(#601)
Default 12-01-2019, 09:09 AM
Originally Posted by gusman
Hi, I'm looking into getting a 2019 f150 platinum with the 3.5L tt with 375hp/470tq. How much whp/wtq gains could I get with map1 on the jb4? I searched the thread but couldn't find any dyno listings for the non raptor 3.5L tt. I'm running 92 octane pump gas where I live. Thanks.
It's around 40hp on map1, solid gains.
reaperofchaos87 reaperofchaos87 is offline
Car: 2019 Ford Ranger
Default 12-04-2019, 01:23 PM
Guy over at Ranger5g is testing a Jb4 for the new Ford Ranger, but is being a bit coy. Any ideas how that is going? Are you expecting power gains similar to what you get on the 2.3 in the mustang?
Charlie
Default 12-04-2019, 02:53 PM
Charlie
We're still finalizing the tuning side so it's still speculation.
We'll try and get some numbers for you guys soon
Hammmerhead Hammmerhead is offline
Car: F150
Default 12-06-2019, 07:25 AM
Originally Posted by Hammmerhead
Is the speed limiter removed with the current JB4 tunes?
Is the transmission changed also doing away with the skip shifting on the 10 speed?
Does anyone know about different Trans mapping or the speed governor with the JB4 ?
Default 12-07-2019, 11:20 AM
The JB4 isn't able to remove the speed limiter, you'd need to add in a flash map for that. Since true max speed is stored across several modules on the truck most people avoid that if under any sort of warranty.
Default 12-07-2019, 11:21 AM
Charlie
It's basically up and working, we're putting together 5 test systems this week and will be seeking BETA Ranger customers.
Default 12-09-2019, 08:49 AM
Thanks for the update!
I know I'm new here.....but am happy to volunteer
Car: F150
Default 12-09-2019, 03:25 PM
Did not know that. Thank you! Is the over boost not recorded using the JB4?
Joseph.machen2 Joseph.machen2 is offline
Car: 2015 ecoboost f150
Default 12-12-2019, 12:13 AM
Just curious, I noticed my IAT pid is stuck at 32 all the time on the jb4 read out. I have plugged in my scanner and made sure it's not the truck. sensor values were correlated with ambient temp at cold start with my scanner.? Thanks in advance.
Default 12-12-2019, 10:06 AM
On some models we may have the wrong IAT logging channel. What version of firmware and truck?
Default 12-12-2019, 10:25 AM
Thanks for the reply terry! I currently have eco 6 firmware and it's a 2015 3.5 eco f150
Default 12-12-2019, 10:31 PM
Got it.. I'll see if anyone else has the issue. BTW latest firmware is v7 in the first post.
Default 12-13-2019, 04:57 PM
Ok thank you. I'll go download the new firmware. It's not a huge issue because everything else seems to be working fine.
