codesx's Avatar
codesx codesx is offline
Default Codes 2E8B, 2DEB, Open to thoughts - 07-05-2019, 09:53 AM
Hi all,
The last couple days have been hotter here at approx 90f.
Also, for two days now (never prior) I'm getting the following codes;
2E8B Intelligent battery sensory, signal (yesterday and today)
2DEB Power management, vehicle wiring system control (today)
After clearing, they return.
Car appears to fun fine, with no impact to anything I can perceive.
I'm focused on the IBS or battery itself.
I suggest IBS as I've had the battery cover off for some time as I was playing with Injectors, etc. (removing negative)
The car always turns over fast, even if it takes a while (leaking injectors at times). Still, all research suggests the battery can still become problematic prior to showing personal symptoms or showing as bad during a capacity test.
Some information even suggests the DME is too hot, however I find 90f dubious in this regard.
I'm very open to your collective thoughts!
Thanks as always!
RB: Inlets | PCV Valve
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
THE BEAST's Avatar
Car: 2008 E93
Default 07-05-2019, 03:58 PM
I vote for IBS.
I have had low battery warnings on a bad battery, but never those codes so.....
Default 07-06-2019, 02:18 PM
Id assume IBS too
codesx's Avatar
Default 07-09-2019, 09:34 AM
Thanks. I've reset all related connectors and it hasn't come back for 2+ days now.
Will keep an eye. If it happens again, I'll start with the IBS and report back.
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
Default 07-09-2019, 09:11 PM
Fingers crossed!
Enjoy your week
