sosn54 sosn54 is offline
Car: BMW 335I Xdrive
Default Clogged Meth Nozzle - 09-17-2018, 11:13 AM
Can the Cooling Mist WMI nozzles be cleaned and re-used if they get clogged?
How do I clean them?
Is it better to just get new nozzles?
2010 E92 335iX, JB4 G5 ISO, MHD RACE BEF, N20 TMAP SENSOR, VTT GC Lites, VTT Inlets Outlets, BMS DCI, VRSF c.a.t_less D.P., VRSF 7.5" Race FMIC, VRSF Charge Pipe with tial BOV, BMS Meth Kit, BMS OCC, Boost Concept Stage 2 LPFP., 335iS Clutch, MFactory Single Mass Flywheel, CFS High Performance Aluminum Radiator, N55 exhaust.
AWSAWS's Avatar
AWSAWS AWSAWS is offline
Car: 335i MSport DCT
Default 06-14-2019, 09:46 AM
screw it in backwards and do a purge. Blockage gone
Default 06-15-2019, 11:08 AM
This is what I’ve always done ^
codesx's Avatar
codesx codesx is offline
Default 07-22-2019, 02:01 PM
Check your inline filter. Crazy that you got it clogged.
Was it build up or particulate?
RB: Inlets | PCV Valve
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK 5992 Plugs @ .020
Maintenance:
2018 - A/T Replaced | Plugs | Ign Coils | Walnut Blast
2019 - Index 12 Injectors | VCG | OFHG & O-rings | Alternator | TStat
2020 - OPG | Battery | IBS | Water Pump
