Endeav Endeav is offline
Car: BMW M2
Default Methanol Solenoid Issue - 06-15-2019, 11:25 AM
Hello,
I have an F87 N55 M2 with PS2 Turbo and Fuel-It Port Methanol injection. I am also running a JB4 and BMS WMI kit. I am running a small nozzle in the charge pipe in addition to the port injection and have a solenoid right before the charge pipe nozzle, however I am having an issue with the solenoid.
The solenoid seems to be stuck in the "open" position once the car is turned on or in accessory mode. I've triple checked my wiring and everything seems to be correct. The green FSB wire is connected to the solenoid, and the solenoid is attached to a suitable ground. I've also bench tested the solenoid with a 12V source and it opens when voltage is applied and the solenoid is grounded. Every other aspect of the methanol system functions except for the solenoid being stuck open.
Ideas?
