(#551)
335imofo's Avatar
335imofo 335imofo is offline
Car: 335i Coupe
Default 07-26-2019, 12:46 PM
Originally Posted by allanC
Here is what ford diagnosed and fixed as per my fault that stored in the ECU.
Same P400 issue here, dealer replaced tube. Removed JB and no more codes. Could the 3 of us have bad boards?
allanC allanC is offline
Default 07-26-2019, 02:30 PM
I just got my new board in the other day. Haven't had a chance to install it. Will install tonight and keep you gents posted.
Default 07-26-2019, 03:23 PM
Not likely but different problems can cause the same symptom.
If you'd like to separately test something out, clear all codes, and remove the JB4 mobile adapter from your system and see if the code returns without it attached.
Also P400 is not an actual code. If using iOS update to the BETA version of the app as they corrected a code reading bug that would give the wrong number out. Android was auto updated a few months ago I think so update the app if yours did not and check the code again.
335imofo's Avatar
Car: 335i Coupe
Default 07-26-2019, 06:47 PM
Interesting. Ok ill try this on Monday.
Thanks Terry
Default 07-27-2019, 07:36 PM
Hey Terry, put the new board in and after about 150-200kms the code came up again. Cleared code and came back again. Do you want me to try it without the Bluetooth adaptor connected? Can I just disconnect the power so it doesnít power up? Or remove completely? Let me know.
Default 07-27-2019, 08:23 PM
The other customer is testing that so sit tight for the moment, working on a firmware update.
tsgieoff tsgieoff is offline
Car: mercedes c400 and Golf R
Default 07-30-2019, 04:35 PM
Sorry to get off topic to what you guys are talking about but had a quick question. Will a 15-16 3.5L jb4 work on a 17+? I remember a bunch of the VW jb4s worked the same on different vehicles. Thanks!
Default 07-30-2019, 05:30 PM
No it's a different harness.. There are 3 harnesses for the EcoBoost. 2011-2014, 2015-2016, and 2017+.
Default 08-02-2019, 09:28 AM
Morning Terry, any update on this.
Default 08-02-2019, 11:13 AM
Sent update last week but not heard back yet. If you also want to help test just email me terry@burgertuning.com
Default 08-05-2019, 03:14 PM
Added ECO_7 to the first post. If anyone is getting a false alarm CEL let me know how it does!
Abyssf150 Abyssf150 is offline
Car: 2019 f150 2.7 Ecoboost
Default 08-05-2019, 03:23 PM
So far so good 350 miles on the new update and no CEL.
Default 08-05-2019, 08:48 PM
Have had the new ECO_7 firmware since Friday and done 700kms. No engine!!
Default 08-10-2019, 08:18 AM
Terry...I just received my jb4 yesterday. Wow, that shipping was fast! I'm planning on using my Bluetooth dongle from my mk7 jb4. Anything I need to do with that or the app before during up the jb4 on the Ford? Wasn't sure if I had to clear all my saved maps and stuff on the app.
Default 08-10-2019, 11:03 AM
Bluetooh has nothing to do with maps other than selecting said map. It's simply there to communicate with your phone. Just like a data cable.
Default 08-10-2019, 01:03 PM
Nope just install it to the new JB4 and you're good to go.
Dpas1973 Dpas1973 is offline
Car: 2019 raptor
Default 2019 raptor - 08-14-2019, 06:49 PM
Hello I just ordered my jb4 for my 19 raptor. I did not purchase the wireless setup since Iím not tech savvy. Do I just plug and play this or do I have to chose different options with the cable for the laptop I ordered?
Default 08-14-2019, 07:08 PM
Originally Posted by Dpas1973
Hello I just ordered my jb4 for my 19 raptor. I did not purchase the wireless setup since I’m not tech savvy. Do I just plug and play this or do I have to chose different options with the cable for the laptop I ordered?
It's Plug and play. map1 which is how it's shipped. So long as your OBD cable is plugged in. If you want to change any maps you will need the cable or the wireless kit.
Car: 2019 raptor
Default 08-14-2019, 07:12 PM
What other maps can I change too? I hate asking stupid questions but I am not computer savvy at all.
Default 08-14-2019, 07:53 PM
Check out the first page of this thread. It lists the maps and what they are for.
Car: 2019 raptor
Default 08-14-2019, 07:59 PM
Thank you. How do I change the mode?
Default 08-14-2019, 09:19 PM
Just plug it in and enjoy!
Default 08-15-2019, 01:59 PM
Terry...What is the best way to datalog with the 10 speed transmission? I know with my mk7r I'd do a low rpm 3rd gear pull in manual mode to avoid the kick down.
Also is avg_ign what we are looking at for logging the timing? I don't think this platform does the individual cylinder display
Thanks in advance
Default 08-15-2019, 03:42 PM
He can be tricky, just a 4-5-6 run is usually OK, or a simulated 1/4 mile, depending on what you're looking for.
Avg_ign is the peak knock timing retard (in any cyl) with the latest firmware. The lower the better, but on lower grade fuels there will always be a little.
Car: 2019 raptor
Default 08-18-2019, 04:40 PM
do i need to download an app to change the maps?
