ulimotorsport ulimotorsport is offline
Car: 135i n54
Default N54 Bi turbo upgrade log help pls - 05-18-2019, 02:56 PM
Hello, I have n 135i n54 bj09 and i put ******* **, Upgrade turbos similar than tte550, charepipe and Blow off, NGK ignition, PVC, oil Thermostat, race oil, MHD backendfash and petrol 98\102 oct.
I now one important thing is missing, the inercooler but this i will get soon.
I read some things here, thanks for this but its not so easy for me because my english is not the best.
Here is one log in 3. gear MT transmission,JB4 map 6 with the settings from the hybrindturbo Thread. For me car is running not so bad, but i want more. Maybe somebody can say me here what i can make better. Thanks.
Best regards from munich.
Default 05-18-2019, 10:46 PM
Log looks okay overall.
Couple things that may help.
Update your firmware to the latest
What are you using for fuel?
Car: 135i n54
Default 05-19-2019, 12:57 AM
Thanks, i will try to marke update towday. Than i make log in 4. gear. I use german super plus 98roz and sometimes i get 102roz.
Default 05-19-2019, 03:09 PM
Proper logs are THIRD gear, 2k to redline just for when you log later
Car: 135i n54
Default 05-23-2019, 03:42 AM
Hallo, now i made the Update and i put stronger spring in Blow off because i fall in hole after Shift allways this is better now. But Power its Same and i want more pls help :D
Haynpunch's Avatar
Car: 07 E90 335i
Default 05-23-2019, 04:36 AM
you may not want a to strong of spring in the BOV, not good for turbos
boost shouldn't spike when you let off the throttle
Default settings for hybrid turbos, FOL is 40 (84), FF is 100 (49)
07 E90 AT - xHP
JB4 G5 - Trebila BEF
FBO
Hybrids
Default 05-23-2019, 11:06 PM
Definitely a bit more room- what are you using for fuel?
Car: 135i n54
Default 05-24-2019, 12:36 PM
Boost go down fast when I let off the throttle. You can see in log. I think its good like this but maybe i buy new BOV.
Fuel Open Loop is 84 and FF go down on 38 ???
I use German Superplus the best you can buy in Germany on petrolstation. Its minimum 98roz(oktan) to 102roz.
Pls help me I want more boost
Default 05-24-2019, 12:39 PM
If you like using map 6- set boost to 16psi across board & relog
Car: 135i n54
Default 05-24-2019, 12:54 PM
Okay, thank you
I try this and make a log.
Car: 135i n54
Default 05-25-2019, 12:01 PM
I made the log. Car is running better but today was very hot and IAT was not so good. I thing next week i get new big intercooler
What I must do next to get more? Thanks for help
Default 05-25-2019, 01:55 PM
Letís wait for the fmic
Car: 135i n54
Default 05-27-2019, 12:16 PM
I get inercooler in 3 weeks...
Default 05-27-2019, 08:35 PM
3 weeks? where are you located?
Post another log and lets see.
Car: 135i n54
Default 05-28-2019, 02:07 PM
I come from a little village near Munich. Zoll and taxes and shipping is bad. But maybe i get earlier. We will see.
Her it is. Thank you.
Default 05-28-2019, 10:18 PM
From 4.5k to redline, raise your duty bias value by 5
relog
Car: 135i n54
Default 05-30-2019, 07:44 AM
done.
Default 05-30-2019, 08:48 AM
done.
This looks really clean!
Boost much closer to target up top.
Get that FMIC! lol
Car: 135i n54
Default 05-30-2019, 12:07 PM
thank you
i will get
Default 05-31-2019, 12:14 AM
thank you
i will get
Car: 135i n54
Default 06-07-2019, 02:12 PM
Today Intercooler came I orderd the Wagner evo3 and its looking so nice.
I put it tomorrow. Can I go on 19 Psi or should i let everything like it is and make a log?
Car: 135i n54
Default 06-08-2019, 12:16 PM
So I made it all on 20 psi.. and its feel good
But I want more pls say me what i must do.
here is the log.
Default 06-08-2019, 11:02 PM
here is the log.
Evo 3- nice choice
Bump your duty bias up by 5 rom 5.5k to redline
Car: 135i n54
Default 06-09-2019, 01:15 PM
Yes and its fit so good i cant belive that. I got the cooler and thought never i will get this in car but no problem.
I think i must now made sparks gap form 0,55mm to 0,45mm for more boost?
And I drive stock Lowpressurefuelpump this I must change also. Is walbro 450 enough ?
Hier is the log. Car its driving good thanks
Default 06-10-2019, 08:41 AM
Iíd run .018- .020 on the plugs
Depending on power goals- the bucketless 450 is usually enough for most guys
