(#51)
erichale's Avatar
erichale erichale is offline
Car: 335i coupe
Default 04-20-2015, 08:24 PM
That link from above is him. Goes by mOdcr4zy
07 335i AT/CUSTOM 6870 GEN2 ST/VAC ENGINE AND STAGE 3 HEAD/FABFACTORY INTAKE W/PI/1000HP AD FMIC/EOS BILLET FUEL SETUP/BL COILS/DUAL OIL COOLERS/RB EXTERNAL PCV/PD TRANY W COOLER/M3 FRONT N REAR SUSPENSION W/ROUGE BEARINGS/HOTCHKIS ADJUSTABLE END LINKS/ADUSTABLE REAR TOE ARMS AND CAMBER LINKS/EIBACH SWAYBARS/BC RACING BR COILOVERS AND CAMBER PLATES/AKG REAR SUBFRAME, DIFF, REAR SHOCK BUSHINGS/POWER FLEX BUSHINGS/WAVETRAC REAR DIFF WITH DEFIV BRACE AND VAC COVER/4IN EXHAUST
cebrailbakan's Avatar
Car: BMW E90 335XI
Default 04-21-2015, 01:44 PM
Originally Posted by robc1976
I have the Motiv 750 (for sale actually) abd I am fine at 23-25psi with stock AT.
How much horsepower with motiv 750 kit at 25 psi for an awd car ? It is really unbelievable that stock gear box can hold 25 psi easily
Do more with less !
robc1976's Avatar
robc1976 robc1976 is offline
Car: 2007 335i
Default 04-21-2015, 01:59 PM
Motiv kit will not fit Xi
Dmac @ BMS/DMD's Avatar
Car: 2008 135i
Default 04-23-2015, 12:58 PM
Minor update.
robc1976's Avatar
Car: 2007 335i
Default 04-23-2015, 01:17 PM
I honestly an thinking of going with a TH4000
Car: 2008 135i
Default 04-23-2015, 06:30 PM
Go for it! We need more people trying different options so we can find the best one.
Car: BMW E90 335XI
Default 04-24-2015, 08:51 AM
So, which one is the most reasonable for an awd fueling with 93 octane and methanol ?
Do more with less !
Default 04-24-2015, 10:49 AM
Vm top mount kit fits XI
Nniftyfour's Avatar
Default 04-24-2015, 08:04 PM
A friend of mine just had them finish up a full build for his car... Went in for the Valvebody and his clutch packs were toast.
I'm going in the morning to drop my car off the Valvebody.. I'll post a review on Monday when I get it back.
Full build is $5k installed.
The drive out to them is rather boring.. but the shop is nice.
Bowser330 Bowser330 is offline
N54TECH FTMFW
Default 04-25-2015, 12:08 PM
https://www.powertraincontrolsolutio...on_Controller/
The TCM-2650 is compatible with the GM 6L45/50, 6L80/90, 6T30/40/45, 6T70/75, Allison 1000 (5 and 6 speeds), the 2nd generation ZF 6HP and the Volkswagen DSG.
If only someone would do a custom controlled 6l80e !!!
Car: 2008 135i
Default 04-25-2015, 12:19 PM
That is truly interesting. Good find!
Nniftyfour's Avatar
Default 04-25-2015, 01:59 PM
I've run without gear control before. (TCU DME sync) Car shifted awfully. The revs hung and slammed into gear. Theres 100% things the DME does during shifts / messages it expects to receive or else the revs don't fall fast. We would need to do some modifications the DME bin as well probably or just code it for Manual (and simulate the clutch but thats easy just ground the circuit). Either way, Just thought I'd add that.
Race8877's Avatar
Race8877 Race8877 is offline
Car: BMW 135I
Default 04-26-2015, 08:06 AM
Question is : Do the level 10tranny holds more than 600+ HP. They claim 1000HP.
That I have to really see.
JBacon335 JBacon335 is offline
Car: 2007 BMW E90 335i
Default 04-26-2015, 12:30 PM
It really kills me that there's no tuning for the tcu available to really find out what these transmissions are capable of
Car: BMW E90 335XI
Default 04-26-2015, 02:51 PM
Well, could I use that turbo instead of my whine death Rbs? Is it better ?
