Fredm21 Fredm21 is offline
Car: Bmw 335i 2007 N54
Default Precision Raceworks install, tranny issue - 05-29-2019, 04:07 AM
Yesterday I installed my new precision raceworks coil system. I am not sure if it has anything to do with this but since I am having issue with my tranny. I clicked the PR coil in the MHD app running JB4 MAP3. At high rpm my tranny is shifting 2 speed instead of only shifting one then shifts back down causing a big lag and bad feeling. I added a LOG in case it could help.
By the way I will be replacing tranny pan with oil filter and oil, also will install my BMS tranny cooler at the same time Friday.
Thank you for your time
-07 335i coupe
BMS charge pipe
Turbosmart BOV
VRSF down pipe
BMS WMI with single nozzle ( 10 )
JB4 map 3 w/bluetooth & antiliag
Afe intake filter
BMS intercooler
BMS tranny cooler
BMS Double baffle catch can
MHD BEF Racegas
Precision Raceworks Coil
-Running 91 octane with WMI
Default 05-30-2019, 08:59 AM
Any trans codes?
Coils won’t mess with the trans...
Default 05-31-2019, 11:58 AM
Any trans codes?
Coils wonít mess with the trans...
I just changed the tranny oil with new filter, also new mechatronic seal and I still have the same problem with these error message. Thank you
CD99
CD9E
CD9D
2E7F
CDB0
-07 335i coupe
BMS charge pipe
Turbosmart BOV
VRSF down pipe
Afe intake filter
BMS intercooler
BMS tranny cooler
MHD BEF Racegas
Default 06-01-2019, 01:37 PM
CD99
CD9E
CD9D
2E7F
CDB0
can you post or list the descriptions too? Thanks!
How did the tranny oil look?
Default 06-02-2019, 04:24 AM
Oil was thin, dark and quite a bit of metal on the magnets. Didnít look so good. I will replace valvebody monday I think. The error message are all saying no description except 2E7F : egs at a- and fa-can
Thanks bud!
-07 335i coupe
BMS charge pipe
Turbosmart BOV
VRSF down pipe
Afe intake filter
BMS intercooler
BMS tranny cooler
MHD BEF Racegas
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 06-02-2019, 09:06 AM
Not sure about the errors but if you have metal gum on the magnet and it's dark mostly your clutches and friction are done, save yourself the time, get the sonax zap kit to rebuild the valve body, get the raybestos clutch pack for all drums, get the bushing and rubber gaskets for the drums and rebuild the full trans and let your trans get as new, costed me in parts around 400-450$ now I dont almost 10k and not a single issue pushing 22 psi .
Before I had slipping clutch E and 5th gear slip and shutter on hard acceleration and gear used to shift down to 3rd and gove the trans error,
Default 06-03-2019, 12:12 AM
Thanks bud!
Did u swap it all out?
I know depending on condition- flushing All can actually lead to worse performance / Trans acting worse
Default 07-14-2019, 05:26 AM
Hey Guys, after spending several hours and amount of money to find the issue in the car I taught it would be great to let people know how I solved my tranny feeling doing hickup after shifting and going on neutral out of nowhere.
Before I say what was the issue let me tell you guys what I replaced!
I started with tranny oil change, seals, oil pan and sleeve which didnít help
Then whole tranny
Battery
Alternator
Cps sensor
New mechatronic
Another valvebody
Programming whole car, special thanks at Tony from codewerx
Replaced for another tranny again.
And to find out the guilty was: precision raceworks coils!
It was kicking out my egs communication somehow! Btw I donít want people to think or have bad opinion about them! They are good, pr is helping me now with it! Im just a guy not being lucky and running **** luck with this car. We will try to find out why it was doing this and let you know. Still got error 2ad0 but no issue at all! Canít wait to get back on the track with the pr coils!
-07 335i coupe
BMS charge pipe
Turbosmart BOV
VRSF down pipe
Afe intake filter
BMS intercooler
BMS tranny cooler
MHD BEF Racegas
Default 07-14-2019, 01:41 PM
Then whole tranny
Battery
Alternator
Cps sensor
New mechatronic
Another valvebody
Glad you got to the root of the problem.
Hopefully youíll be up & running issue free soon!
THE BEAST's Avatar
Car: 2008 E93
Default 07-14-2019, 05:27 PM
Thats crazy ! Never heard of that. Thanks for posting all the troubleshooting you went through.
