araquemoliveira araquemoliveira is offline
Car: BMW 3301 2019
Default 08-19-2021, 10:57 AM
Thanks George.
With map 6 above:
1500 1
2000 2
2500 3
3000 4
3500 4
4000 4
4500 3
5000 3
5500 3
6000 3
6500 2
7000 2
is it less dangerous?
Or thinking about longevity is it better to stay on map 1?rsrsrsr
Moderator
Default 08-19-2021, 11:24 AM
Originally Posted by araquemoliveira
Thanks George.
With map 6 above:
1500 1
2000 2
2500 3
3000 4
3500 4
4000 4
4500 3
5000 3
5500 3
6000 3
6500 2
7000 2
For the octane this is safe. More torque than map 1 and similar at higher rpm.
2021 VW Golf 8 R
Car: BMW 3301 2019
Default 08-19-2021, 11:27 AM
Thank you very much George.
TURBINA TURBINA is offline
Car: TCROSS 250 1.4 TSI
Talking Questions - 07-02-2022, 05:24 PM
George,
Before the Tcross 250 Flex 1.4 Tsi ( today), I had a Golf Mk7 2017 1.4 Tsi (same engine and TipTronic gearbox), Full on alcohol, with same down pipe and intake k&n) and I rode with it at approximately 180 whp (with remap), with a peak of 1.6 bar of pressure, with an upgrade of turbine rotor that we assemble in the company (31,94 x 35,6 mm)( no problems ). Now with a much bigger upgrade (36 x 38,5 mm), I want to put the same pressure or more because I know it will easily with stand the turbine, because we have the machine that we tested the limit of rotation and pressure before putting it to run.. ( But I know that the flow is different ). I will make a log of 3rd and 4th gear and send you to see what you advise me by monitoring the logs. What do you think ?
Moderator
Default 07-04-2022, 05:49 AM
Originally Posted by TURBINA
George,
Log it and lets see what it does and how the fueling looks.
2021 VW Golf 8 R
