Fredm21 Fredm21 is offline
Car: Bmw 335i 2007 N54
Default N54 Malfunction when using JB4 map - 06-08-2019, 09:42 AM
Hi Guys,
I am really running out of Idea and don't know what to do anymore.
I've never had issue with my car since last week. When wot in map 3 running Racegas BEF my transmission is acting wierd, when trying to shift it will overshift or go on neutral and sometimes after it shifts it will downshift. It hapenened after I installed my precision coil kit. I was sure it was the tranny oil or valvebody so I replaced the seals and tranny oil but no success. Then I replaced the whole tranny with body valve (keeping the old mechatronic so I don't need to reprogram ) and my tranny is still doing the same thing. Then I tried to reflash my XHP and still the same thing. So at the track yesterday I tried map 4 and everyhting was fine this way. Map 1-2-3 are all causing my issue. I a not sure anymore, is it jb4 causing this? Mechanical part not taking the high boots? Mechatronic failure?
I need help please. There is a log I did at the track with map 3.
Thank you Guys
-07 335i coupe
BMS charge pipe
Turbosmart BOV
VRSF down pipe
BMS WMI with single nozzle ( 10 )
JB4 map 3 w/bluetooth & antiliag
Afe intake filter
BMS intercooler
BMS tranny cooler
BMS Double baffle catch can
MHD BEF Racegas
Precision Raceworks Coil
-Running 91 octane with WMI
Default 06-08-2019, 11:01 AM
Any codes? I see it misfired or something and went lean, and the JB4 disabled for safety.
Default 06-08-2019, 11:50 AM
Those are the only code I got otherwise it will not throw any code.
My gears are going nuts in this log!
-07 335i coupe
BMS charge pipe
Turbosmart BOV
VRSF down pipe
Afe intake filter
BMS intercooler
BMS tranny cooler
MHD BEF Racegas
Default 06-08-2019, 11:00 PM
Misfire can make the car buck / run very rough.
I’d addres the misfire 1st- then let’s get another log.
Default 06-09-2019, 04:13 AM
Hi Dave, thanks for the answer. Do you think I should remove my pr coils and go back with oem for testing? My spark plugs are brand new and new oem coils also. You think it would only missfire when using map 1-2-3 but not in map 4? Also this is the only time I had a missfire code after several try, car is bucking every time but no code. Thank you
-07 335i coupe
BMS charge pipe
Turbosmart BOV
VRSF down pipe
Afe intake filter
BMS intercooler
BMS tranny cooler
MHD BEF Racegas
Default 06-09-2019, 05:11 AM
Hereís a new log, map 3. No check engine, only transmission malfunction came up and left after a second or 2.
-07 335i coupe
BMS charge pipe
Turbosmart BOV
VRSF down pipe
Afe intake filter
BMS intercooler
BMS tranny cooler
MHD BEF Racegas
Default 06-09-2019, 09:21 PM
What happens on say map1? Something definitely strange with the shifting here.. Trans going out?
Default 06-10-2019, 03:02 AM
Map 1 is doing same thing, I can male a log if you need. I replaced the whole tranny last week except for the mechatronic and same issue?
-07 335i coupe
BMS charge pipe
Turbosmart BOV
VRSF down pipe
Afe intake filter
BMS intercooler
BMS tranny cooler
MHD BEF Racegas
Default 06-10-2019, 08:51 AM
Does the trans behave normal?
Default 06-10-2019, 09:07 AM
While in map 4 the tranny is running great and every shiftpoint is good!
-07 335i coupe
BMS charge pipe
Turbosmart BOV
VRSF down pipe
Afe intake filter
BMS intercooler
BMS tranny cooler
MHD BEF Racegas
Default 06-10-2019, 09:11 AM
Yes post a log of map1... Map4 is low boost, so that makes sense, transmission issues are normally power related.
Default 06-10-2019, 09:24 AM
Here you go, I went smooth on this one but hard enough to get the gear malfunction error to come up.
-07 335i coupe
BMS charge pipe
Turbosmart BOV
VRSF down pipe
Afe intake filter
BMS intercooler
BMS tranny cooler
MHD BEF Racegas
Default 06-10-2019, 10:37 PM
Was the trans used ?
Are you using stock trans software or xHp, alpina or anything?
