Ryan81789 Ryan81789 is offline
Car: 2009 BMW 335ix
Default Jb4 help - 04-09-2019, 01:51 PM
Can anyone take a look at my logs and tell me how to use the jb4 better for tuning? Where do I find the latest firmware to update my jb4?
2009 bmw 335i xdrive. Jb4, dual cone intake, sport intercooler, down *****, all cats are removed, stage 3 fuel it LPFP, VTT GC hybrid twin turbo kit
Default 04-09-2019, 10:49 PM
N54 BimmerBoost MHD Back End Flash Maps - N54Tech.com - International Turbo Racing Discussion
Post #1
Let’s get your JB4 firmware updated & you’ll want to flash the right hybrid BEF
Haynpunch's Avatar
Car: 07 E90 335i
Default 04-09-2019, 11:41 PM
Latest JB4 Firmware
Update to latest JB4 Firmware
Flash the appropriate BEF for your mods as noted above (link in previous post)
Set all settings to default found in post #1
Hybrid Turbo Setup Directions
07 E90 AT - xHP
JB4 G5 - Trebila BEF
FBO
Hybrids
Car: 2009 BMW 335ix
Default Updated firmware - 04-10-2019, 03:29 AM
I updated firmware last night. Here is a new log from after I updated. What flash do I need to get?
Haynpunch's Avatar
Car: 07 E90 335i
Talking 04-10-2019, 07:13 AM
Choose one from the link Dave provided.....if you are running just pump gas start with that. Make sure you flash the appropriate one (when you connect to mhd itíll tell you which dme you have) most likely IJE0S but double check!!!
Set ALL settings to default in the link I provided in the post earlier!
Read that whole post
Start with map 2
Post a proper log
3rd gear 2k - 7k wot traction off
Post it - wait for feed back
07 E90 AT - xHP
FBO
Hybrids
Default 04-10-2019, 09:42 PM
Choose the appropriate flash for your fuel & mods.
If you donít have hybrid turbos or a single- ignore anything with ďSTĒ or ďhybridĒ in it.
Iíd assume your stock turbo- so pump flash if using 93 to e30ish
Car: 2009 BMW 335ix
Default 06-12-2019, 07:35 PM
I recently had the mhd e85 hybrid turbo bef put on my car. Took a log tonight from 2k-7k rpm if anyone can look at it. Any help is appreciated
Haynpunch's Avatar
Car: 07 E90 335i
Default 06-12-2019, 09:30 PM
You still havenít set all to default from post 3 in this thread
07 E90 AT - xHP
FBO
Hybrids
Default 06-13-2019, 10:46 AM
What are you using for fuel? HPFP looks to be getting a bit low / taxed.
I think your LPFP sensor is shot- that value stays pegged @ 48- I'd look into replacing.
Car: 2009 BMW 335ix
Default 06-13-2019, 09:15 PM
I run e85/93 mix, about an e45 mixture. I took another log tonight with the default hybrid turbo settings.
2009 bmw 335ix, jb4, dual cone intake, down pipe, sport intercooler, stage 3 lpfp, vtt gc hybrid twin turbo kit, mhd e85 hybrid turbo bef
Car: 2009 BMW 335ix
Default 06-15-2019, 12:24 AM
I changed the lpfp sensor today. Took another log tonight with the new sensor. The car changed the map to map 4 on me, saying fuel trim variance. Any ideas what it could be?
Default 06-15-2019, 11:01 AM
Your HPFP looks maxed
LPFP dipping into the 50s
Youíll throw the variance code when your bank 1 / 2 trims start to drift too far apart.
Can I see a log on a lower map?
Car: 2009 BMW 335ix
Default 08-02-2019, 12:02 PM
Iíve been having a lot of problems out of my car the past month or so, first the car would randomly die when driving down the road. I replaced hpfp, fuel sensors, battery and battery cables, then my mechanic said the fuel pressure module was bad so he replaced that. The car isnít dying anymore but now when I get on it and it hits 4K rpms it doesnít want to go past that. It acts like itís hitting a limiter or is hesitating or something. Iíve never had this issue before, I took a log but idk if anyone can tell anything or could possibly know whatís goi g on. My mechanic reflashed the car while he had it so I lost the bef and transmission flash also. Any help would be appreciated
Default 08-02-2019, 12:54 PM
difficult to tell anything based on the logs...
do you have a means to flash anything, or are you relying soley on a mechanic"?
Car: 2009 BMW 335ix
Default 08-02-2019, 02:16 PM
Iím relying on a mechanic unfortunately. I scanned the car this afternoon and hereís a pic of the codes.
Car: 2009 BMW 335ix
Default 08-07-2019, 08:37 PM
When driving normal the car will go all the way to redline at 7k rpm but when I get on it it still acts up. Iím clueless as to what it could be. Anyone have any ideas?
Default 08-07-2019, 10:39 PM
Looks like your misfiring on a few cylinders...
