Nordic335IM3's Avatar
Nordic335IM3 Nordic335IM3 is offline
Car: BMW 335I N54
Default ? about 29E0 fuel mix control on cold idle + log - 02-22-2019, 01:42 PM
I get the 29E0 error code and the idle is lumpy when cold.
at first I got:
2A2C fuel mixture control 2
29D1 Misfirings, cylinder 5
29D1 Misfirings, cylinder 4
so I cleaned the 4-5-6 sparkplugs & coils, and Im left with the 29E0 when cold.
Did a log but I do not think it shows anything wrong, but Im no expert, so would like some comments
How should I proceed , getting at the cause of that error & idle ?
(I recently changed no 6 injector because it was leaking)
E92 N54 2007 (kline)
mods:ER CP + TIAL BOV , MMP IN & OUTlets, BMS CM10 with Ethanol , JB4 mhd BEF(race) , pipesdown + no cats, 5" stepped wagner FMIC , 0.5 mm NGK 95770
öhlins shocks & springs , M3 swaybar front, PCV: Misimoto Ext RB blocked ports lowside , Solid Diff Brace, 20" wheels,android HU,
Default 02-23-2019, 07:41 AM
at first I got:
Log doesn’t look bad, nothing jumps out.
Mixture control can happen when trims on one bank or both max one way or other too long- usually.
How old are your injectors
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: BMW 335I N54
Default 02-23-2019, 08:23 AM
I see, It seems like its only on cold starts, when warmed up its just like a very slight stumble when idling, which many N54 does as I understand it.
my injectors are 8 and 9 index, I recently tested them for leaks and only one was leaking, which I replaced.
maybe I should go all in and get index 12´s..
Default 02-23-2019, 10:32 PM
Expensive, but worth it imo.
My old 335 had a pesky mixture control fault- would come & go - replaced all the injectors when one went out- & the code went away.
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: BMW 335I N54
Default 02-27-2019, 09:58 AM
I got a misfire on Cyl 3 , the injector was done for, changed it out with a good index 8 and no more codes.
still a very slight tremble in idle.. Ngk´s and coils on the way, will see if it does anything , will still look into index 12s later on
anyway here is a new log, how does it look?
Default 02-27-2019, 11:59 AM
Boost / timing all look ok.
Your trims look to get a little wonky up top towards redline... something to keep an eye on.
Fuel mix?
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: BMW 335I N54
Default 02-27-2019, 12:16 PM
Fuel mix?
thank you, what should I look for regarding the trims, I dont fully understand the explanation of it from terrys logging post.
this was pump gas Shell Vpower 100(E10) and alcohol/water in the CP
(60-70ish / 40-30) .. thinking of trying adding Ethanol to the fuel to about E25
to see what happens.
This was the first time I ran the Raceflash , usually I run the pumpflash.
Default 02-27-2019, 09:34 PM
Bump the content up to e25/30 & relog
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: BMW 335I N54
Default 04-03-2019, 11:09 AM
back again with index 12 injectors.
raceflash map 5 log - how does it look compared with the previous?
pulls a lot harder than the pump flash on wot.
Default 04-03-2019, 09:35 PM
Timing, Boost & fuel pressure look good.
However your trims are maxing negative (pulling fuel)
May need to adjust meth flow a bit to bring trims back closer to center
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: BMW 335I N54
Default 04-04-2019, 12:46 AM
thank you
what would the ideal trim curve/numbers be on a wot pull?
what setting should I change with the meth? (Im using 93% ethanol btw)
Default 04-05-2019, 12:36 AM
thank you
The closer to home (25) the better
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: BMW 335I N54
Default 04-16-2019, 03:59 AM
back again:
Here is a 3rd gear wot - raceflash map5 on shell vpower100 and no spraying this time
how does it look ?
at least the fuel trims are not going down like when spraying..and it feels smooth , but maybe a little bit clutch slippage
but Im unsure as to how I can add meth and adjust settings so the fuel trims stays in balance...?
Default 04-16-2019, 11:15 AM
back again:
how does it look ?
This doesn’t look bad- you are however getting some timing corrections across multiple cylinders.
Your LPFP touches the 50s - we might be closing in on the comfortable limits of that.
Do you have a log with the methanol on?
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: BMW 335I N54
Default 04-16-2019, 12:27 PM
yes the previous log you commented on is with spray..only difference to this log is the meth is turned off.
I will flash back to the pump bef and relog.
Im not running any added E to the fuel so Im not sure why the LPFP would do that..
Default 04-16-2019, 10:58 PM
I don’t see an upgraded LPFP in your signature - do you have an upgrade?
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: BMW 335I N54
Default 04-16-2019, 11:12 PM
no , no upgraded pump since we dont have E85 around here, this is the first time I have seen it under 70 in a log,it just touches 58-59 at the end of the run..
I will do logs with the pump bef , with and without spray on and look at the fuel trims and LPFP..
Default 04-18-2019, 12:10 AM
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: BMW 335I N54
Default 06-12-2019, 03:22 PM
Back with a new log.
map 3 , 50 meth adder
Other than the fuel trims getting pulled because of the CP alcohol spray, I think the numbers look good, am I right or wrong?
Can I up the boost somehow?.. hitting about 17 psi here. But with the "extra" octane from the alcohol I was thinking about raising the boost and maybe get less fuel pulled then..
should I up the meth adder?.. is that safe?
p.s:I dont know how to adjust fuel scalars to otherwise fix the fuel trims
Car: BMW 335I N54
Default 06-16-2019, 06:43 AM
Default 06-17-2019, 05:02 AM
Log does look a bit better.
More boost = map 6
Trims can be adjusted via tunerpro (custom) or FOL adjusted
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: BMW 335I N54
Default 06-17-2019, 12:29 PM
More boost = map 6
Thx for your time Dave
I just dont know enough about it to fiddle with map 6...
Default 06-17-2019, 12:46 PM
based on what i see- you have enough fuel on the high & low to bump things up a bit.
Map 6 is obviously a bit more hands on- assuming your settings are correct- you can def. run a bit more boost than what you are currently running- imo 18-19 psi without a problem.
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: BMW 335I N54
Default 06-17-2019, 01:55 PM
what about increasing the meth adder on map 3 would that not lead to same effect?
Default 06-17-2019, 09:22 PM
Lol- u can bump that up a bit if more comfortable
e92 AT 335xi 2.0
Doc Race Kit 6062
