(#51)
Default 05-28-2019, 10:20 PM
Logging can be tough, so just be safe.
2k - redline.
WOT
Traction control fully disabled
3rd gear
Otto's Avatar
Otto Otto is offline
Car: 2010 BMW 335i
Default 05-31-2019, 12:25 AM
My first try the boost was nicer around mid 14psi but traffic forced me to stop. Also I noticed it's seems like the jb4 is no longer sending me to map 4. I'm very happy with the way she's running right now but I want to know what you guys think before I proceed. Thanks again!
Default 05-31-2019, 12:27 AM
Better!
Log looks to be fine, you will want to enable 6cyl timing in your user adjustment tab
Otto's Avatar
Car: 2010 BMW 335i
Default 05-31-2019, 12:30 AM
Better!
What will that do? Ok it says 6-cyl timing logging (0-6)
I8A0s=4, IJE0S=5 so what do I put in the box?
Haynpunch's Avatar
Car: 07 E90 335i
Default 05-31-2019, 05:30 AM
It lets you see what all cylinders in are doing not just cyl 1
most likely you have IJE0S so put 5 in the box, if no numbers show up in the next log then try 4
07 E90 AT - xHP
JB4 G5 - Trebila BEF
FBO
Hybrids
Default 06-01-2019, 01:26 PM
allows us to see multiple cylinders
lets try 5
Otto's Avatar
Car: 2010 BMW 335i
Default 06-02-2019, 06:50 PM
I got code for cylinder 3 misfire about a week ago the first day wasn't bad and the second day it was noticeably bad. I replaced the spark plug and all was great! It was hotrod weekend and I was out driving pretty aggressive, got thirsty and downed a newer WRX and a Focus RS lol Today when I turned on the car I noticed a slight misfire and got the cylinder 3 code again. This is a pick of the plug. Looks like its running rich. So that's cylinder 3 spark plug twice in two weeks. What do you guys think I should do or look for?
Default 06-03-2019, 12:29 AM
Tough to see in the pic- is that oil?
What do the other plugs look like?
Otto's Avatar
Car: 2010 BMW 335i
Default 06-06-2019, 08:27 PM
I've been busy this week getting my body used to 1st shift again but I will be removing plugs and taking pics for you guy tomorrow. Question: You guys pretty much know what I have so far. DCI, LPFP, JB4 with the bluetooth, charge pipe with tiel BOV. Do you think I can run meth if so what%?
Default 06-10-2019, 10:57 PM
You can...
Id go FBO first though..