How much psi can I control with a proper tuning ?
Thanks a lot
Do more with less !
Car: 2008 135i
Default 05-01-2015, 02:09 PM
Updated.
Default 05-01-2015, 04:19 PM
You should have got the redline stuff, its like 13$/qt you only need like like 7 I believe?
Car: 2008 135i
Default 05-01-2015, 05:00 PM
I just got what Level 10 suggested. Definitely not trying to cut any corners on the build at this point. And since I got an upgraded torque converter they said it'd need about 11 qts.
lcvette's Avatar
lcvette lcvette is offline
Default 05-02-2015, 02:10 PM
Code DME for manual trans, fabricate Bell housing for 6l90 CTS-V A6, use gm ecm with emulated sensor input and have a proven 800+rwhp paddle shifted A6 designed for a heavier car... With tuning provisions.
Or grab a stand alone tcu TCM-2600 from PCS to control it. Either way this is likely the best solution. Brand new ctsv trans ~$3k would need machined flex plate, 6l90-n54 bell housing (6l90 uses a bolt on bell housing ftw, and the trans body dimensions are similar to the 6hp21 so should fit in tunnel without any fan fare), custom trans mount, drive shaft connection, figure out torque converter (aftermarket is readily available for this). And marry tcm-2600 controller to shifter and paddles. My guess is it would be a bit more than the level 10 after everything is said and done, but you now have full control for shift points and a proven power house of a transmission!
I'm investigating this currently. After I exhausted all other (my opinion) viable options for a reliable 6AT solution, I decided it would be easier not dealing with factory DME. It is too involved and it will take a long time for anyone to crack much less decipher the TCU/DME relationship and then it's going to be trial and error for a year or two before anything is finally sorted well enough to sell. Short of alpina coming out with a high boost upgraded hard parts and clutches flash option, I think this is a long way off.
If you do manage to burn up a 6l80/90, you can grab used ones for under a grand... Makes it worthwhile in my mind.
Chris
Car: 2008 135i
Default 05-03-2015, 12:52 AM
Chris
I wish someone would figure out an answer. Go for it!
After hearing about Terry's fully built transmission refusing to shift I just wanted to clarify something. So there's not any answer (transmission-wise) for a fast high horsepower N54 currently correct? Because no built 6HP21 solution is currently viable past 600whp, the manuals are slow and lose boost on shifts (I've heard NLS is a bad idea from very good sources), and there is currently no other option. So it seems like any N54 past 600 wheel is just a dyno queen and either slow on the street or only holds up for a (relatively) short time.
Midnitetuning's Avatar
Midnitetuning Midnitetuning is offline
Car: 07 e90 335i
Default 05-03-2015, 08:25 PM
We are working on a th400 swap on our 335i n54
lcvette's Avatar
Default 05-03-2015, 09:24 PM
That's awesome for a track setup, I am guessing it's a drag only car? I couldn't imagine a th400 on a daily driven car. I had one in an old truck many moons ago and while it did great driving locally in 45mph areas, over that and the engine was screaming... Forget about an interstate.... Lol...
robc1976's Avatar
Car: 2007 335i
Default 05-04-2015, 09:14 AM
if that is the case I Will defiantly be switching platforms. GTR or Porsche more than likely.
Stucks Stucks is offline
Default 05-04-2015, 09:52 AM
isnt that what happens to all the supra guys that use them? lol
Current: 2008 e92 335i coupe.
135pats 135pats is offline
Default 05-04-2015, 11:15 AM
This thread is making me sad
But yes, right now the N54 is an expensive, high-ceiling, dyno queen. The 6AT eats it north of 600WHP or so (I'm too scared to try anything north of 23 pounds), the 6MT bogs, and the Dual Clutch is an unknown unless you throw $$$$$ at it.
It should be noted the 2J was in the exact same spot for far longer. The only platforms which go ham at the strip right away are Domestic big cubes, built GTRs, and built P Cars. Most of the German and JDM stuff takes a long time to get right.
The motor is ready, rest of the platform just isn't there yet. Such is life when we're the pioneers
