Asuna's Avatar
Asuna Asuna is offline
Car: M240i
Default BMS intake - 04-15-2019, 08:27 PM
After I setup the BMS intake of B58, my log get worse. Please help me.
4-07 is before. 04-15 is after.
Default 04-15-2019, 08:29 PM
Logs are both under boosting.. It's flashed I presume? Time to use the JB4's EWG control to crank WGDC up to get boost up to target.
Asuna's Avatar
Car: M240i
Default 04-16-2019, 05:04 AM
Thank you Terry. I used the EWG and FF. The ign1 is very low. I use NGK97506. This is BM3 Stage2 OTS with JB4 map0.
BMW After BMW
Car: BMW M240i
Default 04-16-2019, 06:13 AM
Your duty bias settings are all 50 so you're not adding any WGDC. Your WGDC and FF in the graph show 0 which is way out of tuning range. Raise duty bias to like 60 to start and set your FF manually to like 100. This is way higher than usual but if it helps the car will start adapting.
Also make sure that intake is installed properly
BMW After BMW
Car: BMW M240i
Default 04-16-2019, 01:28 PM
Also I think everything in JB4 is off in map0. Use Map1 if you want to crank things up as Terry suggested.
Asuna's Avatar
Car: M240i
Default 04-17-2019, 04:53 AM
Thank you very much. And I'll try it later.
Asuna's Avatar
Car: M240i
Default 04-18-2019, 08:45 AM
I set the duty bias to 60. And this is my map6. Please help me. Thank you!
Default 04-18-2019, 09:04 AM
Log seems fine to me, any issues?
Asuna's Avatar
Car: M240i
Default 04-18-2019, 09:20 AM
The ign1 is lower than others. Are there any problems in the mixture? I use 100% meth. One cm10 and one cm5.
