joeybutts joeybutts is offline
Car: '07 e90 335i
Default meth issues discovered while tuning BEF - 07-12-2019, 05:41 AM
Hey gang, having a slow/inadequate meth flow while trying to tune a Trebila BEF.
It's flowing but according to Dave there is an issue somewhere. My current meth setup utilizes the windshield washer tank as the reservoir (I know.....I know....), is tee'd off the washer nozzle lines, runs over to the Aqua Mist pump, through the other thing(name is slipping my mind) and then goes to a tee that leads to the dual CM7 nozzles in a Stett Charge pipe.
I keep getting air in the line between the nozzles and solenoid, but it appears that the line from the reservoir is primed. I replaced the windshield washer pump approx 2yrs ago as well as the nozzles.
Am I missing something? Can't think of anything else other than something clogging.
Default 07-12-2019, 09:54 AM
Got any logs so we can check it out? Air between nozzle and solenoid is okay. Just make sure it's a short distance between the two.
Car: '07 e90 335i
Default 07-12-2019, 10:56 AM
Dave said my run is way too long, which makes sense, I’m gonna shorten it.
Here is my last decent log....
Car: '07 e90 335i
Default 07-12-2019, 10:58 AM
Log
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 07-13-2019, 03:28 AM
Thought meth scale default should be 60 while yours at 45?!
Car: '07 e90 335i
Default 07-13-2019, 03:49 AM
Instructed by Trebila to do so.....
Default 07-13-2019, 08:30 AM
Rarely do I / we like to step on a tuners toes - what does your tuner say?
Car: '07 e90 335i
Default 07-13-2019, 09:04 AM
I've done nothing without Dave's input, I'm fairly ignorant to tuning. He stated there was an issue and to make the changes I have stated.
I'm going to shorten up the feed line to the nozzles. I guess maybe I need to look at the tank and the main lines?
Car: '07 e90 335i
Default 07-14-2019, 09:07 AM
So I went out and did some runs today, and in doing them I pulled my squirts while WOT, and boom, no issues, 100% flow.
So, guess I need to go dedicated tank? Even so, do you think I need to replace the pump?
Default 07-14-2019, 01:38 PM
Wouldnít change too much all at once- Iíd get a dedicated tank tho for sure
Car: '07 e90 335i
Default 07-14-2019, 03:56 PM
Dave, no joke, no issues if I pull the squirts.
Possible the pump is dying? Or not strong enough to pull through the WW pump?
Any recommendations on what to buy to easily retrofit?
Default 07-15-2019, 12:47 PM
hmm- i wouldn't rule anything out. How old is the pump? I guess replace?
Car: '07 e90 335i
Default 07-15-2019, 12:59 PM
Well, Dave insists the pump trying to pull from washer tank through pump is issue and I’ve been wanting to relocate anyway, so going to install tank and run line. If it isn’t that, then pump.
What tank would you recommend for in trunk behind driver rear tire?
Default 07-15-2019, 03:28 PM
Well, Dave insists the pump trying to pull from washer tank through pump is issue and Iíve been wanting to relocate anyway, so going to install tank and run line. If it isnít that, then pump.
im partial tho : )
methanol Burger Motorsports, Inc.
blown07's Avatar
blown07 blown07 is offline
Car: 335xi, 335i
Default 07-16-2019, 11:12 AM
Remove the tee with with the check valve to the wipers as the check valve will introduce air. If you run a tee to separate nozzles the highest placed nozzle will let air in and meth out of the lower placed nozzle thus draining all meth out up to the solenoid. When I had a 2 nozzle setup I used 2 solenoids to fix this. I heard a loop in each line going to the nozzle may help but I never tried it.
Car: '07 e90 335i
Default 07-17-2019, 06:04 AM
AHHHHHHHH. Thanks. Will check that out!! But did already order the new tank and line.
codesx's Avatar
codesx codesx is offline
Default 07-22-2019, 01:45 PM
Dave said my run is way too long, which makes sense, Iím gonna shorten it.
What is considered a long run between the solenoid and nozzle?
I'm at approx 24 inches all told, though a bit less. (no issues yet, but new to this)
RB: Inlets | PCV Valve
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
Car: '07 e90 335i
Default 07-22-2019, 02:49 PM
Mine is probably max 18", but can be as short as 7" or 8".... just waiting on line to get here to get everything done in one shot.
codesx's Avatar
Default 07-22-2019, 04:52 PM
Hi Payam,
Do you mind sharing what the issues may be with a longer run between the filter and nozzle? (Say, 20")
Is it heat causing air (expansion of liquid) that may slowly collect in the high point of the line?
(As in, keep all hot hose as short as possible? )
** EDIT ** my line is 24 inches, from filter (fender, beside break fluid reservoir) to nozzle. Each time I touch the hose, another bubble comes up from the nozzle to the air line and sits in the high point. Currently there is a 4 inch bubble. The air comes in when the nozzle drips, just sitting there. Only fix in my mind is to mount the nozzle on the bottom of a CP so it doesn't drip. Since I cant do this, I believe I'll curve my hose down (maybe mold in heat) so that the maximum drainage (and thus bubble) will be no more than 2 inches.
Very open to other experiences and opinions.
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
