(#76)
Soccerstyle Soccerstyle is offline
Car: Kia Stinger
Default 04-24-2018, 06:59 PM
Originally Posted by Deider1
Have had this installed for over a week and have had no problems using map 1. Anyone had no problems with map 1 one but then map 2 caused problems? Also the bluetooth module connects with no problem but will not give proper feedback until they update phone app when out of beta.
Iíve been running map 2 for over two weeks and havenít had any problems.
Default 04-24-2018, 07:51 PM
I'd be interested to know how many of you have misfires, and at what boost levels, so we can plan the maps out accordingly.
stingerGT stingerGT is offline
Car: 2018 Stinger GT2
Default 04-25-2018, 04:00 AM
I had been running map 1 with 93 octane for about 400 miles, then started getting stuttering about 3K RPM when hitting boost. It started out barely noticeable, then got almost violent within a day. I removed the tune until I can re-gap the plugs, hoping that's the problem. Unfortunately I wasn't logging at the time to provide any better feedback than this. Any idea why the drastic change all the sudden?
hungtran505 hungtran505 is offline
Car: Kia Stinger
Default 04-25-2018, 03:45 PM
I had the same thing happen to me. I had to replace all spark plugs and coils and regap the spark plugs to .025. I'm on map 2 with no issue at all.
Default 04-25-2018, 03:50 PM
I've had the chip off for 2 days and the car is running great now. Hopefully no damage to coils or plugs.
Jdouga Jdouga is offline
Car: Kia stinger
Default 04-29-2018, 11:47 AM
Has there been any updates on canbus? As far as misfires go, ibgapped the stock plugs to .025 using 91octane and map 1, 430mi later, no issues yet.
Anthony235's Avatar
Anthony235 Anthony235 is offline
Car: m235i
Default 05-01-2018, 01:49 PM
BMS,
Are you working with this company or are they just copying your product and pictures? I almost registered on that site to call them out, but figured I'd let you handle it.
https://www.kiastinger.org/forum/thr...iggy-back-Tune
Default 05-07-2018, 08:38 AM
Any news on Canbus support?
Default 05-07-2018, 09:10 AM
Originally Posted by Anthony235
BMS,
Bytetronik private labeled our hardware at one point, so they are legit, but their sales volume was relatively low and didn't meet their volume commitments. So we started working with the Kia platform directly as a a result.
Default 05-07-2018, 09:11 AM
No updates yet there, been tied up with other projects. If anyone has a Stinger and wants to drop it off for a few days (we can send you home in a BMW loaner), it would definitely help the cause.
jerrym79 jerrym79 is offline
Car: 2018 STINGER GT1
Default 05-07-2018, 05:31 PM
I have replaced my plugs and regapped them to .22 and still getting missfires on map 2 then went to 1 and still there. Looked at all plugs again and look good so I'm not sure why I am still getting them the misfire is not bad not even a light yet just some strong stumbles ans only at speeds over 80 mph and wot.
Car: Kia Stinger
Default 05-10-2018, 05:38 PM
Well I started getting misfires around 80mph. Guess I need to check my plugs and regap.
Default 05-10-2018, 07:17 PM
Yea it's very common with more boost and power for this car. Once gapped tighter you shouldn't have issues. We've sold so many already with really good positive feedback.
Car: Kia stinger
Default 05-12-2018, 12:45 PM
Thats is reassuring, was hoping it sold good that way it could get passed the beta phase.
jaddi85 jaddi85 is offline
Car: Kia Stinger
Default 05-15-2018, 03:24 PM
Glad to hear the positive feedback from the community, have you sold any units to those with the 2.0?
I believe it has the same connectors and should be compatible. **Fingers Crossed**
Dustinís GT2 Dustinís GT2 is offline
Car: 2018 Stinger GT2AWD
Default Stuttering issues. - 05-16-2018, 06:25 PM
I have the HKS plugs and gapped to .024. Iím still getting the bad stutter at 80+ at WOT running map2. I havenít had a chance to log yet but will in the next few day so you guys can look at the data.
Car: Kia Stinger
Default 05-17-2018, 05:19 AM
Stock plug gapped it to .025 on map 2. Had about 3 weeks and running it hard with no issue.
Car: Kia stinger
Default 05-17-2018, 11:46 PM
Do u have any other mods installed as well?
Car: Kia Stinger
Default 05-18-2018, 05:21 AM
Just a catback.
Default 05-18-2018, 06:30 AM
I have the K&N Typhoon intakes. Going to do the porting on my down ***** as Torque showed in his video to giv it a little more flow.
Car: Kia stinger
Default 05-18-2018, 10:49 AM
I cant see the intakes or catback causing issues, hopefully bms can get an answer for u. Btw any link for the porting?
Default 05-18-2018, 10:54 AM
They replaced the down p i pe / secondary c a t with straight p i pes. They ported the primary c a t, which is must more difficult to get to.
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 05-18-2018, 10:57 AM
What exactly is 'porting a c at' ?? Is that just removing the catalyst material, traditionally called 'gutting the c at'?
Car: Kia Stinger
Default 05-18-2018, 10:58 AM
I believe your coil is bad.
Default 05-18-2018, 11:11 AM
I can't find the post now, but I believe they actually removed material from the cast piece going into the c at. If my memory is correct, the p ipe narrows quite a bit there. You kinda see the right side (inlet) is a narrow cast piece.
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
ghodge
