PGNDAz PGNDAz is offline
Car: M235i
Default Log check / propper logs? - 03-28-2017, 12:23 PM
I just got my JB4 and tried logging maps 1 and maps 5 ill enclose the CSV files below- can you tell me if evreythings fine or if the logs aren't adequate?
Its a 2014 M235i
I'm running only a BMS intake and the M performance exhaust.
Car: M235i
Default 03-28-2017, 12:23 PM
NOTE*** map 5 file was too large.
Is there a way to cut it down since 90% is unneeded? ( it seems it did not do WOT only)
miksebik miksebik is offline
Default 03-28-2017, 01:01 PM
I use LibreOffice to read CSV, trim it and then save it as csv
E92 335i N54 MT. Hydra Performance HP650.
Car: M235i
Default 03-28-2017, 01:03 PM
gotcha thanks for the help!
Car: M235i
Default 03-28-2017, 04:34 PM
Here is a better map 5 run as well- the map 1 run is in the first post
questforthetune questforthetune is offline
Car: m235
Default 03-28-2017, 07:55 PM
Bump for log review?
Default 03-28-2017, 09:27 PM
Map 5 looks fine to me. FF is really low but learning up as needed.
Car: M235i
Default 03-29-2017, 01:27 AM
Great! I'll be adding e85 starting with a gal, and relogging😎
Default 03-29-2017, 08:30 PM
Car: M235i
Default 03-29-2017, 08:50 PM
I'm somewhat scared what the big show your waiting for is haha. I added 1.5 gal and had a log but my laptop crashed 😕. I didn't notice bucking or timing bieng pulled in 5- but I'm still nervous of course
Default 03-29-2017, 09:04 PM
You'll be fine with 2 or 3 gallons of E85. Bump your FOL up to 70 and post a log when you can.
Car: M235i
Default 03-29-2017, 09:12 PM
Will do tommorow! Can't wait to get the connect upgrade as well- see some parameters
I saw peak of 15psi- but I don't know anything haha so without a log in sure it's useless. Never thought I'd be thrilled at the Possible need to have to get a metal charge pipe!
Default 03-30-2017, 08:30 PM
Car: M235i
Default 04-02-2017, 05:50 PM
Got a log! hopefully its good, its tough to find a private road to make the run on since I don't want to be unsafe on public roads.
This is Map 5 on 2.2 gallons of E85.
I noticed in manual mode in 7th gear accelerating slightly I felt some jerkiness but it could have been me modulating throttle absent mindedly too.
Car: M235i
Default 04-03-2017, 07:41 AM
bump!
