Default JB4 for Porsche 911.1 and 911.2 - 05-30-2019, 01:10 PM
We will use this thread for info on the upcoming JB4 for Porsche 911 models!
Purchase Here: https://www.burgertuning.com/product...-911-turbo-jb4
JB4 Map Guide:
Map0 - JB4 disabled
Map1 - 2psi peak 91 octane
Map2 - 3psi peak 91/93 octane
Map3 - 4psi peak 93 octane, race gas, or ethanol blend
Map4 - 6psi peak ethanol blend or race gas
Map5 - 8psi peak ethanol blend, race gas, CPI required
Map6 - User adjustable by RPM map using settings on user adjustment page. Setting of 5.0 would request 5psi over stock at that specific engine speed.
Map7 - Progressive WMI integrated map, boost profile under WMI flow adjustable on WMI page.
Map8 - Valet map in 911.1, 911.2 same as map0
How to update firmware:
For firmware updates we suggest you turn off WiFi, change upload timeout to 25, and set your phone next to JB4 box under the hood.
Default 05-30-2019, 02:42 PM
Awesome stuff!
Thanks Terry
Default 07-01-2019, 11:31 AM
Dyno Testing:
Payam was able to trek down to Weistec today to use their all wheel drive dynojet for a little tuning on our 2014 911 Turbo S development car.
Mods are the BMS intake, BMS chargepipe, Exhaust, BMS CPI, and of course the JB4 for tuning. The ECU on this vehicle is 100% factory and never been reflashed.
Baseline testing was done on 91 octane with CPI disabled, and then Payam cranked it up by adding in some E40 fuel and turning on CPI. Frankly we're not sure what others are getting with the car but we've been pretty impressed with its performance for such mild mods. It ran 166mph at the last Shift Sector standing 1/2 mile.
Sticky Sticky is offline
Car: M3
Default 07-02-2019, 06:09 PM
And you couldn't get the damn thing on my car when you had it?????
Default 07-02-2019, 07:14 PM
You gave it to the wrong person LOL
If it involves taking the rear bumper off, Terry wont do it
winnigt2 winnigt2 is offline
Car: 991.2 Turbo S
Default 09-03-2019, 04:35 PM
interesting System for 991.2 turbo s
One Question if i see the log data.
Wy Ignition is about 30 degress with high boost / and 20 degress with low boost in the logs for the 991 turbo S (red line peak 30 degress wiht 22psi boost ) red line 24 degress with 17psi boost)
Default 09-04-2019, 10:29 AM
More timing with more boost with higher octane fuel.
Lower timing with less boost on regular pump gas 93/91.
Car: 991.2 Turbo S
Default 09-07-2019, 03:09 AM
Is it possible on your beta version to create with map 6 a rpm depend boost curve
as following example?
Default 09-07-2019, 11:35 AM
Yes map6 for user customized boost profiles is active.
Car: 991.2 Turbo S
Default 09-07-2019, 01:04 PM
so it is possible to create a boost ramp depend on rpm ?obd interface is used for the rpm singal for my unterstanding
Default 09-07-2019, 05:00 PM
Right, it uses OBDII port to read RPM for that part of the mapping. Also reads pedal input, engine temp, afr, timing, fuel trims, throttle position, and much more to be incorporated in to the tuning.
Car: 991.2 Turbo S
Default 09-08-2019, 02:27 AM
Thanks for your answers
now another question / if i like to create a Boost 6 map, can I use your basic maps and correct only the boost by rpm......(like to add boost only above 4000rpm)
sorry my english is not the best
Default 09-09-2019, 10:16 AM
That would be only for map 6, so you can edit any value you'd like.
The other maps are preloaded and can't be changed.
So yes, if you want most boost only at 4krpm and above. You'll make a special map 6 boost profile.
luchocamp's Avatar
Default 09-10-2019, 02:43 AM
great stuff
15 BMW M4 Full Weight 10.69@133mph stock turbos SOLD
18 BMW M2LPower
Car: 991.2 Turbo S
Default 09-18-2019, 11:35 AM
I already ordered a JB4 for a 991.2 turbo S over European Shop
What psi is possible with 95 Oktan US (European102 Oktan) Map 4?
If i create a boost map 6 / i copy one your map in the map 6 an adjust only boost by rpm..correct? (i see a lot of adjustable points in the map 6 and like to copy the variables to correct only boost by rpm)
Default 09-19-2019, 10:25 AM
Yes, but you might need extra fueling.
Start with map 3 for now and post a log.
Correct, map 6 you can adjust boost via RPM to your needs after we review some logs
Default 11-18-2019, 06:57 PM
Found a possible bug in the 911.2 firmware. Anyone have time to load an update and grab a log so we can confirm?
135burner 135burner is offline
Car: Audi S4
Default 03-14-2020, 08:27 AM
Any plans for the 991.2 S models (also turbocharged)?
Default 03-14-2020, 02:30 PM
Yes, the JB4 tuning is compatible with the new TurboS as well.
Car: Audi S4
Default 03-14-2020, 02:47 PM
Sorry, I should have clarified. I meant the 991.2 Carrera S and 4S models; the non turbo models (although, still turbocharged themselves).
Default 03-16-2020, 10:38 AM
Yes, we have it here:
https://www.burgertuning.com/product...63fa8222&_ss=r
Default 03-14-2020, 08:03 PM
The same 991.2 JB4 system should be compatible across the entire lineup.
OWLY OWLY is offline
Car: Porsche
Default 04-13-2020, 07:16 PM
In the instructional video, the OBD II connector wasn't plugged in. Is necessary to do so? What role OBD II play?
Default 04-14-2020, 09:29 AM
Yes, the OBD2 plays an important roll with the JB4. That give the JB4 the CANbus feedback and information it needs to tune with.
You can leave it unplugged, but you will only be able to use maps 1/2
Ralonso Ralonso is offline
Car: 2017 911 4s
Default 04-21-2020, 06:27 AM
hello,
I am new to this thread. I just installed the jb4 on my 2017 911.2 4s. right now I only have a BCM filter no other mods but i am installing the Soul *** bypass *****.
right now I have the jb4 on map 3 runnig 93 pumpo gas with some octane boost. I don't feel like i am getting any gains. i was boosting about 14psi at wot 6800 rpm, which is more or less where it was before.
anything I'm doing wrong? i looked to see if i needed an update but was a little apprehensive to start the process after reading the instructions. currently have JB4_PORSCHE-912_2_2.HEX firmware file version 9112/2//7.
thanks
