Honray Honray is offline
Car: 2008 335i Sedan
Default Porsche 992 JB4 installation tips? - 01-20-2021, 04:40 PM
Has anyone installed the JB4 into the 992? I have a convertible and while the TMAP sensor is easy enough to get to, the MAP sensor on the intake manifold is buried deep into the engine bay. I have rather slender hands but there is no way I can get my hand in deep enough to access the MAP sensor let alone wiggle it out with the plastic locking mechanism. I cannot even touch this thing. Any ideas out there?
Default 01-20-2021, 04:42 PM
dragy dragy is offline
Car: BMW 320i
Default 01-22-2021, 08:31 PM
I was able to installed the map sensor after removing the rear bumper and ECU.
Default 01-25-2021, 01:11 PM
If you unhook the ECU harness, that will leave you space to reach and undo the manifold sensor.
Default 07-14-2021, 09:59 AM
Gigantic struggle... and months later. The JB4 is in. It's worth it. Performance I can feel.
Default JB4 not working Map 3 Map 4 - 10-29-2021, 07:17 AM
JB4 on 992 not working for Map 3 Map 4 properly. Car seems to be shifting abruptly and too often with the PDK. JB4 cannot record logs. The phone app crashes on "Start Logging".
Map1/2 works just fine. OBD is plugged in and I can see AFR/RPM etc. data.
Any ideas here BMS team?
Default 10-29-2021, 08:37 PM
Can you try to get us a log and post it up on map 3?
