(#501)
K.Jameel K.Jameel is offline
Car: BMW E92 N54
Default 01-03-2018, 05:20 AM
Originally Posted by mp335
thanks which number? looks like there are 2, my car is 2009 not sure which one I can use. Also does anyone figured out D mode fix ?
ZB7615835
Or ZB7603537 that one i did not try it honesty but ZB7615835 work perfectly
BMW 335i '08 E92 N54, JB4 G5 IOS, BMS DCI, VRSF ***, BMS-Tial BOV Kit with Chargepipe, VRSF FMIC, BMS Meth Kit, JB4 MHD BEF, BMS PCV valve, BMS OCC. TCU Alpina_B3 Flash, .
abhishek abhishek is offline
Car: 2008 BMW 335i E90
Default Datatransmission to ECU disturbed - 03-29-2018, 11:11 PM
Attachment 72654
Originally Posted by trebila
Com port default is 1 and you must set advance com port latency to 1 in device manager. (very important).
I did this and I was able to get my transmission to work. My transmission was locked in P with transmission malfunction codes on dash and got a bunch of errors mainly "2021 Error Datatransmission to ECU disturbed" when I was flashing from Original Alpina B3 (ZB 7615835) to ZB 7603537 (New Alpina B3 Flash). Also tried to flash ZB 7601494 (US Sport Flash) and stock but didn't work. Disconnected battery > did not work. Finally did this latency change and it worked. Back to original Alpina for now. Too scared to try new alpina or us sport for now.
Thanks, Guys!
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 03-30-2018, 03:08 PM
Save the headache and the pain and use the XHP it's way better than the alpina, I flashed the XHP stage 2 over my alpina b3 flash and I love the shift points and the quick shifting... will never go back to alpina or stock
Default 03-30-2018, 06:12 PM
I have this car stock for last four years ever since I got it. What do you think about stage 3?
Jeffman's Avatar
Jeffman Jeffman is offline
Default 03-30-2018, 06:30 PM
I’ve been using xHP Stage 3 ever since it became available. Prior to that Alpina B3 for 5+ years ever since it became available. Stage 3 xHP absolutely superior. Love it!
2008 E90 335xi AT 67K MILES
MHD CUSTOM FLEXFUEL 24 PSI, N20 TMAP, FUEL-IT STG 2 LPFP, cPE CHARGE PIPE, HELIX IC, TIAL Q BOV WHITE SPRING, BMS DCI, BMS T-STAT DELETE, BMS HIGH AND MISHIMOTO LOW OCC, RB PCV, KW-V1 COILOVERS, APEX ARC-8, 235/265 MICHELIN PSS, xHP STAGE 3, SCOOPS, PR IGNITION
