(#776)
Jefflee Jefflee is offline
Car: c450
Default 06-16-2019, 02:42 AM
For installing BCM
Can those aspects be adjusted?
Default 06-16-2019, 12:21 PM
Yes the mapping is adjustable.
Directions for installation here: N54Tech.com - International Turbo Racing Discussion - View Single Post - Mercedes C300 / C400 / C450 / C43 W205 Stage1 JB4
Car: c450
Default 06-17-2019, 03:58 AM
Can provide c300
Jb4 installation guide?
Car: c450
Default 06-17-2019, 09:48 AM
Cbm
How to make the signal shrink? How to adjust?
baccart88 baccart88 is offline
Car: C43
Default 06-17-2019, 10:57 AM
how does this look?
Default 06-18-2019, 08:37 PM
Originally Posted by Jefflee
Can provide c300
The C300 JB4 install guide is on our site, it's the same guide as the C400/C43.
Originally Posted by baccart88
how does this look?
The log is too short to really evaluate, try to capture something longer!
MatthewJ MatthewJ is offline
Car: C400
Default 06-20-2019, 12:45 PM
Terry or Payam,
Could you please let me know if you see anything i need to adjust with this map 6 setup? C400, E30 mix, BMS intake, hot and humid AF outside. Timing is up there, boost seems to hold where i want it and i set FOL to 65 to try and get trims down some. First gear doesnt like it though, it feels like it pulls a bunch of boost and short shifts second then the boost comes on hard. Have max boost 1st set to 5.0, should it be higher?
Default 06-20-2019, 06:19 PM
Originally Posted by MatthewJ
Terry or Payam,
Boost, timing, and fueling all look good here. I wonder if you wouldn't benefit with the BCM given the high target? Worth trying I think. You can always return it if it doesn't wind up helping the car go faster!
marcrpoirier marcrpoirier is offline
Car: C400
Default 06-21-2019, 04:42 PM
Hi Terry, quick one !
My Friend ordered a JB4 for his car BMW today from Canada, he had a different ship To address than itís bill to. He was asked to provide additional details Photo ID... is this the normal process ? Just to confirm itís not some phishing/hacking technique from an illegitimate organization
Tjs
Marc
Default 06-21-2019, 06:25 PM
Normal process, there is a secure link he will get for addl info to confirm order, when billing/shipping address don't match AVS process.
Car: c450
Default 06-24-2019, 05:28 AM
Hi!
Can understand and tell me c300
A/b/c installation guide?
I am a blue version of jb4
Default 06-24-2019, 10:34 AM
Hi!
Upload a picture of your engine bay and I can help you move forward.
What is blue version of JB4? Did you purchase this from us?
Car: c450
Default 06-24-2019, 09:41 PM
Yes
Car: c450
Default 07-02-2019, 08:44 AM
Can provide more reference to the map6 adjustment method?
BigTurboC4 BigTurboC4 is offline
Car: C400
Default 07-10-2019, 08:11 AM
Roast me if you will, but in lieu of searching whilst I have no time....On the newer harnesses, where does the green wire plug to? C400 btw.
Default 07-10-2019, 10:01 AM
It's optional, attaches to the fuel pressure plug under the factory airbox on the driver side. Normally only used for E85 mixtures or really aggressive setups.
Car: C400
Default 07-10-2019, 11:01 AM
I remember it being optional from the install. A user over on mbworld suggested using it and then graduating to a more aggressive map than map 2 if the fuel trims looked okay.
DubVBenz DubVBenz is offline
Car: W212 M276 DELA 30 ; W211 OM642
Default W212 E400 Map5 Logs - 07-30-2019, 05:46 PM
Requesting a log review to see if I'm pushing things too far or need to do any manual adjustments. After running Map2 on firmware JB4_MB_C_2_TEST4 for over a month with no issues (and almost 2K miles), I figured I'd try Map5 despite only running 93. Current setup:
Model: W212 E400 (15)
BMS Version: JB4 purchased in April 19
JB4 Firmware: JB4_MB_C_4
Temp: low to mid 90s with moderate (east coast) humidity
Fuel: 93 Octane with up to 10% Ethanol
Altitude: 600-1900 feet throughout the drive
Driving style: merging onto a highway and driving over a small mountain along an interstate
Peak boost registered: 14.8 (seems to align with 6.5 over stock with Map5).
Let me know if there's a better driving style to measure logging. I actually intended to do a different set around town with lots of accelerating off of stoplights, but I must have forgotten to record.
So far no CELs or warnings, although at low throttle in eco mode when accelerating I get a bit of very slight pulsing.
Edit: original file was too large, which is why it was zipped. Only way to get current attached file was to truncate it to 3850 lines rather than the original 5000.
Default 07-30-2019, 05:48 PM
You need to attach the JB4 CSV file to the thread, not zipped, or reformatted in any way.
Default 07-30-2019, 06:04 PM
Apologies, original file was too large, which is why it was zipped. Only way to get current attached file was to truncate it to 3850 lines rather than the original 5000. Attached the truncated version, only manipulated by removal of the last ~1150 rows
Default 07-31-2019, 11:35 AM
Runs look fine from what I can see here.
Kishan16 Kishan16 is offline
Car: Mercedes Benz C 250 2015 W205
Default 07-31-2019, 12:45 PM
Hi there
I have Mercedes Benz C 250 2015 W205 sedan 2.ltr turbo with 98 octane fuel in Australia what would be the best way to boost
I see jb4 but I don't see any proper video showing how to install on them
Default 07-31-2019, 01:05 PM
Thanks Terry. I'll stick with it for the time being. Been happy with everything so far.
Default 08-05-2019, 10:51 AM
Looks like MB might have changed the sensor calibration for 2019 C300 models. Any 2019 JB4 customers here to confirm the TMAP sensor part number on their 2019 C300, C400, or C450?
