(#326)
Default 12-17-2013, 03:07 PM
Originally Posted by brakthru
Hey Terry,
I attempted to pester Cobb today to see if your flashes could where we pened up. They told me you being a pro tuner already can create open maps for the end user to tweak. I told them you requested to have the maps open and they said it's nothing they need to do on their end. They did not elaborate on how the end user can open the apps. Forgive me in advance, im still trying to learn this stuff. Does that make sense what they are saying or is there miscommunication here. Thx.
Email them the map then and ask them how you can open it. The maps can be resaved in a format where we would need to enter the the serial number for each person who wanted to open it but it would not be practical from a time perspective.
Besides some of the functions we use on the n54 side are not in Cobb. The open flash is really the future as far as back end flashes go for the n54 and we've moved on. We will be doing Cobb maps for the n55 but nothing else for the n54.
Default 12-17-2013, 06:03 PM
Can you elaborate on this?
Default 12-17-2013, 06:08 PM
No reason to go in to great detail but a simple example is disabling 30FF and 29F2 codes, for example, so the JB4 can manage both in a way more conducive to higher horsepower levels.
brakthru brakthru is offline
Car: BMW 335i
Default 12-17-2013, 08:22 PM
[QUOTE=Terry @ BMS;289456]Email them the map then and ask them how you can open it. The maps can be resaved in a format where we would need to enter the the serial number for each person who wanted to open it but it would not be practical from a time perspective.
With that being said Terry, I'm moving on as well. Someone posted up BB flash drivers today. I will be giving this a try in the future. Thank you.
SneakyDeeky's Avatar
SneakyDeeky SneakyDeeky is offline
Car: 335i E90 6MT
Default 12-17-2013, 10:01 PM
Ok.
I got a little more info. As an Access tuner pro, tuners can make the flashes open for end user adjustment or lock them so no one can make changes. I was informed Terry you may be able to just open the flashes and re-save them in the open format or something like that. The end user can use the Access tuner race software to modify it to the parameters of the free BB flash tunes. Cobb is making it sound sooo simple. So tell me, what's the bad news or can this actually be done!
Terry Can you chime in on this. Thanks.
+1.
6MT | JB4 G5 | E60 | Walbro 392 | NGK 5992 | Spec2+ | ER Dual Oil Coolers | ER CP | Synapse BOV | ETS FMIC | 3.46 Wavetrac LSD
BMS DCI | AR *** | Magnaflow | BSH OCC | KW V1 | M3 Bits | Advan RS | Michelin PSS | LS3 AEs | P3 Boost Gauge | Dyno Results | COTM Pics
Default 12-18-2013, 04:28 PM
True story...I kind of figured this was what you were referring to, just wanted to confirm you guys hadn't come up with a table I hadn't discovered yet.
thanks
blown07's Avatar
blown07 blown07 is offline
Car: 335xi, 335i
Default 12-23-2013, 01:47 PM
Trying to decide if I should do the BMS backend flash on my daily winter driven 335xi. Car is JB4,50/50 Meth - 3 psi adder,FMI,intake, 94 pump gas. Questions are:
1. How much does this effect driveability/fuel mileage ?
2. Pump gas flash is best for my mods?
Just got the BT cable in case my battery dies so basically free at this point.
335i FBO,Meth,MHD,XHP3,LSD,GCLites 11.83@124.88
335xi FBO,Meth,MHD,XHP3,VTT stage1 11.38 1/4 - 7.30 1/8th - 3.35 0 to 60 @ 0C
MathR601's Avatar
MathR601 MathR601 is offline
Default 12-23-2013, 02:14 PM
If you have the cable already I don't see why you would not try, it's free!
JB4 G5 ISO, BMS DCI, 3" AR ***, E85, BMS OCC, BMS Spacers, ECS Blackout Kidney Grille.
blown07's Avatar
Car: 335xi, 335i
Default 12-23-2013, 05:08 PM
What is your experience with a backend flash?
MuNky6913's Avatar
MuNky6913 MuNky6913 is offline
Default 12-23-2013, 05:25 PM
Why not try it. See how it works for a tank of gas. You can always put your original back on if you don't like it for some reason.
2009 135i - Berk Tech. Race Axleback - Injen Short Ram Intake - BMS JB4 G5 ISO - CXRacing FMIC - ER Chargpipe - BMS Straight Down ***** - Walboro Inline Fuel Pump - Spec Stage 2+ Clutch - Spec SMFW - BMS Dual Meth Kit - BMS Backend Flash
brendan's Avatar
brendan brendan is offline
Brendan
Car: 335i 2007 6spdman
Default 12-23-2013, 08:27 PM
1. Drivability pretty much the same with a bit more torque down low. I get just under 500km around town. (using the pump backend flash via cobb)
2. I know nothing about meth.
blown07's Avatar
Car: 335xi, 335i
Default 12-24-2013, 08:09 PM
Okay thanks.
I'm having trouble dowloading the BB software. Says I don't have permission to access this page. I did recently signed up but it appears my account has been validated. Anyone else had this problem?
MuNky6913's Avatar
Default 12-24-2013, 08:57 PM
Okay thanks.
Read a page or two back. Something's wrong with the website. There are multiple ways to get it on this thread. Just look back a little bit.
Edit: I just saw terry posted that he updated the link in the first page of the free flash sticky. Try that.
blown07's Avatar
Car: 335xi, 335i
Default 12-25-2013, 04:06 PM
Okay thanks - I installed the race flash and it felt good. I will do some logs tomorrow. I am most interested to see what changes there are in the timing recovery post shift.
heartpumper77 heartpumper77 is offline
Default 08-03-2014, 05:27 AM
I don't know if this has ever been asked, I was just wondering why don't have a specific pump flash for automatics?
Grayforge Grayforge is offline
Car: 2008 E90 335xi
Default 02-18-2015, 10:24 AM
Old thread, but a question: The thread talks about using the COBB AP to load backend flashes. However, I also see it mentioned elsewhere to use the Bavarian Technic cable.
Same flashes, so the latter can now be used to do what the COBB was required to do earlier, right?
Speed Is Life
musc's Avatar
musc musc is offline
Car: 335is DCT
Default 02-18-2015, 10:29 AM
The Bav Tech cable flash will do everything the BMS Cobb flash would do. It is also not locked so you can make fine adjustments to it for your set up. There is a big thread dedicated to the BimmerBoost flash using the Bavarian Technic cable here
http://www.n54tech.com/forums/showthread.php?t=20563
335is DCT
Car: 2008 E90 335xi
Default 02-18-2015, 11:28 AM
Nice! I just came back to respond to my own question, having found that thread. :-)
Russ
Speed Is Life
Bullitt1841's Avatar
Default 02-18-2015, 11:51 AM
Each flash method has its own file type and loading tool. You cannot mix and match the Cobb and BimmerBoost stuff. But each method is virtually the same, with the exception of the Cobb taking less then 1 minute to change flash files, and not requiring a laptop.
laurean bmw 135i n54's Avatar
laurean bmw 135i n54 laurean bmw 135i n54 is offline
Car: bmw 135i n54
Default 05-02-2015, 01:23 PM
guys I have a question I'm loading the ijeos-race.bin files to a load pressure 1m but not the car someone has a problem ?? and JB4 values shown me all lockers 0.
when I made a backup of the original file .org keep me normal?
bmw 135 i m54 jb4 PT 6466 PT intercooler fsb meth
