codesx's Avatar
codesx codesx is offline
Default Do we all emit black smoke on start up? - 06-28-2019, 11:03 AM
My car runs a bit rich, though not bad at WOT.
Every start up, black smoke emits.
I know I need to replace the injectors, which is happening soon.
That said, I see the black (fuel, based on smell) on every start, even if just off for 1 minute. (Watching someone else start it. It can't be seen in rear view mirror)
I still have stock exhaust.
Typical when modded?
Just ignore it?
Or uncommon and likely to clear after injector replacement?
Thanks for the thoughts!
RB: Inlets | PCV Valve
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 06-29-2019, 03:34 AM
Never had a black smoke on startup, could be carbon build up? Any walnut blasting done? A friend bough a used e92 but it was buffing black smoke on flooring it I guess previous owner never floored it and used low grade fuel, an injector cleaner and few pulls cleared it all.
THE BEAST's Avatar
Car: 2008 E93
Default 06-30-2019, 12:05 AM
Ummmm No.
codesx's Avatar
Default 06-30-2019, 05:53 AM
Rubbish. I was hoping it was due to out tunes.
I do WOT many times a day and walnut blasting and liquid port cleaning done (ports visually look clean).
Will update after injector replacement.
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
ifjd073's Avatar
ifjd073 ifjd073 is offline
Car: 2007 BMW 335 (E90)
Default 06-30-2019, 08:34 AM
I throw out an unfortunate amount of soot in a liquid suspension on startup, which I attribute to startup richness. It's enough to make a fun little spray pattern on my garage door if I ever test fire - note that after I saw it once I never leave my garage door down for any reason when starting. That said, it doesn't smoke... Just does that for a minute or so.
'07 335 sedan, Stage 2 VVT, VVT inlets/outlets, VVT DCI, Phoenix CP with Tial BV, 3.5 bar TMAP sensor, Spec twin disk clutch with SMF, BMS OCC, RB PCV valve, ***less ***, VRSF catback with Vibrant *** installed, ETS 5" intercooler, Fuel-It stage 2 fuel pump, Fuel-It 650HP LPFP upgrade with 525 pump, JB4 with custom Trebila BEF, Phoenix PI intake manifold /w 550cc injectors, Fuel-it fuel lines, ethanol sensor and analyzer
THE BEAST's Avatar
Car: 2008 E93
Default 06-30-2019, 01:04 PM
I would lean towards injectors as well.
rickz96 rickz96 is offline
Car: e60 535Xi
Default 07-05-2019, 07:27 PM
I second this...have the stains on my door as well.
mrmax1984's Avatar
mrmax1984 mrmax1984 is offline
Car: E92 335i
Default 07-09-2019, 01:43 PM
Could be oxygen sensors as well, if this is happening after the car warms up:
How I Diagnosed My Failed Oxygen (Air Fuel Ratio) Sensor - BMW DIY - YouTube
funglenn funglenn is offline
Car: 535Ix
Default 07-14-2019, 11:52 AM
i had a JB4 tune and no smoke, moved to COBB and no smoke at all.
2009 535i Xdrive Sport. Alpine White/Black Leather. JB4 G5, Dinan Exhaust. Escort Passport SRX laser jammer. Burger catch can, Sport SAT Transmission retrofit, Beyern Mesh Chrome Rims, CIC Retrofit
THE BEAST's Avatar
Car: 2008 E93
Default 07-14-2019, 12:15 PM
So what your saying is, your car never smoked.
codesx's Avatar
Default 07-15-2019, 09:28 AM
Thanks. Very interesting video.
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
codesx's Avatar
Default 07-15-2019, 09:31 AM
LOL. Who goes from JB4 to COBB?
P.S. You still have JB4 in your signature. I think I'm miss-reading a few things here
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
