(#301)
Default 03-26-2015, 03:08 PM
It's only going to turn on if boost goes high enough to enable it.
Amgturbo2012's Avatar
Amgturbo2012 Amgturbo2012 is offline
Car: 2010 135i
Default 03-26-2015, 03:42 PM
If you don't want it to turn on at all, even in boost, map B should be blank all the way across the board.
10'135i Alpine White M-Sport M/T 827HP 707TQ@32lbs
Motiv 900 - Tial BOV/Wastegate - Big Tom Intercooler - FuelIt! Stage 3+ - MHD Custom Flash - Haltech PS1000 - Motiv Port Injection/Twin Disc - BMS OCC - Kosei - 275/40/17 NT05R's
10'135i Black A/T - 580WHP 540WTQ (11.51@134MPH 2.1 60')
blisstik's Avatar
blisstik blisstik is offline
Car: 2007 E92 MOTIV 750
Default 03-26-2015, 04:01 PM
You could also put a switch on the negative wire that's hooked to the chassis, then you can manually turn off the negative. No negative, no power.
Originally Posted by dmacpro91
Don't know if this has been answered yet (I didn't see it), but is there a way to disable the port injection? Like if I put a toggle switch on the power line going to the injectors, would that suffice? Could I just make an AIC map with zero'd out pressure and load that when I don't want port injection? I ask because I'm not sure how my LPFP will take this right now and if it doesn't like it, I want to disable it until I get my Stage 3. Also would running this with a 50/50 E85/93 mix hurt anything?
MOTIV750 / MHD+JB4 / ADV / SB REAR O2
Car: 2010 135i
Default 03-26-2015, 05:41 PM
Map A will be the only map that'll have any changes made to it. Map B is left blank, at least so far. Basically leave the SS in map A if you want it active and adding fuel. The two maps on the first page don't effect Map B. One of for the N20 Map sensor and the other is for Stock map sensor.
Dmac @ BMS/DMD's Avatar
Car: 2008 135i
Default 03-26-2015, 10:19 PM
I may end up doing this.
Maybe I don't see the info somewhere, but how do you switch maps on the AIC? Over the serial cable?
Edit: It looks like the AIC only uses map B for a different firing pattern with more injectors/strokes so you can't switch to that map, unless I'm understanding something wrong. If this ends up being a problem I might just look at the serial protocol for the AIC and add a fuel map editor to the apps.
Default 03-27-2015, 09:10 AM
The AIC we provide completely ignores map B.
blisstik's Avatar
Default 03-27-2015, 05:35 PM
Hi Terry,
Are there any updates to the PI maps? It would be helpful if you could put a date next to it or version number of some sort.
Default 03-27-2015, 06:19 PM
Yes good idea. Last time I updated them I made a post here.
Car: 2008 135i
Default 03-28-2015, 01:18 PM
As for the backend flash, do you suggest lowering the Fuel Scalar and altering the AFRs? Saw that you said you use slightly leaner AFRs, but how much is "slightly"?
n54 power's Avatar
n54 power n54 power is offline
Default 03-30-2015, 08:44 AM
Hi Terry.
i think,it is wrong..where is boost signal connector?
Default 03-30-2015, 08:46 AM
That is an original AIC4. IF you have that model the boost reference connects to the diverter valves. Also you must copy fuel map A to fuel map B.
Default 03-30-2015, 08:47 AM
I have a 100% E85 MHD back end flash file. It might be what I already sent you? I'll be adding the 100% E85 flash files to the first post shortly.
n54 power's Avatar
Default 03-30-2015, 08:52 AM
should i the pipe to intake manifold install? can i 36psi ?
Default 03-30-2015, 10:09 AM
No the AIC4 only reads up to 26.5psi give or take. But this is suitable for up to 30psi actual boost. I ran it for awhile with great results. Just be aware the maps are a bit different than what is posted. If that was the used one I sold then it already has maps loaded. Leave those on there to start.
ps. Checked the email and it was you. I'll forward your invoice back over to you to refresh your memory.
kenjermen's Avatar
kenjermen kenjermen is offline
Car: 2009 BMW 335i
Default 03-30-2015, 07:51 PM
will the 100% e85 flash go through this or will it need to be flashed like the other fuel maps?
2009 BMW 335I with: MHD/Haltech,
precision 6870 turbo, jp Workz header,
Wagner EVO II intercooler,HKS exhaust with cutouts, stage 3 lpfp, wavtech lsd, eospeed intake manifold with fuel return and 60lb injectors
Fuman Fuman is offline
Car: '09 E92 335i 6AT MSport
Default 04-02-2015, 12:32 AM
Anyone experiencing strong jerk upon sudden release of throttle on WOT after installing PI.
No codes. All running fine.
*E85 flash, map 7, full e85, stg2 LPFP, stock TMAP, PI
E92 N54 6AT, JB4 G5 ISO, FBO, METH, E85 FLASH, PI, S2 LPFP
Car: 2010 535i
Default 04-02-2015, 05:32 PM
I have the same setup, I occasionally get the jerk but can usually avoid it by letting off the throttle gently. That said, it probably shouldn't jerk like that even when letting off abruptly.
Default 04-03-2015, 02:30 PM
Got a log of the "jerk"? Wonder if it's going rich for a split second...no pun intended.
Car: 2010 135i
Default 04-03-2015, 02:38 PM
I think I have several logs of my car doing it Steve. Nothing looks out of the ordinary though. It's weird.
Default 04-03-2015, 02:41 PM
Post one up...I'd like to see it.
frmtl2_335i's Avatar
frmtl2_335i frmtl2_335i is offline
Car: 07 e92 M/T
Default 04-03-2015, 02:52 PM
Wait you threw me off here, so with the split second bic we can only boost up to 30 psi? What about those single turbo guys pushing over 30psi?
FFTEC 6466 Gen2, MHD Flash Tuned by Wedge, BMS PI Kit, FUEL-IT Stg 3 pump, HALTECH PS-1000, MFactory LSD w/lock down brace, ECS Trailing Arms, M3 control arms, M3 brace, DGR Coilovers, N20 tmap sensor, BMS OCC, VRSF exhaust w/4" tips, VRSF CP, Tial BOV. BigTom FMIC, Msport front & rear, m3 sides skirts.
12.23 @ 118.9mph (RBs)
2.3 60' lol (single pass night, bog shifting)
TT-Tom TT-Tom is offline
Car: C.S.B.
Default 04-03-2015, 03:07 PM
Its almost certainly running very rich, the injectors included are intended for large turbos, on stockers you need to run much smaller injectors (like half the size) to achieve proper results. When you run the ipw so low (10-20%) its not utilizing the injector properly, your car will run pig rich as it can't pull any more fuel than it is already.
I'd suggest looking into these for stock turbos:
http://www.atpturbo.com/mm5/merchant...Category_Code=
Terry maybe you could confirm/ correct my thoughts here, pretty sure this is accurate
Car: 2010 535i
Default 04-03-2015, 03:19 PM
Amgturbo2012's is doing it too though and he is single turbo.
Car: 2010 135i
Default 04-03-2015, 03:21 PM
Let me go through and find a good log that may show something. If we're talking about the same thing it's like a random buck once you drop off the throttle.
Default 04-03-2015, 03:48 PM
Its impossible to know. When you let off the gas the throttle closes cutting off oxygen to the engine. So even if extra fuel is injected during that time, it won't result in any power generation. A log of it coming up might shed more light on whether there is a mapping issue there that needs to be corrected, etc.
