BoostAddict BoostAddict is offline
Car: e46 323i/ 04.5 Turbo 350Z
Default 10-01-2014, 10:33 AM
I think the photo (Installed) depicts the holes being much closer than they really are. I've tested on an '07 6mt, '08 6mt, '09 6at, and '11 DCT. I'm not really sure which years correspond to the different differentials. The only differences I've seen are some of the early cars have some plastics covering the subframe. The brace easily slides under it.
The area is much tighter than the photo you posted portrays.
EDIT: Just Went outside and looked under my car. Those holes are in a different spot. do you know what car that was a photo of?
www.BoostAddictions.com
Custom Engine Calibrations and Performance Parts
996 Turbo
Default 10-01-2014, 10:49 AM
For the 135 guys, I'm pretty sure the fitment is the same as for 335i. I'm trying to find somebody local so I can confirm. I'll let you guys know when I'm 100%.
996 Turbo
Car: 09 E92 335i
Default 10-01-2014, 10:59 AM
Looks like the kit should work with the either pumpkins if it fits on both 07 MT and 09 AT (mine is an 09 AT).
I took that picture from Rob's car (https://www.bmwcca.org/forum/index.p...down-diy.9869/), which is an 07 E90, so it might be an early model thing. I will confirm tonight and see where are the holes located on the later models (mine was built in Nov. 08 as a early MY09).
Btw, what was the built date on your car?
Default 10-01-2014, 11:07 AM
My car is a 10/07 build. The '07 I checked was a '06 build I believe, but was a 6mt e92.
I appreciate your help with this. I would have never known there was any difference. Hopefully we can isolate the models with the different holes. I certainly don't want anybody to have a surprise when they go to mount it.
996 Turbo
Default 10-01-2014, 05:35 PM
I'll update the first post with this info as well, but for anybody interested in ordering, please confirm that the subframe hole locations are in the same position as marked in red below.
996 Turbo
Car: 09 E92 335i
Default 10-01-2014, 09:42 PM
Yeah, mine is at the same place as yours. There really isn't another part number for the rear subframe either, either. No idea why the holes are different on supposedly the same subframe.
A quick search on google image reveals some cars doesn't even have holes on the subframe.
Anyway, good kit nonetheless, will probably save me breaking an axle going over the stripped curbs on road courses. Any noticeable increase of NVH? Guess it doesn't really matter since you can just remove the brace after a track day anyway.
Will be placing an order once we get to see the installation video.
Default 10-02-2014, 10:38 AM
Thanks, for checking. Luckily it seems that most cars that do have the holes, have them in the location I designed them for.
I didn't really notice an increase in NVH. That's coming from somebody super picky when it comes to mounts and NVH levels. It pretty much just feels like a tight suspension setup.
996 Turbo
Bme30's Avatar
Bme30 Bme30 is offline
Car: 07 335i 6 speed
Default 10-02-2014, 11:51 AM
Look for the install video this weekend. Will be buying mine and making a video with boost addictions!!!
Whosdady Whosdady is offline
Car: 2007 335i Coupe
Default 10-02-2014, 02:01 PM
I would be interested if it worked with the vac machined LSD cover...
davidwarren davidwarren is offline
Car: 2010 335i 2006 325i 2001 325i
Default 10-02-2014, 02:02 PM
does this eliminate wheel hop?
robc1976's Avatar
robc1976 robc1976 is offline
Car: 2007 335i
Default 10-02-2014, 07:03 PM
See this image.
Lol! My pic
robc1976's Avatar
Car: 2007 335i
Default 10-02-2014, 07:04 PM
I was just about to text you!
Nugs Nugs is offline
Car: 2011 135i
Default 10-03-2014, 12:18 AM
Great idea, much better price and simpler installation than the DEFIV kit.
Looks like it will work with DCT 135i.
This is my subframe
Default 10-03-2014, 07:46 AM
Unfortunately it won't. The heat sinks are in the way.
Yes 99% of the time. IRS just inherently likes to hop due to it's design. This is the simplest solution without getting crazy and designing a lower control similar to what would see on a Mustang.
This is my subframe
Sweet!
996 Turbo
Bme30's Avatar
Default 10-03-2014, 12:50 PM
http://youtu.be/P1Kwq3p7OzI
Bme30's Avatar
Default 10-03-2014, 12:51 PM
Install video posted!!
Car: 09 E92 335i
Default 10-03-2014, 01:30 PM
Sweet, probably gonna be easiest thing to install out of all the things I have done to the damn car over the year. Order placed!
Default 10-03-2014, 02:27 PM
Thanks for the Order! Let me know if you have any questions. Just be patient lining up the whole on the bottom of the diff. At first it may seem like they don't lie up, but the will. Start the driver side diff cover bolt first. Seems to seat better that way.
996 Turbo
Default 10-03-2014, 02:35 PM
In regards to the diff holes. I had to 07's come today, one being BME30. The holes were in the alternate location on both vehicles. I'm gonna say this is a '07 thing. The good news is the subframe is easy to drill through. I used a 1/2" bit for the holes. It took barely any time to get the holes lined up, and drilled. you can see the holes in the first pic.
Also big shout out to BME30 for helping me out with the video.
996 Turbo
Default 10-05-2014, 06:02 PM
2 braces were sent out to 135i owners, so we should have feedback soon.
Also, I signed up for a track day thursday, so I'll have feed back from how the brace is on a road course.
996 Turbo
Stucks Stucks is offline
Default 10-06-2014, 05:14 AM
Are these still available? I have feb 08 build 6at 335i.
Current: 2008 e92 335i coupe.
goldfz8's Avatar
goldfz8 goldfz8 is offline
Car: BMW 135, Yamaha fz8
Default 10-06-2014, 09:57 AM
Should be getting mine today . and ill be hitting up the track in two weeks reviews coming!!!
BMW 135
Default 10-06-2014, 11:45 AM
Yes, I have 4 left of this first batch. Sending you a pm as well.
BMW 135
Can't Wait!
996 Turbo
Bme30's Avatar
Default 10-06-2014, 01:08 PM
So just an update. After we made the video for boost addictions video for the diff brace we finally got around to fitting one on my car. Again I cannot stress how simple this install is!!! It took about 12 minutes from start to finish and that was from getting the car onto and of the ramps.
Initial driving impressions: The car absolutely drives so much better, the car actually feels like it has a proper LSD. The ride has been transformed for the better. The rear end doesn't feel as squishy......the lack of slop makes this car feel like it should have been from factory.
It reminds me of my old e30 days with my 410 limited slip, but with about 400 more hp This product is one of the best mods to date especially with all the added Hp.
here is a pic installed.
disclaimer********(just to be clear this is the temple/original brace that came off BuraQ's car as he wanted a new one because he is a snop lol !!! This is not the product that will be received. The shipped product will have an expoy coating and will be more finished and refined. Same overall outcome, just a more refined finished product!!)
Car: 09 E92 335i
Default 10-06-2014, 07:26 PM
Got mine today, quick shipping I have to say
Two small issues with mine. First off, my diff housing (the black painted part) has a casting seam running in the middle, so that is preventing the brace from seating correctly and aligning with the diff bolts. That seam needs to be grinded off. Have to get a shop to do that since I don't have grinder nor planning to run a grinder 5 inches away from my face.
Also, it seems like my diff sits a bit higher than the brace was designed. If the top of the brace has to sit flush against the subframe, the opening for attaching the diff cover is about 1/4 lower than it needs to be. Played around with aligning the thing, but can't seem to figure it out. Not sure how you guys did it or it is just my car.
