(#201)
Eric97h Eric97h is online now
Car: Bmw 340i
Default 06-10-2019, 02:10 PM
EWG connector right? Set FF to 60 and relog map3 and map4, so we can get boost up closer to the intended target.
Here is map 3 and map 4 after doing that adaptation ? Do you think map 4 is safe to run without meth ?
2 map 3 2 map 4
Default 06-10-2019, 04:20 PM
Here is the issue... On map4 fuel pressure is starting to crater. So I'd stay on map3 for now.
Car: Bmw 340i
Default 06-10-2019, 05:14 PM
Ok thank you I will use map 3 it ran completely fine was really fast too if I get meth I will run map 4!
BMW After BMW
Car: BMW M240i
Default 06-10-2019, 07:25 PM
Meth helps a whole lot with the hardware fuel limits on this platform, if you want to make more power. That said: there are lots of variables so what works for one may not work for someone else. Have fun experimenting.
ziyadeth ziyadeth is offline
Car: M240
Default 06-11-2019, 08:22 PM
Here is a log. I don't have access to e85, so 93 octane it is.
17 M240I - 6 Speed - FBO - PS2 - WMI (M1) - MHD BEF +JB4(FF and EWG wires)
JBoe JBoe is online now
Car: M240i
Default 06-11-2019, 08:49 PM
They do or wait for our USB-C cables. Should be here in a few weeks.
Hi Terry... are the USB-C cables available yet? I want to get the BEF and maximize my stock turbo WMI setup asap.
Default 06-11-2019, 09:30 PM
Sorry not yet. Just get an adapter or buy a $40 android device that has MicroUSB.
rf30a rf30a is offline
Car: F30 328ix/C300 W205
Default 06-12-2019, 01:06 PM
Anyone else experiencing a rough idle on startup with the cold start disabled?
Default 06-12-2019, 01:25 PM
Disabling cold start as a flash time can sometime cause cold idle issues. I'd leave it on.
Default 06-12-2019, 02:04 PM
Thanks Terry!
Car: Bmw 340i
Default 06-12-2019, 10:10 PM
hey is it possibel to use the race gas map back end map just do full 100 octane will it run better or even faster than e40?
Default 06-12-2019, 10:32 PM
Yes with unleaded race fuel you have more tuning flexibility as fuel pressure is less of an issue.
Default Map 4 e85 logs - 06-14-2019, 05:23 PM
Hey,
Attached are some map 4 and a map 5 e85 logs. Running e40 with 93 octane base. Let me know how it looks.
Thanks,
Ron
Car: Bmw 340i
Default 06-14-2019, 07:05 PM
Originally Posted by rf30a
Hey,
Attached are some map 4 e85 logs. Running e40 with 93 octane base. Let me know how it looks.
Thanks,
Ron
Dam map 4 didnít work out so well with me e40 91 octane hope it works good for you
Default 06-14-2019, 07:21 PM
Fuel pressure looks good, and trims seem okay so, I think it is good but want to check with the experts. 93 octane as a base must make a difference too.
Antec800 Antec800 is offline
Car: 340ix
Default 06-16-2019, 06:08 PM
Alright map 4 on v13 with bit6 turned off is 6.5 psi target boost for anyone running additive on v13 instead of absolute with bit 6 turned on
Default 06-16-2019, 08:59 PM
Made the fuel pressure safety a little more sensitive in 13_1, found some instances where misfires were occurring from fuel pressure drops on E85 mixtures that the safety didn't catch ahead of time. Keep the logs rolling and we'll crank it up even more if needed!
Nugs Nugs is offline
Car: 2011 135i
Default 06-18-2019, 10:20 PM
What is the scaling of FP_H in JB4 logs?
eg does 15=1500psi?
At what point do you start getting misfires from low fuel pressure?
Default 06-19-2019, 05:18 AM
I got jb4 switched to safety map a couple times on map 4. Unfortunately, I wasn’t logging either time, just opened the mobile app and saw it pop up after connecting. Maybe I am missing a potential issue in the logs I posted above?
Thanks in advance for the help!
Default 06-19-2019, 10:03 AM
See if you can capture it coming up in a log so we can see why exactly. What was last safety setting stored on user adjustment page?
Default 06-19-2019, 03:37 PM
Says 0? Does it reset after disconnect/reconnect?
Default 06-19-2019, 03:43 PM
I'll have to see the log then...
Default 06-19-2019, 03:44 PM
Ok think i got it. Since map 4 used to be the safety map, if you connect the app and the jb4 is in map 4 it thinks it switched to the safety map. So, throws up the banner in the app even though there was no safety issue.
I opened the app, car was in map 3, I switched to map 4, Disconnected and then reconnected and got the switched to safety map message. Probably logic in the app?
Default 06-19-2019, 04:54 PM
By the way any feedback on my map 4 and 5 logs posted above. Would really appreciate it!
B58_M240 B58_M240 is offline
Car: M240i
Question BEF with JB4 removed - 06-19-2019, 09:46 PM
I don't see that this has been asked before, so if it has already been answered, I apologize.
If JB4 BEF is applied and JB4 has to be removed (malfunction, damage, etc.), are we safe to run w/0 JB4 or do we have to flash back to stock? I'm curious is there is anything set in the BEF that will result in oddities or danger if JB4 is removed from the equation.
