BIMMIN BIMMIN is offline
Car: 2009 335i AT
Default Have an interesting issue with a 30ff code - 06-25-2019, 04:44 AM
So my car is in sig. I never get the 30ff code when I floor the car, it's only when I have it in a high gear, like 5th or 6th and I give moderate throttle but not enough to make the trans drop down a gear.
I'll watch the boost in my app when this happens, most it will go up to is around 2psi.
Is this just normal? I always run the trans in sport mode. Rarely manual shift.
2009 E92 335i AT
Engine
Rev9 Hybrid 16t twins, Injen cyborg intake, CP-e charge pipe with HKS SSqv BOV, RB external PCV catch can, BMS catch can, Cobb intercooler, HKS Legamax exhaust, RB inlets, VTT single barrel hpfp, fuel-it! stage 2 lpfp, MOTiV Flex fuel flash only w/ trans tune by Cedar Performance
558rwhp and 523rwtq on e60 110* ambient air
Dave @ BMS/Fuel-It! Dave @ BMS/Fuel-It! is online now
Default 06-25-2019, 01:15 PM
Can you capture via log?
Car: 2009 335i AT
Default 06-25-2019, 01:43 PM
I will have to get a log next time I'm in the car.
I remembered, it will do it in 2 thru 6 gear.
2009 E92 335i AT
Engine
Car: 2009 335i AT
Default 07-07-2019, 12:04 PM
Here is my part throttle underboost.
It's super weird. There is a boost target of zero wastegate stuck at 27 pedal % goes up to 55% with nothing
2009 E92 335i AT
Engine
Default 07-07-2019, 01:23 PM
What are your menu 10/12 set at?
Car: 2009 335i AT
Default 07-07-2019, 02:34 PM
Default wastegate pos. = 80
PID gain = 25
Wastegate adaptation= 150
Auto shift boost redux = 20
2009 E92 335i AT
Engine
Car: 2009 335i AT
Default 07-09-2019, 08:11 AM
Bump
My app is setup and worded a bit different. So I hope those were the values you wanted
2009 E92 335i AT
Engine
Default 07-09-2019, 09:18 PM
Bump
I saw you chimed in here: JB4 menus 10, 11, and 12 for dummies - Page 4 - N54Tech.com - International Turbo Racing Discussion
Set your 10-12 menus to default & adjust from there
Car: 2009 335i AT
Default 07-10-2019, 04:40 AM
So I know I chimed in and thought I understood. That whole article is about the steering wheel controls
What are the names of menu 10 11 and 12 in the jb4 app?
The values are not listed by rpm either.
2009 E92 335i AT
Engine
