DaySleeper DaySleeper is offline
Car: 2001 and 2013 BMW M5
Default First log on map 1 - 10-04-2018, 09:57 AM
Here is my first log on map 1. At first it shot up to 19.4lbs boost and I could hear detonation clicks! This is after it corrected and the detonation went away.
Back in the day, the Grand Nationals could run about 18psi before it leaned out on pump gas until we discovered the magic of alcohol injection.
Default 10-05-2018, 12:00 PM
I don't see you hitting anything more than stock basically.
Can you get me a log on map 4 and 3?
Default 10-07-2018, 03:38 PM
I had the traction control on. oops.
I'm almost done routing the methanol line under the car (time consuming) and then I'll try again. I normally get around 19psi on map 1.
Default 10-08-2018, 08:28 AM
Oh man, are you using a stainless steel line? Routing under the car can be scary.
Default 10-09-2018, 03:18 PM
Right. It's in a plastic conduit and I'm following where other wiring is routed so as to avoid heat. It is taking a lot more line than I hoped, about 18'. It will look good and won't be inside my interior. The guy that bought this car before me paid $108K because of all the options and I can't bring myself to run a pressurized methanol line inside of it.
