SwinJB4 SwinJB4 is offline
Car: 2006 E92 335i
Default Map 5 switched to Map 4 log attached - 07-14-2019, 03:54 PM
is anyone able to look at the attached log and see if you can tell me why my JB4 put me in to map 4 from map 5?
Car: 2008 E93
Default 07-14-2019, 05:23 PM
Over boost
Car: 2006 E92 335i
Default 07-15-2019, 07:11 AM
Over boost
Ordered 2 new solenoids as this seems to be the cheapest potential solution if not then I guess it's a good opportunity to look at hybrids? is there any other cheap solution I should be looking at?
Default 07-15-2019, 12:30 PM
Could look into solenoids, but i don't think your turbos are shot by any means...
You just overboosted / hit the safety set.
enable 6cyl logging
Set DB to 0 across board for now
relog
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: 2006 E92 335i
Default 07-16-2019, 02:34 AM
enable 6cyl logging
relog
I will look to do this and get some more logs, but I've got some more logs that where I've noticed the Boost Target is doing something odd and seemingly holding a pressure even when I've backed off the throttle.
