Furylibre Furylibre is offline
Car: 335XI
Default First log after installing Pure Turbo stg2 (low boost) - 06-12-2019, 08:41 PM
Hello all,
This my first log, and i am very surprised about the boost level (not more than 4-5). Car is running well, no code, but no boost really. 2008 N54 E90.
I changed turbos for Pure Stage 2, DV, inlets 2", kyttylessDP, inefortercooler, chargepipe. I have BEF hybrid for pump, i run 91, and i adjusted MAP 5 with BIAS as of Terry recommendation in thread #33200.
I did inspect visually, but before making vacuum test, and remove everything and look for leak, or vanos, or other things, i just want to make sure it's not another thing obvious that you could see.
Here's my log.
190612_2001.csv
Thank you for any advice.
Haynpunch's Avatar
Car: 07 E90 335i
Default 06-12-2019, 08:50 PM
Menu 4/2?
Proper Logs:
A couple adaptation runs are good if you made any recent changes
Flat open road
3rd or 4th gear (preferably 3rd)
Traction off
Start log WOT 2k to redline Stop Log
Post it!
07 E90 AT - xHP
JB4 G5 - Trebila BEF
FBO
Hybrids
Car: 335XI
Default 06-12-2019, 09:02 PM
Thanks for fast return.
Yes 4,2 is done.
Adaptation runs have not been done, it was second run after updating software and flash Back End.
i'll make another log soon..
Haynpunch's Avatar
Car: 07 E90 335i
Start w map 2
07 E90 AT - xHP
FBO
Hybrids
Car: 335XI
Default 06-12-2019, 09:09 PM
When i change bias and parameters in JB4, is it for all MAP or just the one selected ?
Btw, i did change the tmap sensor for a 3.5, and PCV valve.
Haynpunch's Avatar
Car: 07 E90 335i
Default 06-12-2019, 09:20 PM
It’s for all
07 E90 AT - xHP
FBO
Hybrids
Dave @ BMS/Fuel-It! Dave @ BMS/Fuel-It! is online now
Default 06-13-2019, 10:44 AM
Originally Posted by Furylibre
Hello all,
Here's my log.
Attachment 87380
You don't go WOT in the log?
Proper log is WOT, 2k to redline, in 3rd gear.
Relog w. map 1 or 2 to start
Car: 335XI
Default 06-28-2019, 08:25 PM
Finally, manage to replace Coils, Spakplug and injectors.
I did 2 pulls, and the second one put me in Map4.
After, i had hard time to return home, big sound of broken thing in the car. Tomorow, i'll tow to Indy to see what happening, i suspect a turbo blow out...
Do you see something weird in logs ?
Thank you, i am little bit worried now :o\
190628_2018.csv
190628_2023.csv
Default 06-28-2019, 08:40 PM
Attachment 87844
Attachment 87845
Throwing overboost code- hence the map 4 change
Nothing indicating a loud bang in log- u sure you didnít just backfire?
Default 06-28-2019, 08:41 PM
Attachment 87844
Attachment 87845
Nothing indicating a loud bang in log- odd Turbos would be blown this early..?
Car: 335XI
Default 06-28-2019, 09:23 PM
You can have a look of the sound
Weird motor sound - YouTube
Default 06-30-2019, 11:38 AM
Hmm- noisy for sure.
How does the car idle / run - have you driven it?
Car: 335XI
Default 06-30-2019, 12:02 PM
Idle Is ok. Not rought at all. But noisy. I drove home, it was like breaking dishes. Head turning but not for good reason. Just about home I had a low oil pressure error. Close everything , put the car on towing, and ship it to Indy. I suspect maybe crank bearing or something like this. Hope I did not destroy motor. I did 3 pulls. Not a lot. It began slow tic tic, I stopped the pulls, and by the 10 miles it took to get home, it has been more and more noisy.
Default 06-30-2019, 07:47 PM
Yea Iíd get an Indy to inspect- bad luck man.
How many miles are on the car?
Car: 335XI
Default 07-01-2019, 04:56 AM
130K miles.
Default 07-01-2019, 10:19 PM
130K miles.
Tough luck- keep us posted
Car: 335XI
Default 07-03-2019, 01:33 PM
Finally, Blewed motor ! Kaput! Need another one.
Can't beleive it! I am surprised that N54 are that weak. I don't know what happened. As soon as we'll remove it from the car, we'll have a look.
The logs was not so bad, i don't think a 24 psi boost can blow out a motor like this. The only things, on second log, i had overboost. I respect and configure JB4 and MHD as instructions provided here, and triple check everything. Maybe at 130K miles motor was too old to support all that boost.
Heavy money again to trow in that pit.. Ho well, what else can i do with all my money anyway...
THE BEAST's Avatar
Car: 2008 E93
Default 07-03-2019, 02:38 PM
24 psi on PS2 is capable of 600whp. I would not try to even get close to those #s on 91 pump. Sorry for your loss. Update thread with damage if you dont mind.
Car: 335XI
Default 07-03-2019, 06:53 PM
So you think it was too much boost for pump gas ? I was 91. I took pump gas when i installed the MHD BEF. hybrid, pump.
THE BEAST's Avatar
Car: 2008 E93
Default 07-03-2019, 07:17 PM
Breaking the motor down will tell the story.
I feel overboosting that much on pump gas is not safe IMO. But, just a one time event would be real crappy luck to have a motor let go because of it. Like I said, tearing the motor down will give more insight.
codesx's Avatar
codesx codesx is offline
Default 07-04-2019, 09:46 AM
Curious if your oil filter had collapsed. (low oil pressure)
My last 335xi had this issue when I bought it. The independent dealer cheaped out. A BMW dealer found it when changing solenoids at the cost of the independent dealer. All boiled down to the oil filter collapsing.
RB: Inlets | PCV Valve
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
