(#876)
Default 02-08-2020, 10:23 AM
Looks like they may have changed the CANbus ID for the 2020 models. Need one to swing by so we can check it out! We'll make it worth your while.
Drh784 Drh784 is online now
Car: 2020 AMG C43 Sedan
Default 02-10-2020, 04:51 PM
Cmon guys someone with a 2020 please bring it to Terry!! Im dying to get this canbus working!! Lol
Default 02-14-2020, 02:35 PM
Don't worry someone will turn up sooner or later.
Savvy Savvy is offline
Car: C300
Default 02-16-2020, 08:48 PM
When i updated to the new firmware the gauges started jumping all over the place here's a idle log
Default 02-17-2020, 01:41 PM
You have a different SENT system so the V6 firmware posted is not going to be compatible with it. You'll need to load the SENT firmware.
C292 C292 is offline
Car: C292 Coupe
Default 02-17-2020, 10:10 PM
Completely agree with Terry, have my system stable on idle with map 1, 2 & 3 after updated last firmware jb4_mb_c_6. Here are the logs
aussie644 aussie644 is offline
Car: W205 C43 2017
Default 02-21-2020, 03:06 PM
Can we get some clarification on the new Maps, please?
Map 4 is now between Map 3 and Map 5, but Map 3 is based on the boost safety (according to the first post), which I think is 3 by default, so it's now between 3 and 6.5, which is also where Maps 1 & 2 are??? This is based on the initial descriptions.
So now, Map0 logs all parameters, and is the baseline logging map right?
Finally, Map 8 is now the Valet Map, which is cool! More specifically, are you able to tell us any more about it, or point me to where I can find out?
Thanks for the continued work!
Default 02-21-2020, 04:55 PM
I'll go fix the first post right now!
gekkie96 gekkie96 is offline
Car: C43
Default 02-23-2020, 08:52 PM
Do you need a c43 or c300 to stop by? I have a 2020 c43.
Default 02-23-2020, 09:40 PM
Yes they def need a 2020 c43 to stop by. I also own a 2020 c43 and am patiently waiting for someone to stop by Terry so i can get my jb4 up and running! Thank you in advance!!!
Default 02-23-2020, 09:41 PM
I think either one should work for the 2020 model, C300, C400, or C43. They probably all use the same CANbus system. Drop me an email and we can set something up. terry@burgertuning.com
Car: C43
Default 02-23-2020, 09:46 PM
Where is the shop located?
Car: C43
Default 02-24-2020, 08:15 AM
I sent you an email Terry, looking forward to talking.
DubVBenz DubVBenz is offline
Car: W212 M276 DELA 30 ; W211 OM642
Default 02-27-2020, 09:04 AM
Hi Terry - Can you share the previous firmware map definitions so I can better understand the changes? I never documented them
Drh784
