26-2017, 03:30 PM
You can see it all here.
http://www.n54tech.com/forums/showthread.php?t=46427
