Santeen Santeen is offline
Car: 2018 Infiniti Q50
Default P0100 DTC codes - 07-11-2019, 04:23 AM
These codes have come on 3 times since, along with the collision malfunction warning. See attachments. I went and had the actual codes checked and they were P010B and P0101. Any idea what's going on?
Default 07-11-2019, 09:35 AM
They both come up as MAF sensor codes. Did you recent install intakes of some sort?
Default 07-14-2019, 05:56 PM
It does have AEM intakes, but they've been on for a while. These codes came up, the week after I put on the JB4. But I'm sure the intakes probably have something to do with it. Just wanted to make sure these weren't common codes with the JB4
Default 07-14-2019, 06:16 PM
Might be a code reading bug with us not getting the right numbers. There was an update for that in the app, if iOS you may need to email them for the BETA version.
Default 07-18-2019, 05:18 AM
I'm on android, with the latest update
PACE2525 PACE2525 is offline
Car: 2017 Q60 RED SPORT AWD
Default Same issue. - 08-06-2019, 06:33 PM
I had P0000, DCS Malfunction and also AWD Error come up today after re-installling the JB4 after the install of the WMI system.
Everything works on JB4 side but cant get rid of the above issues except for the P0000 that i could erase with the Delete function in JB4.
However the DCS and AWD issues are still at large dispite resetting ECU, Disconnected battery, Disabled JB4 on Map0, took it physically out. Nothing works.
Nearly killed myself as I have AWD and went down to 2WD unexpectedly in the rain.
Please advise .
WinfnitiQ50 WinfnitiQ50 is offline
Car: Q50
Default 08-14-2019, 11:40 AM
this has happened to me 3x while running map 3 my JB read the same code however i ran my snap on obd scanner while this was on and got all this P0101B & P0101 also gotthese C1130 & C1199.
I have a 17' Premium ams LDP's MBRP Catback exhaust and stock intake with all the plastics removed ( because i hate plastics and for temporary more airflow untill i buy my CAI.
Default 08-14-2019, 01:53 PM
Update app to beta so codes are properly read, or read via another OBDII tool.
Car: Q50
Default 08-25-2019, 09:31 AM
that didn't work for me I have the latest firmware as mentioned in my other post when ran with my OBD scanner I got different codes. any idea what the cause of those could be?
