turbo16lbs's Avatar
turbo16lbs turbo16lbs is offline
Car: Bicycle
Default NLS - AFR lean, regular shifting - fine - 06-14-2019, 08:39 AM
Hello, as the title states my car (E92 335XI Manual) when using NLS running E85 (E40-E60) the switch between gears (at random/any) causes AFR to lean out at WOT and switch to Map 4. Attached is one log. Its happened a couple of other times, however didn't have my phone to log at the time.
Mods:
VRSF 5inch Intercooler
VRSF Intake Relocation
VRSF Down pipe
Fuel it LPFP
JB4-Map 7 - Anti-Lag Chip & 2Step Relay
E85 Backend Flash - 020719 - JB4_IJE0S_E85 file
JB4 Firmware 32_12 but now updated to 32_14
Spec Stage 3+ Clutch
10k miles on new coils and plugs
If anyone could help pointing me in the right direction I would greatly appreciate it. Thanks.
Default 06-15-2019, 11:11 AM
Mods:
VRSF Down pipe
Fuel it LPFP
Looks like you go into open loop / switch to map 4
Does it only happen when running the mentioned blends?
turbo16lbs's Avatar
Car: Bicycle
Default 06-16-2019, 07:28 AM
Itís the only thing Iíve ever ran. Granted the revision changes on the JB4 firmware and the BEFs have been applied over time, but during shifts causing a lean AFR never happened before NLS or the Antilag chip. Not saying thatís the cause but probably something that occurs just between shifting the gears with the pedal at wot.
Doesnít happen when shifting normal while driving spiritedly.
turbo16lbs's Avatar
Car: Bicycle
Default 07-01-2019, 11:23 AM
Anyone kindly with any possible other inputs?
Default 07-01-2019, 10:23 PM
Hmmm odd- have you tried with old firmware?
turbo16lbs's Avatar
Car: Bicycle
Default 07-02-2019, 04:58 AM
I haven't. Only because the latest firmware combines the Anti-Lag and 2Step (while rolling) with the WMI option selected on - its too much fun. I'll give it a shot though.
rickz96 rickz96 is offline
Car: e60 535Xi
Default 07-03-2019, 04:16 AM
I have had this happen, can't find the specific logs in my sea of logs, but yes. I have attached a log from when I was at the drag strip the other night showing the same lean condition during NLS, however mine is no longer going into map 4.
I still believe something is going on with NLS/2step and AFR, just having a hard time putting my finger on it. I have ordered Fuel-it ethanol sensor to integrate with JB4, hoping it will be able to control the AFR better. I am trying to eliminate variables.
