(#326)
Rob@RBTurbo's Avatar
Stalker
Car: 335I
Default 08-27-2013, 10:24 AM
Originally Posted by illrider
What ever came out of this? I thought at one point Rob you had talked about designed a modified bucket to use other aftermarket pumps?
Has anyone tried any other inline pumps besides the Walbro GSL392?
My update is the same as last time. That is there was someone else working and/or almost done with a solution. They'd have to pipe up and say how it is going.
Rob
Default 08-27-2013, 02:40 PM
Can't comment on a drop in solution...I've gone a different direction.
Yes, I have a different inline option in place, although in my application the 255 would work fine as well.
Will be testing some other options in a couple weeks. Wanted to make sure my fuel system was stable and robust before proceeding.
aoschadlin's Avatar
aoschadlin aoschadlin is offline
Car: 535i
Default 08-27-2013, 05:14 PM
The 5er's seem to have a slightly different fuel system to the 1's and 3's.
I'm trialing a solution where we've added the fuel bucket from a v8 X5 into the driver side fuel tank and attached it downstream of the regulator.
Still tweaking it but it seems to be doing the job.
Cool stuff no longer installed.
07tundra's Avatar
07tundra 07tundra is offline
Car: a slow one
Default 02-23-2014, 03:53 AM
So Steve what ever happened to your ported fuel rail is it helping at all or?
Default 02-23-2014, 09:23 AM
I'm still running a ported rail. I need to do some more testing to say conclusively how much/if it really helps with a stock HPFP but have concentrated my efforts in other areas of the fuel system. I may revisit it in the near future but don't have any plans of doing much with it at this time.
Default 02-23-2014, 09:54 AM
Rob
I want this:
http://www.gtrlife.com/forums/topic/...-pump-install/
Just requires some sort of harness to strap the pumps to. Should be enough room in our bucket.
Default 02-23-2014, 09:55 AM
I have it on my car and it definitely stabilized pressure north of 5k rpms with E50 blend.
07tundra's Avatar
Car: a slow one
Default 02-23-2014, 03:18 PM
Now that I've gotten my life back together somewhat I will and making that adapter for the 455. So we can run it inline with our factory pump, so no disturbing the stock configuration and we could add the 455 full e85.
eurocentricllc.com's Avatar
eurocentricllc.com eurocentricllc.com is offline
Car: 2007 335i e92
Default rail upgrade - 02-05-2015, 07:24 PM
Sorry I know this is an old thread. Here is something I have been thinking of trying. My idea is to tee off the outlet of the hpfp going to the rail. The stock rail has the inlet on the front and nothing on the rear of the rail, meaning bank 1 would get more flow then bank 2. I want to attempt a tee from the hpfp outlet and have 1 hose go to the front of the rail and 1 hose go into the rear of the rail. I've noticed a lot of people complaining of cylinder 5 and 6 misfires which makes me wonder if its due to injectors 5 and 6 the last to get fuel. Also steve can you give me the final drill bit sizes you used on the rail and the hpfp. Going to attempt to bore everything out, add a inline pump next to the transmission (have a 450 intank), and add the tee and extra inlet to the rear of the rail.
Thanks,
Michael
Default 02-05-2015, 08:41 PM
Michael,
My advice:
1. Do not run a 255 inline with the 450 pump, the 450 maxes out the HPFP.
2. Do not run an inline pump without a regulator.
3. The rear of the rail has the "hpfp sensor".
4. The gains for drilling out the individual ports is minimal at best. IIRC, we did .0625" but it's currently sitting in a cabinet and we run a stock rail.
Frankly...while we had our ups and downs with all that testing, on a stock HPFP, there isn't much to be gained. We did it all and now run completely stock from the HPFP to the injectors.
BTW, you are working with 3000psi...make sure you plan accordingly.
If you do, good luck.
Steve
Car: 2007 335i e92
Default 02-05-2015, 08:47 PM
Thanks for the advice. May try adding a rear hose to the rail. I would have to tee the sensor in at the rear of the rail. I will be using cline hose and hydraulics here in greenville sc. They have the metal hoses I need to hold the 3000 psi. Would be interesting to see if adding a rear hose to the rail will help anything. I would think it would in theory.
Default 02-05-2015, 09:04 PM
I see where you're coming from...but also remember that those pressures readings at taken at the back of the rail where you plan on tee-ing in.
Car: 2007 335i e92
Default 02-05-2015, 09:25 PM
good point.
Default 02-05-2015, 10:03 PM
Sorry...but at the time of this thread, everything was new to us. Since that time we have dissected the HPFP and done virtually everything we could...with minimal gains and maybe a little bit better response. However, mostly what we found was that the bellows in the HPFP simply bottom out, and if your pressures and supply are sufficient (>50psi) there isn't much else we can do.
Not to discourage you, because I can understand wanting to try it for yourself.
Car: 2007 335i e92
Default 02-05-2015, 10:12 PM
I understand and thanks for all the advice. Think i do need to add a second 450 in tank. I hit 603 whp with my 6266 top mount and my lpfp which has never been a problem before is now getting into the low 50s.
Default 02-05-2015, 10:59 PM
What are your cars specs? Running meth or race gas?
Car: 2007 335i e92
Default 02-06-2015, 04:35 AM
E30/e40 mix of e85/93. 6266 top mount, meth with cm7, cm10, and a port meth setup with 3 gph nozzles.
