Renato B58 Renato B58 is offline
Car: Bmw M140i
Default M140i map2 throttle closing - 04-07-2019, 12:19 PM
Hey guys
Resently sent my m140i in for its first service, the dealer recommended I take all the add ons off which I did, they had to load new software to the car as there was a note requesting software upgrade. Anyway I have since reinstalled my jb the ** and intake BUT in map 1,2,3 car hesitates like throttle is closing, in map 4 its slitly there, but in map0 stock car runs like a bat out of hell, I loaded the new firmware still the same on the logs can see it closing the throttle, any suggestions why or what to do
naughty140 naughty140 is offline
Car: BMW M140i
Default 04-07-2019, 12:58 PM
I'm more surprised they didn't mention anything about you running the JB4 - when they reprogrammed the DME for the software update, surely the evidence would have been there?
despite you removing it from the car.
Car: Bmw M140i
Default 04-07-2019, 01:00 PM
I removed it from the car
Car: Bmw M140i
Default 04-08-2019, 02:13 AM
Here are the logs just a short 3rd gear pull, throttle closing and not sure why
Car: BMW M140i
Default 04-08-2019, 01:27 PM
Did you not read what I said?
I know you removed it from the car. But the evidence is still there. It wouldn't take BM 2 seconds to figure out the engine has been tampered with.
Default 04-08-2019, 01:49 PM
Hmm, get another log on map 1 and 0 buy try to do the same thing in both. 3rd gear 2krpm till redline. Make sure pedal is 100% for consistent data
Car: Bmw M140i
Default 04-08-2019, 10:55 PM
Will run logs tonight and check whats the deal
Car: Bmw M140i
Default 04-08-2019, 10:56 PM
No really if there isnt any stored fault codes, how would they know
Heusing240i Heusing240i is offline
Car: M240i Sunset Orange
Default 06-15-2019, 09:45 AM
Any update on the logs? I feel my car is running similar to Renato but I don’t have the data cable or BT yet to pull logs. When I’m on 3/4 to full throttle the boost spools then cuts out a few different times. I’m looking to get a data cable soon and will test the 3rd gear 2k to redline but wanted to see if anyone else was having this issue and what their results were.
JBoe JBoe is offline
Car: M240i
Default 06-17-2019, 09:04 PM
I just had my car serviced and they did a software update. With JB4 back on I was slow, throttle closures, and a few CELs. Ended up being fuel trims and ecu learning. I went back to map 0 and drove for about 500 miles of mixed driving. Reset all codes and put JB4 back on map 7. All is well now.
Give that a shot. Just a suggestion.
Default 07-12-2019, 07:46 PM
So I went ahead and purchased the JB4 USB Data Cable from BMS and was able to do some data logging. I ran a test on MAP 0, MAP 2 and MAP3. All strange results. Mind you, my check engine light came on and I did not clear it before the test. Hope this doesnt mess things up. Hoping someone can clarify whether or not the JB4 is faulty or what the issue is. Please let me know if I should be posting these elsewhere.
Default 07-16-2019, 04:14 PM
Hello all,
Any help would be great and please let me know if I should be posting elsewhere.
