(#301)
Default 05-09-2018, 04:12 PM
The E85 value is currently used only for port injection integration and only if enabled. We'll be adding more to that soon.
The physical sensor takes priority if installed over the virtual sensor.
QKRTHNU QKRTHNU is offline
Car: 2009 E82 135i Coupe LeMans Blue
Default 05-10-2018, 07:33 AM
So as of right now if I'm planning on going with a JB4 integrated PI setup do you recommend adding a physical sensor or not?
Default 05-10-2018, 11:30 AM
The physical sensor will only help the JB4 for the ethanol content, it wont only rely on the virtual sensor.
buster84 buster84 is offline
Default 05-25-2018, 05:42 PM
So the current flex fuel capability is entirely dependent on port injection? I know MHD is releasing some new flex fuel maps. Are you planning to look into this as another alternative to how the jb4 does flex fuel?
2009 335i X-Drive | GC 2.0 Turbos | VTT silicone Inlets | VTT Aluminum Outlets | Fuel It PI with FPR,return line, BMS controller, and flex fuel sensor | Fuel It Stage 3 fuel pump | BMS dual cone instakes | BMS Catch Can | VRSF 7.5" Race Intercooler | Forge Diverter Valves | JB4 G5 ISO with Blutooth/JB4 Mobile App | n20 tmap sensor 3.5 bar | AR After turbo Exhaust
Default 05-25-2018, 07:40 PM
Yes we plan on incorporating whatever new tables MHD has to offer in our back end flash map (when loaded via MHD), once the XDF and relevant information is posted.
Default 05-25-2018, 08:19 PM
Sweet. Will this also be released for those with custom flashes? I have a custom back end flash by trebia and I would like him to update that full e85 for me once you guys get it all finished up. If he reached out to you guys will you offer up the tables to him?
Default 05-25-2018, 08:28 PM
Normally what happens is we introduce the basic logic in our public maps then you work with your custom tuner to refine that as needed.
Default 05-26-2018, 08:08 AM
Perfect. Will you be creating a new thread when you get it all finished or updating this one?
Default 05-26-2018, 08:28 AM
We'll post it somewhere.
Car: 2013 Genesis Coupe
Default 05-31-2018, 12:22 PM
My E85 is way off do I lower the offset or raise it?
Default 06-01-2018, 10:39 AM
Depends whether it's off high or low. A lower offset will increase the virtual E85 reading IIRC.
Default 06-01-2018, 10:45 AM
It's way high, what's the maximum setting and minimum?
DSCOFF's Avatar
DSCOFF DSCOFF is offline
Car: 335i coupe N54
Default 06-01-2018, 01:46 PM
Terry, if my e85 vso is suddenly declining to where it should be at does that mean I should wait till it recovers (in my case 85-88) before I do any wots? I notice if I do any changes in the user adjustment page while engine is off, the e85 vso can decline quite rapidly
2009 N54 335i coupe, 6AT PD trans, Stage 3 XHP, Built Motor, 9.6:1 Comp Ratio, Ported Head, Trebilia Custom Flash, JB4, Mhd flasher, Ngk 97506 0.018 gapped, PI Kit 100% E85, Jb4 PI integration, Stage 2 Pure Turbos 25.6psi, 17.2 deg timing, TFT inlets, Stage 3 Fuel-it Fpr, FBO, 431rwkw Mainline Dyno Aus
2016 M4 Competition Pack, 7-sp DCT, Jb4 Map 6
25.0 psi, s55 ign e85 Bef, E70, M4 plugs gapped 0.020, stock everything else, 374.9 rwkw Mainline Dyno Aus
aoerick aoerick is offline
Car: bmw 335i n54
Exclamation E85 vso - 11-18-2018, 11:44 PM
My vso indicates I'm running at 58% but I'm on 91, is there a way to get it back to 0?
Both logs are running the same gasoline no refueling or adding anything, I've tried changing the vso parameter and it doesn't seem to help or change, I even tried setting it up to 0
Vargas Stage1's Avatar
Vargas Stage1 Vargas Stage1 is offline
Car: 335i bmw e90
Default 11-22-2018, 09:19 AM
My JB4 E85 mobile set @ E55 content goes down to E50 or so but under full throttle pulls does come back up to Correct Content... E55
Haynpunch's Avatar
Car: 07 E90 335i
Default 11-22-2018, 02:12 PM
Do you have an actual inline sensor or virtual?
AJoosten AJoosten is offline
Default Voltage from Flex Fuel Analyzer to JB4 - 01-24-2019, 12:50 AM
I figured it out looks like 0-5 volts still.
[QUOTE=Terry @ BMS;533484]Worth noting the Fuel-IT analyzer uses a simple voltage formula like 0-0.1v = 0% E85 and .1v - 5v = 0-100% E85, which I expect will be compatible with any flash DME flex fuel sensor voltage input logic released. ]
Terry, is this scale still what is being used in the JB4 conversion from volts to Ethanol content?
0 Volts=unused/error
0.1 Volts 0% Ethanol
5.0 Volts 100% Ethanol
Sorry I am nerding out on some electronics right now. Thanks
09 135i N54|JB4 G5|BMS PI Cont|BEF Hybrid PI E85|Pure Stage 2 Hi-Flow Turbos|NGK 97506|Fuel 85% Ethanol|BM-Parts PI 750cc|Dual Walbro 450LPFP Bucket|Ethanol Sensor|3/8" Fuel Line|Stett Dual Oil Cooler|VRSF Relo Inlets|Active Autoworks7" FMIC|VRSF CP|HKS SSQ BOV|Agency Down & Mids|BMS Cowl Filter|MFactory LSD|JE Piston Heads|SPEC STG 3 Spr 6|ACT Pressure Plate|SPEC Single Mass Alum Flywheel|COBB Sway Bars|Ohlins Coilover 400/600|CAR BLOG
SamJ SamJ is offline
Car: BMW 335i
Default 04-30-2019, 08:12 AM
just checking with a kline car with E85 BEF do i set the virtual offset to 132 to start with still and then see how close it is to what I guess it should be?
Car: BMW 335i
Default 05-02-2019, 01:49 AM
Tried 132 setting and the E85 is reading way low
I’m not sure what my fuel scalar is but I’m assuming it’s lower than what Terry runs so tried 120 and it’s still reading low, shows 30 at most on the gauge and I’m running 2/3rds E85
Even allowing for bad fuel this should be 45-50 at worst
I’ll find out what my Fuel Scalar is but is it normal to have to go lower than 120 to get a correct reading?
