Didier Didier is offline
Car: BMW 320I Sport GP
Default 06-24-2021, 11:45 AM
I'll check the codes. Sorry, what is DTM?
Default 06-24-2021, 01:02 PM
The read codes follow. I take the opportunity to forward a snapshot of the settings
Default 06-25-2021, 06:35 AM
Hi!
I deleted the codes and made a new datalog.
I reread codes and none were reported.
Follow datalog file and code reading before deleting and after executed datalog.
Have a great weekend!
Default 06-25-2021, 10:14 AM
A DTM is a Drive Train Malfunction.
There are inconsistencies in your WGDC that we need to work out. I'm thinking it may be an issue with the EWG connection but am also getting a second opinion as I haven't seen this before.
Default 06-25-2021, 11:00 AM
Okay....update your firmware to V8_T4 and set your PID Gain to 20. Do a log and lets see how that looks..
Default 06-30-2021, 05:38 AM
Hi!
Here is a new datalog. I checked and there are no error codes.
Default 06-30-2021, 10:43 AM
That looks much better and I'm assuming feels a lot better?
Default 06-30-2021, 11:14 AM
Yes, I felt an improvement...but I believe we have a little more to extract from the engine, am I right?
Default 07-15-2021, 12:25 PM
Steve,
is it possible to increase the performance a little more?
Tks
Default 07-16-2021, 09:28 AM
Not much, your WGDC is very high.
Default 07-16-2021, 09:45 AM
And what would be the next step to get more power?
What parts would need to be upgraded?
Tks
Default 07-19-2021, 12:07 PM
With this motor...I wouldn't push it too hard without upgrading internals. They've been known to pop.
Default 07-19-2021, 12:47 PM
Understand. As it currently stands is it safe to run?
Default 07-20-2021, 10:31 AM
Yes, that should be fine.
cityhunt3r's Avatar
cityhunt3r cityhunt3r is offline
Car: 2013 BMW 320i
Default 03-09-2022, 07:28 PM
I wanna run e85 also... so all i need is the JB4? and the EWG cable to connect to my jb4?
Car: Evo VIII
Default 03-11-2022, 10:32 AM
Yes!
cityhunt3r's Avatar
Car: 2013 BMW 320i
Thumbs down 03-11-2022, 10:36 AM
Ando at BMS just told me I can only run E30 NOT E85
Car: Evo VIII
Default 03-11-2022, 12:03 PM
E85 is a loose term. E85 is what you will fill up with as well as 91 octane to get to E30.
When filling up "straight/full" E85, then you would fill up with E85 only.
E98 = 98% Ethanol, 2% Unleaded
E85 = 85% Ethanol, 15% Unleaded
E30 = 30% Ethanol, 70% Unleaded
91 Octane = ~10% Ethanol, 90% Unleaded
cityhunt3r's Avatar
Car: 2013 BMW 320i
Default 03-11-2022, 12:24 PM
is there anyway I can go straight e85 on my 2013 320i EWG with a JB4 map?
Car: Evo VIII
Default 03-14-2022, 11:33 AM
The vehicle would need a BEF and proper fueling/supporting mods.
cityhunt3r's Avatar
Car: 2013 BMW 320i
Default 03-14-2022, 12:24 PM
Do you guys sell all the necessary equipment? If so can you give me the list of items I'll need?
But if I'm going to run e30 I m good to go on stock setup right?
Car: Evo VIII
Default 04-04-2022, 02:34 PM
Upload a log on E30 first.
The link will take you to the N20 fuel pump upgrade.
https://burgertuning.com/products/bm...f5b25a9a&_ss=r
Davion345 Davion345 is offline
Car: BMW 228i x drive
Default N20 Jb4 will run map 1 fine but when i run map 2 it keeps switching to map 4 - 07-03-2022, 08:37 PM
List mods full bolt ons including a ********. The car was running map 1 just fine i finally get my ******** installed and switch to map 2 but now it keeps changing to map 4 on its own. Its not right away i can do a couple of pulls in map 2 before it switches over to map 4 again
