(#76)
Default 01-03-2018, 11:12 AM
Originally Posted by Jmwilson125
I know that BEF is only for jb4. What I do not know is if the bef is essentially a flash tune that is designed to work with a jb4 car, or if it just compliments the jb4?
Example the jb4 tricks the ecu nto creating more boost. Does the BEF alter the ecu boost directly? Or is it still looking at the jb4?
I figured options were jb4 with BEF and wmi or OTS with a standalone wmi controller. I just do not know what benefits the OTS route would have over JB4 + BEF.
How the BEF is implemented depends on the application and BEF map itself, but it's designed to allow us to provide tuning and features beyond what can be done flash only. Otherwise, what would be the point?
Down the road we can get in to the details. It's still early days on development on both fronts, and I see absolutely no reason to bog down in to it right now. Just know that there are plenty of great options on the horizons to move the F series platforms further thanks to MHD releasing this software.
705's Avatar
705 705 is offline
Car: E90
Default 01-04-2018, 06:58 PM
Originally Posted by Mike_L
What are the Android requirements for the MHD app? I get a not compatible message when I try to put it on my AT&T Trek HD. I use an iPhone, so that’s the only Android I have (thank god!).
Any android device running android 3.2 or higher...
I have a samsung galaxy tab pro 10.1 with “f-series” N55 installed. Works for me.
Waiting for my bimmer geeks cable to arrive as well.
http://mhdtuning.com/support/
705's Avatar
705 705 is offline
Car: E90
Default 01-04-2018, 07:01 PM
Wondering when a jb4 BEF will be available.
Default 01-04-2018, 07:06 PM
When you guys are able to flash and ready to help the cause just email me, and we'll get started!
bg435i bg435i is offline
Car: BMW 435i
Default 01-05-2018, 05:44 AM
@Terry i have all the things to try the BEF. I can‘t still wait to try this.
Default 01-05-2018, 11:41 AM
Email me I've got an F series N55 BEF file ready to load, will need lots of logs as we fine tune and tweak things.
P.S's Avatar
P.S P.S is offline
Car: M135i xDrive
Default 01-05-2018, 11:43 AM
Worth trying yet with my mods?
M135i xDrive EWG, JB4, Pure S2, Pure inlet, N20 tmap, c a tless, Wagner fmic, FTP chargepipe, Fuel-it PI, BMS PI controller, Fuel-it lpfp, ACF Performance back end flash. 10.9s @ 204km/h
Default 01-05-2018, 11:50 AM
Absolutely! But since you already have a BEF do a run or two as it is now so we can compare and work on it.
Nachos23's Avatar
Nachos23 Nachos23 is offline
Car: about to purchase 09 335i Xdrive
Default 01-05-2018, 01:06 PM
Hi Terry, Is that BEF EWG only?
2016 335 GT - let the upgrades begin..
2000 Z3M - too many upgrades to mention ... lol
Default 01-05-2018, 03:11 PM
We're working on EWG and PWG... I think according to MHD the only F N55 platform we can't do yet are PPK cars, as they require some special coding that isn't ready yet.
Nachos23's Avatar
Default 01-05-2018, 03:18 PM
Oh perfect! So, just need to pay for MHD master license (I've installed the app) and you'll email the file which we load using MHD app correct? Waiting to confirm the OBD cable I need for my F10 N55 JB4 I got from a buddy (missing ODBII cable; final section).... do I order just the Cable only from site?? Do I need to have JB4 installed prior to installing MHD flash?
Default 01-05-2018, 03:23 PM
For what we're doing yes install the JB4. When you flash you unplug JB4 OBDII to flash then plug it back in after.
Nachos23's Avatar
Default 01-05-2018, 03:26 PM
Hi Terry... So, in regards to OBD II cable, do I need to order JUST the cable or the cable with side connector for retorfit option? I have the 4pin molex connector coming from JB4 but missing OBDII section...
Car: BMW 435i
Default 01-05-2018, 03:59 PM
@ Terry can you send me per PM the right email adress for the BEF and a right Guide to install the BEF on my car, please.
5soko's Avatar
5soko 5soko is offline
Vintage
Car: F10 N55 PWG
Default 01-05-2018, 04:48 PM
Can the MHD BEF remove the speed limiter on the F series aswell? Can this be done in app as a selection, or are the BEF maps provided will have this done by default?
2014 F10 535i N55 PWG
Nachos23's Avatar
Default 01-05-2018, 06:25 PM
do we use a different app other than the MHD app to load the flash? I see two versions of MHD app in App store N54 and N55 E-series....
JuicedboXed42 JuicedboXed42 is offline
Car: 2008 BMW 335i
Default 01-05-2018, 06:41 PM
@Terry can I do some betas as well?
Default 01-05-2018, 09:11 PM
You need to join MHD's F series BETA group and flash map0 via MHD, before you're ready to contact me.
Yes, we'll remove it in our JB4 BEF.
jet_00's Avatar
jet_00 jet_00 is offline
Car: M235i
Default 01-06-2018, 03:50 AM
If I understand well, JB4 BEF will not work on M235i and M135i ? Or only on M135i PWG ?
Devitto Devitto is offline
Car: M135i 2015
Default 01-06-2018, 02:27 PM
I have my DME unlocked. Do I need to upload the MHD flash software (25 min) and after maps (2-3 min) or can I go straight to the maps?
WaqasRiyami's Avatar
Car: Bmw 535i - 2011
Default 01-06-2018, 02:31 PM
Straight to maps
Car: M135i 2015
Default 01-06-2018, 02:38 PM
Originally Posted by WaqasRiyami
Straight to maps
The DME was unlock to bm3. Can I use straight a MHD map?
Do I have to buy any license for the BETA test?
Iím not finding. I only find to E series..
Default 01-06-2018, 02:54 PM
So you are still not in the Beta team , you will have to wait untile the official reales of MHD after about 2 weeks
akgambino akgambino is offline
Car: 2013 F30 335i xDrive
Default 01-06-2018, 03:53 PM
Now that this bms bef for the jb4 is in the works what exactly are your goals with the flash terry? As in what can someone expect to see as a result of loading in the back end flash, specifically on a jb4 pwg ******* ** car on 93octane?
Smoother? More power? More torque? More burble?
