(#426)
Obviously Obviously is offline
Car: 2017 Audi S3 Sportback
Default 07-13-2019, 09:32 AM
No, the issue is when using LC and just after the gearshift there is a pause, hesitation type and then pull the rest of the gear normal. This happens in all the gears but only when using LC as it shifts to a different map on the ECU.
Thanks. No problem like that at all George. My car pulls cleanly through all the gears post launch. 👍🏽
joneze93tsi joneze93tsi is offline
Car: MK7 GTI
Default 07-15-2019, 11:42 AM
To clarify, the "new" Map4 which is 7spd specific, can also be used on the 6spd DSG cars without issues as it merely tapers boost and would be fine for cars in hot climates?
Or did I misread that completely?
FeldiSan FeldiSan is offline
Car: VW Golf 7 R
Default 07-15-2019, 09:05 PM
Picked up a issue on some cars with map 5. Attached updated firmware.
Hello,
What issues was that?
Default 07-16-2019, 03:48 AM
Originally Posted by FeldiSan
Hello,
The boost target values in the firmware where not spot on.
Yes, it can be used on any car. 93 is recommended.
z19930612 z19930612 is offline
Car: 1M&GTI
Default 07-16-2019, 08:27 AM
Hi George, Does the new update has the Future use D to eliminate cars with no meow meow?
Default 07-16-2019, 08:59 AM
Only outside the US.
Car: VW Golf 7 R
Default 07-16-2019, 07:57 PM
Hello,
They are too high? I have in the 4th gear 27 psi that is the problem of what you speak?
They talk in Map 5 from 25 to 20 psi. The log is otherwise clean. In 3rd gear is a littlebit timing reduce from 1,8 degreese. This was are the 1rst full pull with the new firmware, I think the ecu adapting this at the next pull and there are clean.
Best regards
TSI 1.8T Jasper's Avatar
TSI 1.8T Jasper TSI 1.8T Jasper is offline
Car: 2018 mk7.5 1.8T m/t
Default 07-16-2019, 08:38 PM
We have been testing the new version of software on around 30 cars and all seems to be good. Would be nice to get a bigger pool now.
Firmware version is 60/85//5
Changes are as follows:
Map 3 Peak boost 6psi
Map 4 Peak boost 6psi 7speed DSG specific, it has a taper at higher rpm so will also work well for guys on 93 in hot climates
Map 5 Absolute map peaking 25 tapers to 20psi. E30 with bolt ons needed
Map 8 Safety Valet map
Other improvements are on idle and boost onset.
OBD disconnected yield 0 boost add.
Let me know your thoughts.
Question , I'm on map2 93 octane and just so is ur update now any benefits to last firmware also I would say my hiccups are basically gone after doing about 1k since last update
Default 07-17-2019, 03:14 AM
Hello,
Best regards
Best to update. The original where flat lining 27psi demand. New version is sorted now.
Default 07-17-2019, 03:15 AM
Not sure what you are on but its worth updating this one.
Default 07-17-2019, 04:16 AM
Ok thanks will update today after work , I'm on firmware 8.4 hex the one u posted two weeks ago to help with ideal
Default 07-17-2019, 03:13 PM
just did my update , will keep you posted ...thanks
madspeed madspeed is offline
Car: Audi S3
Default 07-17-2019, 06:41 PM
Damn government
JuanFranCupra JuanFranCupra is offline
Car: Seat Leon Cupra 2019
Default 07-19-2019, 09:07 AM
Hello George,
I just tried map 4 of the new firmware in my leon cupra 2019.
The car feels a little faster than in map2
Can I use it with 98 octane gasoline with stock exhaust system?
Default 07-19-2019, 09:51 AM
Originally Posted by JuanFranCupra
Hello George,
Yes, its fine to use. It runs 6psi additive till 5500 and then bleeds out the boost add till 7000.
Default 07-19-2019, 10:50 AM
That means that from 5500 rpm to 7000 rpm there is no increase in psi over stock?
Dysfunctional Dysfunctional is offline
Car: Mk7 golf r
Default 07-19-2019, 03:02 PM
I have a mk7 golf r. I updated to the latest firmware this morning. It said complete but when I tried to start the car it would only run for a moment. Tried to flash back to old firmware but now it won't connect. I use the data cable with OTG adapter. Just says serial failure when trying to connect on the app. Luckily I'm able to unplug the OBD cable and the car runs fine. I've flashed firmware numerous times and never had an issue. Tried to do the disaster recovery but it simply won't connect. Did I brick it? Tried
Default 07-19-2019, 03:20 PM
Generally the disaster recovery always works. Did you try the steps correctly? Had I ever sent you the process? Drop me a email George@burgertuning.com and we can work it out. On bricked units we can get another master chip out to you that costs $25 and will get you up to speed again.
Default 07-19-2019, 03:44 PM
It still adds boost. Its a additive map and the top looks like this.
5500 6
6000 4
6500 2
7000 2
Car: Mk7 golf r
Default 07-19-2019, 04:54 PM
Thanks for the quick reply.. Emailed you!
jagger230 jagger230 is offline
Car: Volkswagen GOLF R
Default 07-22-2019, 10:16 AM
hey george, i tried sending you emails for logs and never heard back from you. i am sorry i just wanna make sure the logs look good and at the same time im not harming my car, thanks
Jagger
Default 07-22-2019, 01:16 PM
Jagger
When you don't hear from me especially on a Sunday and are unsure of the map you using rather go back to the map 6 that has been set for the car until you do. Will get to the emails but there is a cue.
Default 07-22-2019, 01:21 PM
my sincere apologies george was just a bit worried..... once again very sorry
Default 07-23-2019, 08:38 AM
5500 6
6000 4
6500 2
7000 2
So, with which map do you get more power? With map 2 or with map 4?
I get the feeling that map 4 is more aggressive especially in the middle zone
Thanks, George
