landshark92 landshark92 is offline
Car: 2013 335is
Default I never learned to read! please help - 06-05-2019, 07:17 PM
Ashamed to admit that I can't read my spark plugs and don't know what they are trying to tell me. Can you guys take a look and tell me what has been going on inside cylinder 1?
These plugs have about about 21,000 miles on them, 4,000 of those miles tuned, and 3,000 of those miles on E32 at 18psi. I have been having problems at higher boost levels with cylinder 1 misfires. The spark plug from cylinder 1 looked much worse than the other plugs.
1st picture is the cylinder 1 plug
2nd picture is what the other plugs looked like on average
3rd picture is a side by side comparison of the 2 plugs
4th picture is a brand new stock Bosch plug for reference
2013 335is N54 / 6MT / JB4 G5 ISO "E85" BEF map 5 / Fuel: E40 / Phoenix Racing charge pipe / Diff lockdown / 70K miles
I'm addicted to meth but E85 gets me by...
BIMMIN BIMMIN is offline
Car: 2009 335i AT
Default 06-06-2019, 04:07 AM
Looks like your running lean. Have you logged your lpfp and hpfp?
2009 E92 335i AT
Engine
Car: 2013 335is
Default 06-08-2019, 02:06 AM
Yes, the LPFP has been above 5 and the HPFP has been higher than 11 the whole time. AFR has been pretty good, dropping to about 12.5 near redline and the trims have never been maxed out. With E32, trims and LPFP has been close to the limit but never exceeding them, with AFR looking real good the whole time.
I do have this weird JB4 safety that comes up for AFR. When I have the traction control on and hit it real hard down low, if the car has a lot of traction before the tires spin up, the AFR safety kicks in and I get the 2 hazard lights flash and then it switches to map 4. Only happens when the traction control is activated in 1st or 2nd gear.
In the default setting, which cylinder is monitored for timing in the logs?
Default 06-08-2019, 10:55 PM
Do you have any logs?
Car: 2013 335is
Default 06-08-2019, 11:27 PM
I don't have any logs of the AFR safety events as that is very rare. Only happened 3 or 4 times in the last 5 months.
Here is a normal run with the car on E34.
Default 06-10-2019, 08:30 AM
Hey few things-
Enable 6 cyl timing
I have a feeling your going lean, when trims max.
Do you have the BEF ?
Car: 2013 335is
Default 06-10-2019, 12:16 PM
I am installing the "pump" BEF as we speak. I'll enable 6 cylinder timing, log, and post it up here after.
Default 06-10-2019, 10:41 PM
Sounds good
