VTR VTR is offline
Car: bmw e82
Default Low pressure FPH - 06-14-2019, 09:29 PM
Hello!!
I have the following problem
I have an e82 n55, the clock of jb4 FPH always marks 10 and accelerating at full load drops to 5, change the sensor to a new one and keep dialing 10
then leave the sensor on the fuel rail and connect the new sensor without mounting on the rail and keep dialing 10
drwillb drwillb is offline
Car: 2012 n55 135i
Default 06-15-2019, 04:05 AM
Does your JB4 harness have a fuel pressure connection? Some of the older ones don’t so if you bought a used one you will need to add the fuel pressure wires. This is available on the Burger site.
I have the same car as you so I went through this already.
2012 135i Mods: air scoops, CP, BMS filter, PS1, N20 TMAP, ADE FMIC, BMW PE, JB4, BMS BEF, 1M front body, full M3 suspension
Owned so far: 88 M3 x 2, 95 325is, 95 M3 x 2, 06 Mini Cooper S, 08 335 xi, 09 Z4 35i, 01 M3, 12 135i
VTR VTR is offline
Car: bmw e82
Default 06-15-2019, 11:46 AM
Originally Posted by drwillb
Does your JB4 harness have a fuel pressure connection? Some of the older ones donít so if you bought a used one you will need to add the fuel pressure wires. This is available on the Burger site.
Can you show me what they are or pass me a link?
Car: 2012 n55 135i
Default 06-15-2019, 07:05 PM
Does your JB4 harness have a set of plugs that tap into the factory fuel pressure sensor on the back end of the fuel rail.
You mentioned fuel pressure sensor in your original post so you should be familiar with it and whether or not you are tapping into that.
If your harness doesn’t have the wires then go to burgertuning.com and look for them there.
Default 06-15-2019, 08:34 PM
JB4 log? Sure the fuel pressure connection is installed properly?
VTR VTR is offline
Car: bmw e82
Default 06-16-2019, 02:33 PM
I do not see connection to the pressure sensor, the car buys it with the jb4 already installed
Default 06-17-2019, 08:24 AM
Check our install guide to see if it's connected or not.
https://cdn.shopify.com/s/files/1/08...03566420695544
Zackman218 Zackman218 is offline
Car: 2011 BMW 335i M-Sport
Default 06-19-2019, 10:37 AM
Hello!!
I'm having the exact same problem and I even replaced my high pressure fuel pump and there was no change. Did u find out the fix for this?
Default 06-19-2019, 10:54 AM
Hello!!
I have the same problem as u and I checked to see if I had the fuel pressure connection and I don't I found it on BMS and ordered it, it's only $25 and totally worth it. https://www.burgertuning.com/collect...flexfuel-wires
Default 06-22-2019, 08:48 PM
I got the fuel pressure sensor for the jb4 today and went to install it and I made sure I set open loop fuel to 50 in user adjustment. I start the car and it ran for a few seconds then stalled and keeps stalling after I turn it on. I followed the installation guide from your website and can't seem to fix it. Do u think it might be related to having mhd bef?
VTR VTR is offline
Car: bmw e82
Default 06-23-2019, 12:24 PM
what I was reading with old firmware versions does not work, is it?
Default 06-23-2019, 12:48 PM
Has to be wired wrong then. Let's see some instillation photos.
Default 06-23-2019, 04:51 PM
Yeah it was just a bad connection or something I used crimp connection instead of butt connectors. Got it all sorted out thanks for the help!
Default 07-15-2019, 09:55 PM
Just update the firmware. It's not very difficult, I installed my fuel pressure sensor and I'm getting normal hpfp numbers now!
Default 07-18-2019, 10:21 AM
All sorted?
Teckstudios's Avatar
Teckstudios Teckstudios is offline
Car: BMW 335i
Default 10-03-2019, 04:42 AM
So is it normal for my FPH to be 18 under load and FPL to be between 26-41?
BMW F30 335i M-Sport - JB4, BMS Intake, VRSF FMIC, BMS CP, VRSF D/p
