e92life e92life is offline
Car: e92 335i
Default 335i Log review - limp mode no codes? - 07-06-2019, 12:02 AM
335is 6MT, FBO + Inlets, CP + ebay BOV, 7.5" VRSF Stepped Competition MHD + JB4 PUMP BEF
I'm not sure what's going on but sometimes when I really get on it in map 2 my boost will get completely cut off and I get into limp mode with NO codes/no CEL and then I "clear codes" and my boost comes back. Not sure whats going on. Here's some logs what do you guys think?
In the log "Boostleakmap2" is where my boost cuts off so thats where the issue is. The other 2 are logs I did before that pull and after that pull. Ignore the title "boostleak" i just named that cause its the first thing that popped in my head when i wanted to rename it lol. Not sure if thats it or not.
Car also feels sluggish for some reason... On another note why does MHD Stage 2 + target 19lbs and MHD + JB4 target 17? I have 3 friends and they all seem to reach 19lbs of boost on a flash only tune.
Car: e92 335i
Default 07-06-2019, 07:39 PM
Here's another log where my boost got cut off...
Car: 2008 E93
Default 07-06-2019, 11:03 PM
Your timing is sh1t. Get better fuel.
Car: e92 335i
Default 07-06-2019, 11:18 PM
Is that the reason why itís feeling sluggish/went into limp mode with no codes?
Default 07-07-2019, 08:37 AM
You sure you aren’t storing any codes?
Hpfp tanks up top - and your trims max...
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: e92 335i
Default 07-07-2019, 10:02 AM
Thanks for the response, nope no codes stored I read them and nothing comes up.. but when I go in and erase codes my boost comes back. Should I reflash the PUMP bef/reinstall the JB4 app? Because itís not like I even get kicked to map 4? It stays on the same map regardless if boost gets cut.
Should I also go ahead and reset adaptions? Iím going to post my settings just in case to see if you think anything is off.
I know the auto clear is gone from JB4 so not sure whatís going on..
You sure you arenít storing any codes?
Default 07-07-2019, 01:22 PM
Just for the sake of it..
Reflash eveything & ensure JB4 is set to 4/2 on the tach
Log map 1 after
e92 AT 335xi 2.0
Doc Race Kit 6062