08 335Ci's Avatar
08 335Ci 08 335Ci is offline
Car: 08 335Ci
Default 06-10-2019, 10:48 PM
Reach up behind your front junction box (fuse box) and make sure the E-box cooling fan is working. The JB4 adds a lot of heat to that box and it's a poor cooling design at best. The fans can fail with no codes and a hot DME isn't a happy DME.
'10 E92 335 M Sport, JB-4 G5 ISO, 3" CPE Charge pipe, WMI w/dual CM 5 nozzles, 3.5 Tmap, E85 BEF, Front Strut Brace, SS brake lines, Drilled and Slotted Rotors, Anti-lag, OCC. Escort Max 360
Totaled by a careless driver:
'08 E92 335, M sport option
Default 06-11-2019, 04:32 AM
The transmission was used but low milleage and tested, also doing exactly the same issue as the one before with higher milleage. I was running ( without knowing ) XHP with an old version, I am now running the newest version of Xhp (still the same issue) but their software is bugged and can't reload since I resetted my adaptation, they are not replying to my email. Yesterday I tried to reset my adaptation and recalibrated everything as mentionned in the file software + T re-adaptation and hope it will solve my issue. I will drive the car smoothly for anoter 200km before trying to push it hard.
Thanks a lot for your time guys! It is greatly appreciated!
-07 335i coupe
BMS charge pipe
Turbosmart BOV
VRSF down pipe
Afe intake filter
BMS intercooler
BMS tranny cooler
MHD BEF Racegas
Default 06-11-2019, 04:33 AM
To be honest I had no clue there was a fan in there, I don't remember seing one cooling the dme box. I will double check to make sure there is one in there? Also, is there a temp sensor to allow it to run when needed or it should run all the time?
Thank you !
-07 335i coupe
BMS charge pipe
Turbosmart BOV
VRSF down pipe
Afe intake filter
BMS intercooler
BMS tranny cooler
MHD BEF Racegas
Default 06-11-2019, 05:41 AM
Terry and Dave, from my logs can you see if I am running out of gas pressure or flow? I was thinking maybe this would be the problem?
Thank you
-07 335i coupe
BMS charge pipe
Turbosmart BOV
VRSF down pipe
Afe intake filter
BMS intercooler
BMS tranny cooler
MHD BEF Racegas
08 335Ci's Avatar
Car: 08 335Ci
Default 06-11-2019, 08:01 AM
Thank you !
The fan is inside the car and well hidden behind the 'fuse box'.
The speed is controlled by the DME. When cool it runs slow, then speeds up as the DME heats. Another problem is the carpet might be covering the air inlet a bit. If you want to confirm it's heat build up in the DME, take off the E-box cover and give it a try.
I spent nearly 2 months chasing the same trans problem in addition to my WMI coming on unexpectedly and flooding out the engine.
Default 06-11-2019, 08:57 PM
Thank you
In he most recent map 1 log- hpfp / LPFP look normal
Default 06-12-2019, 04:34 AM
And what about map 3? Could it supply enough gas in map 1 but not enough for map 3?
-07 335i coupe
BMS charge pipe
Turbosmart BOV
VRSF down pipe
Afe intake filter
BMS intercooler
BMS tranny cooler
MHD BEF Racegas
Default 06-12-2019, 09:30 AM
Iíve been able to stick my finger in the air outlet to dme and itís blowing little bit of air when starting up the car, iíve also tried with no cover on and same issue.
-07 335i coupe
BMS charge pipe
Turbosmart BOV
VRSF down pipe
Afe intake filter
BMS intercooler
BMS tranny cooler
MHD BEF Racegas
Default 06-12-2019, 11:18 AM
That log is extremely short- but again the HPFP / LPFP values look fine.
Dont think you have a fuel delivery / pressure issue.
This looks like a physical hardware issue w. the trans imo
08 335Ci's Avatar
Car: 08 335Ci
Default 06-12-2019, 01:49 PM
Sorry I didn't help.
Default 06-12-2019, 03:06 PM
Itís highly appreciated since I am running out of ideas!!
-07 335i coupe
BMS charge pipe
Turbosmart BOV
VRSF down pipe
Afe intake filter
BMS intercooler
BMS tranny cooler
MHD BEF Racegas
Default 06-13-2019, 10:34 AM
TBH- and it would suck, i wonder if the "new/used" trans is damaged?
