mister_jp mister_jp is offline
Car: 335xi 2008 coupe 6spm
Default 09-16-2013, 04:17 PM
We probably need a fitting like female to female... I think
N54mike's Avatar
N54mike N54mike is offline
Car: grocery getter
Default 09-16-2013, 05:11 PM
One is for the bluetooth interface and the other is for usb otg. You can get otg cables for dirt cheap on amazon.
http://www.amazon.com/gp/aw/s/ref=is...prefix=usb+otg
Just make sure your phone is OTG compatible.
ReefSki ReefSki is offline
Car: '09 335i
Default 09-16-2013, 06:01 PM
Awesomesauce I just ordered 2! I have a samsung note 2...should be alright I believe? !
N54mike's Avatar
Car: grocery getter
Default 09-16-2013, 06:34 PM
Yep!
lbzkid101 lbzkid101 is offline
Default 09-16-2013, 06:45 PM
Just bought and tested both apps, I have a razr with bluetooth obd2 that use for tourque app, Couldnt get it to connect with BluBoost said i need to repair but it worked with tourque and was paired. Any help would be appreiciated
For the OTG i used my asus transformer tf101 android o/s tablet took a little trial and error but got it working . I found when i changed it to landscape it froze and i would have to unistall and reinstall to get to work again. Also where do the logs go i couldnt find them after i logged?? says something like rb/rb.csv???
N54mike's Avatar
Car: grocery getter
Default 09-16-2013, 07:03 PM
I got a crash report from your transformer and am pinpointing the origin now. You said it connected successfully after? Also, the logs are stored in /sdcard/BB/. I've been meaning to make that user adjustable.
I've also posted a new version with the USB host feature requirement removed so if you are sure your device has OTG support and it said it was incompatible before, try looking for it in the play store again in a few hours.
Ethan
Default 09-16-2013, 07:07 PM
Yes, i had to uninstall then re-install a few times, then i figured it was crashing when i changed to landscape. Also my tablet does not have an sdcard in it would it default some where else or not save??
Default 09-16-2013, 07:08 PM
FYI, this is going to be awesome!!!! looking forward to see the development of this
Default 09-16-2013, 07:21 PM
Found the csv files
Car: '09 335i
Default 09-17-2013, 09:52 AM
Can you check engine codes or modify any settings? Or is this strictly for reviewing on the fly data and data logging. .?
N54mike's Avatar
Car: grocery getter
Default 09-17-2013, 10:17 AM
Code reading and clearing is a planned add on for a future release.
skyguy's Avatar
skyguy skyguy is offline
Default 09-17-2013, 10:20 AM
so far just gauges and logs, but still a huge step forward from trying to use laptop while driving
N54mike's Avatar
Car: grocery getter
Default 09-17-2013, 02:55 PM
Posted version 1.1.0 to the play store.
- Added option to keep backlight bright
- Saved current view state
- Added option to change log directory
- Corrected some typos
Default 09-17-2013, 03:44 PM
Do you think it's working on bb10 ?
Or I have my tablet Asus tf700 but it's not a otg cable... if I use a Usb female tu Usb female and my cable should it work ?
tjobeid tjobeid is offline
Car: 07 335i coupe
Default 09-17-2013, 04:03 PM
Originally Posted by skyguy
Have my nexus 7 installed on its side, install is relatively permanent...
Thanks,
Sky
installed permanently where? pics?
N54mike's Avatar
Car: grocery getter
Default 09-17-2013, 04:04 PM
http://www.amazon.com/gp/aw/d/B008TO3PSS
Default 09-17-2013, 04:31 PM
Thanks man !
Your god !!!
TLO03 TLO03 is offline
Car: 535 XIT
Default 09-17-2013, 07:39 PM
Easy way to tell if you have otg capable phone..
N54mike's Avatar
Car: grocery getter
Default 09-17-2013, 09:21 PM
Install otg troubleshooter and see if you have otg host support.
https://play.google.com/store/apps/d...tgtroubshooter
Car: 535 XIT
Default 09-18-2013, 05:34 AM
Thank you for your contributions, I was asking for something like this years ago when I first started using the torque app..
skyguy's Avatar
Default 09-18-2013, 07:51 AM
Its not pretty, but the plan was to build it into a nav dash when I'm not too broke and busy...7-24v usb hub installed in ash tray is fully functional now, so that's a win.
N54mike's Avatar
Car: grocery getter
Default 09-18-2013, 11:19 AM
Nice install. How are you mounting it?
skyguy's Avatar
Default 09-18-2013, 01:11 PM
There was some trim cutting to get it as low as possible. The first trick was to open up the tablet, bend the usb port back 180 degrees, and glue the otg cord so the cable came out the back. Then cut some of the padding off the dash and made a hole for cables and clips. Notched that aluminum trim so the nexus screen was flush with trim on the bottom. Finally clipped a snap-on back cover to the dash and tacked it together with some hot glue.
I have a couple pictures of the nexus but none of cutting into the dash. If I did it again it'd come out a lot cleaner...
miksebik miksebik is offline
Default 09-19-2013, 02:47 PM
Hi, I have a Samsung S4, tried to connect.. but the connection is not established. I get a message about security problem. I am trying to solve this by installing "Security policy update".. but there seems to be a problem with connection to (samsung?) server.
Just for your info...
heartpumper77 heartpumper77 is offline
Default 09-20-2013, 06:12 PM
I have an Acer a500 with USB port built in, do I still need the otg adapter?
