(#1376)
AGO 530's Avatar
AGO 530 AGO 530 is offline
Car: 11' N55 E90
Default 11-19-2014, 06:20 AM
Hey guys
Maybe itís just me, but did we lose the ability to toggle on/off the stealth gauge mode (5/6) with ISO_5_5? Also seems like the DTC push at startup on/off is not working (5/5).
'11 E90 MSport / BMS : JB4 - Stage 2 ISO, ********, Intake, OCC, Low Temperature Thermostat / ETS 5" FMIC / Evolution Racewerks CP / Swift R-Spec Springs on Koni Yellow's.
NickDHdfc NickDHdfc is offline
Car: 2011 135i
Default 11-19-2014, 10:13 AM
Stealth gauge mode does not work for me either, mine weirdly jumps from (5/6) to menu 8 after trying to apply (5/6)
2011 e82 n55 135i
Jb4 ISO w/ FF Wires
BMS Intake
ETS Chargepipe
********* DP
Berk Race Exhaust
AGO 530's Avatar
Car: 11' N55 E90
Default 11-19-2014, 11:52 AM
Thanks for the confirmation;
Iíve noticed that the JB4 retained my previous setting when updating to ISO_5_5. I canít turn off the start in DTC option. When I make selections in the higher menu options, the needles appear to be stuck and pressing the left down button (volume -) the speedo needle doesnít move like normal to exit. Then I need to recalibrate the needles as they are all over the place and re-set for Metric setup.
discreet_335i discreet_335i is offline
Car: 2011 335i
Default 11-20-2014, 07:06 PM
This happens to me too.
Mods - DP, FMIC, JB4, and INTAKE.
Nugs Nugs is offline
Car: 2011 135i
Default 11-20-2014, 11:45 PM
Is there any chance that timing for all cylinders and load will become loggable?
AGO 530's Avatar
Car: 11' N55 E90
Default N55 ISO E Series Steering wheel guide - 11-24-2014, 10:23 AM
A little love for the N55ís, Iíve updated the steering wheel guide for the N55 ISO post ISO_5_5
Car: 2011 135i
Default 11-24-2014, 05:21 PM
found answer..
2011 e82 n55 135i
Jb4 ISO w/ FF Wires
BMS Intake
ETS Chargepipe
********* DP
Berk Race Exhaust
BostonShant's Avatar
BostonShant BostonShant is offline
Default 12-08-2014, 10:42 PM
Where do I get the most recent firmware?
2011 135i - N55 - JB4 ISO - FBO + Meth + Corn
VTT JB Stage 2 with VTT Forge DV and VTT N55 Waste Gate Upgrade
Pump Gas
60' ... 1.850
1/8 MPH ... 98.06
1/4 ... 11.735
Trap ... 122.71
Car: 2011 135i
Default 12-08-2014, 11:07 PM
http://www.n54tech.com/forums/showpo...30&postcount=1
Default 12-09-2014, 01:03 AM
Wow lol can't believe I missed that. Thanks dude!
Pump Gas
60' ... 1.850
1/8 MPH ... 98.06
1/4 ... 11.735
Trap ... 122.71
alexc93 alexc93 is offline
Car: 6mt N55 135i
Default 12-11-2014, 07:47 AM
Is a backend flash required to run E85 with JB4? Or can I stay on map 5? I assume the car would auto tune once flex-fuel wires are added
2014 M235i Black Sapphire Metallic / Black Dakota Leather
|| 30% Llumar CTX || IND Painted Front Reflectors || BMW Performance Grilles || Lightweight Front Lip || BMS Exhaust Tips || JB4 || ER Charge Pipe || MPI DP ||
Car: 2011 335i
Default 12-11-2014, 05:48 PM
Not required to run if the mixture isn't heavy. I do 50/50 mix with the FF wires. I've done 60/40 with no issues but over that I don't know what would happen.
Default 12-11-2014, 09:04 PM
No, back end flash is not required for the stock N55 turbo. Only for larger turbos does it become necessary.
Car: 2011 135i
Default 12-14-2014, 07:45 PM
Is this in the pipeline for N55s?
Default 12-26-2014, 10:07 AM
Read the codes and post them in the support section.
DVAPower DVAPower is offline
Car: E93 N55
Default 12-31-2014, 03:30 AM
I am just reviewing the settings in my JB4 (ISO, no E85 or Meth, no FF wires) which is running map 5. Does the screenshot on page one of this thread just below the steering wheel controls table represent the recommended settings?
Dave
houtan houtan is offline
Default 01-08-2015, 09:54 AM
Thanks for updating this guide.
Newguy123's Avatar
Car: 12' 135i
Default 01-09-2015, 07:00 PM
Hey quick question. If I was previously running the backend flash and now I am not. s2jb4 FF ISO only now controlling everything should I change my "all map AFR " settings back? I forgot to do so and they are all 0's. cps is set at 35 if I remember correctly. I see on here it's 10-40 with cow 0. Logs look fine just wondering about these settings and if they matter. Thanks in advance
18í Glacier white RS3
#PURETURBOS
#FUELIT
Default 01-09-2015, 09:27 PM
Those settings are not used with the N55 so it doesn't matter.
beast135i beast135i is offline
Car: 2011 bmw 135i n55
Default 02-06-2015, 03:00 PM
About to go ISO on my 2011 n55 135, just wanted to ask if there is any update past 5.5.?
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 02-19-2015, 03:19 PM
I don't see the stealth gauge option on this guide. I am having a hard time turning off this feature for full time gauge hijacking. Any help??
2011 E92 335i Auto Sold
12.0 @ 125MPH JB4
Default 02-19-2015, 04:34 PM
It's on there. Hint, it starts with a 4
Car: 2011 e92 335i
Default 02-20-2015, 11:47 AM
Wow I don't know how I missed that. I looked at it 3 times before posting. Thanks for looking out.
12.0 @ 125MPH JB4
Default 03-13-2015, 01:45 PM
Hey guys, quick question when you go ISO is there still a top speed limiter on the car?
e46m3to335i's Avatar
e46m3to335i e46m3to335i is offline
Car: 2015 F22 M235i
Default 03-13-2015, 02:12 PM
Yes. There is no speed de-limiter for the N55 yet..........Us N55 guys are still stuck at 155mph until someone creates one.
2014 335i xDrive / Silver / ZF8 / M-Sport / 400M / BM3 2H Map / xHP Stage 3 / ATM FMIC / H&R Sports / VRSF **/CP
