codesx's Avatar
codesx codesx is offline
Default Ideal Tire Pressure on Wider than Stock Rim/Tires? - 07-05-2019, 03:06 PM
So, I have X1 322 Rims in my car since I bought it.
I've since installed wider tires on the non-E9x Rims and I'm trying to determine ideal tire pressure. (ideally without slide testing or waiting for inner/outer wear of course)
My car is over 4000lbs empty, being convertible (E93).
Stock wheel/tire sizes have a pressure of 33r/36r. (225f/255r)
Current Rimes and Tires:
Fronts: 8.5", 245/35r18
Rears: 9.0", 275/40r18
I'm guessing at 35f/38r, simply based on wider tires have higher pressure to avoid just wearing on the outsides.
Thoughts / Experience / Facts are all welcome!
RB: Inlets | PCV Valve
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
THE BEAST's Avatar
Car: 2008 E93
Default 07-05-2019, 03:36 PM
I run 42psi in front and 36 psi in rear. 19s on my E93. Front are Pirelli, rear are ToyoR888r. Its not a set thing, some tires allow 50 psi max, others 45, etc. Sidewall strength, hardness of the rubber, etc will all play a part. Should just look up recommended tire pressure for the tire you are running. FWIW , I ran 75 psi front and 48 psi rear on skinny little 155/80/13 on the lowrider, lol
