Default JB4 for 2018+ F90 M5/M8 - 03-28-2018, 06:50 PM
This is the central point of contact for all 2018+ F90 JB4 related information. Anything from install directions, to firmware updates, to settings, to frequently asked questions. Any and all relevant info is linked in this post. If you come across something missing from here be sure to let us know.
Order the full F90 JB4 system here.
Map changes, datalogging, updates are done using the BMS data cable or the JB4 Mobile bluetooth kit.
BMS data cable hard wired directions Click here
Map Guide as of v6 firmware:
Map 0: Stock operation, JB4 disabled
Map 1: Default performance map, 4psi peak request over stock
Map 2: 22psi absolute boost profile, 93 octane OK. For competition packages cars and/or in warm/higher elevation climates map1 might out perform map2.
Map 3: 25psi absolute boost profile, requires higher octane like unleaded racing fuel
Map 4: 26psi absolute boost profile, requires unleaded racing fuel
Map 5: 27psi absolute boost profile, requires unleaded racing fuel
Map 6: User adjustable map. RPM1500 values of less than 6psi make map6 additive target based, values over 7psi make map6 absolute target based.
Map 7: Water/meth (WMI) progressive safety map, boost target determined by WMI additive
Map 8: Low boost VALET & safety map
Note to properly delete fault codes on the F90 the car must be in diagnostic mode first. With your foot off the brake press the ignition button 3 times fast. All lights will appear on dash.
Firmware
Download using the new internal firmware database within JB4 Mobile or externally by clicking this link.
JB4_F90_5:
1) Revised map2 as an additive map with a peak request of 5psi over stock
2) Enabled EWG control for map1 and map2, for vehicles where the optional EWG connections have been attached.
3) Fixed bug with startup EWG fault appearing on some models.
JB4_F90_4:
1) Redesigned boost by gear system. Boost in 1st, 2nd, and 3rd gear now represents the amount of boost to subtract from the boost target. This allows you to set boost lower than stock when slippery track conditions dictate. When using launch mode of the car "bogs" shortly after the launch reduce boost in 1st gear until you're able to get a clean launch.
T1) Adjustments to FF under absolute target maps to improve boost targeting.
JB4_F90_S63TU_3_T2:
1) Adjusted map1 to peak request of 4psi over stock, to match new BMS Stage1 mapping. Making Stage1 and JB4 map1 effectively similar tuning.
2) Reworked the code reading function so codes are properly read from both ECU's independently. May require interface update to work properly, if you have problems reading codes with this update, contact Donnie for the BETA JB4 Mobile interface.
3) Added higher boost map5 @ 26psi peak, and map7 @ 27psi peak, for those looking to push records on straight MS109 racing fuel.
JB4_F90_S63TU_3:
1) Revised boost mapping to improve partial throttle smoothness on absolute target maps 2 & 3.
2) Adjusted map4 to an 8psi VALET map. Perfect for when you want to save gas or lend the car to "friends".
3) Revised boost by gear logic for improved performance. You can now target boost below the factory target if desired.
4) Wastegate control logical change to improve boost targeting during runs with multiple shifts, like 1/4 mile runs.
TEST2: Fixed some minor bugs with TEST1 on partial throttle control
TEST3: Further low throttle refinement
Default settings:
Map Switch In Dash:
How to attach BlueTooth kit:
How to update firmware:
For firmware updates if having issues we suggest you turn off WiFi, change upload timeout to 25, and set your phone next to JB4 box under the hood.
Car: 335i, 2009
Default 03-28-2018, 08:06 PM
Can't wait for results..
M3 F80 2017 Competition & Carbon Brakes
JB4 ||| H&R Sport Springs
X5 50i 2013 ///M Sport
BMS Stage 1
dragy dragy is offline
Car: BMW 320i
Default 03-28-2018, 10:12 PM
60-130mph and 100-200km/h run post by DME Tuning on stock car
Ando @ BMS's Avatar
BMS Customer Service
Car: bmw 335i
Default 03-29-2018, 09:00 AM
Really excited about this car. Hopefully there is more left in it.
That blue is super nice.
Default 03-29-2018, 10:16 AM
Mo @ DME Tuning sent over a fresh dyno from their new F90 M5 Development car. Overall, looks strong, although we're a little concerned with the AFR. We'll need to better evaluate that as we start to dial up boost. The platform is EWG based so I envision designing a new JB4 system for it with dual bank boost, fuel, and EWG control, at a minimum. Being so strong from the factory I wonder how much tuning potential they left for us. 700awhp would be amazing.
BMS has a car on order that is currently on the water, so probably a few weeks out. I was hoping to have it a few days before SS to rig up a tuner and race it but the timing is in question now. Will update the thread when we have it.
Should look nice in the garage next to our 775whp 2015 M5.
fusionchicken fusionchicken is offline
Car: 08 535i
Default 03-29-2018, 02:01 PM
Hmm that 8.3 60-130 is slower than I'd expect at the power level and weight. Was expecting mid 7s. Maybe it will speed up as it breaks in.
+1 another shop got a similar 60-130 time on another forum, but I expect it go go mid-7s as well. Thing is moving for sure, and that's before mods lol
Peter @ Pure's Avatar
Car: F20 M135i
Default 03-29-2018, 09:49 PM
Afr’s look like b58 afrs. Are they using new dme types or same as f10 m5?
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
luchocamp's Avatar
Default 03-30-2018, 06:10 AM
Great numbers stock !
A90 Supra Full Weight No Nitrous 10.78@133mph
BMW M4 stay tuned
Drag Track online set up on instagram @luchocampusano YouTube Lucho Campusano
Down4it's Avatar
Down4it Down4it is offline
Default 03-30-2018, 09:02 AM
Originally Posted by Peter @ Pure
Afrís look like b58 afrs. Are they using new dme types or same as f10 m5?
It's a new DME I have heard. I would think the AWD is cutting out some of that top end power that we have been enjoying in the F10/F13
steeve13m steeve13m is offline
Car: 13 M5 DCT
Default 03-30-2018, 02:07 PM
BMS has a car on order that is currently on the water, so probably a few weeks out. I was hoping to have it a few days before SS to rig up a tuner and race it but the timing is in question now. Will update the thread when we have it. Our development car is Marina Bay Blue, white interior, and M Drivers Package for the speed limiter change. MSRP with the gas guzzler tax and destination is $107,095.
Terry here's another AWD/RWD Mustang DYNO reference point;
https://f90.bimmerpost.com/forums/sh....php?t=1478756
2019 Marina Bay Blue M5 Competition, HRE FF04 21",BMC filters, 5% Window tints,Clear protection film,Escort Passport MAX,zw5,Sprint Booster.
2004 Lamborghini Gallardo -Manual- Giallo Midas Pearl Yellow- Modified Intake, Exhaust, Tuning, Carbon parts, HRE wheels, Sound system, +
nallenalle nallenalle is offline
Car: F80 M3
Default 04-01-2018, 08:13 PM
What app is that?
Bushidopupil's Avatar
Bushidopupil Bushidopupil is offline
Car: 2011 CTS-V Coupe
Default 04-07-2018, 03:12 PM
Terry,
When your car arrives will it be run on the same dyno as the graph you posted for comparison?
Default 04-07-2018, 03:33 PM
No, Mo is across the country.
Default 04-07-2018, 04:19 PM
Gotcha! Just coming back to the BMW scene. The M5 will be my next vehicle. Can't wait to see what you can squeeze out of her.
135idct 135idct is offline
Default 04-07-2018, 05:28 PM
the AFR of the new M5 about 15, i don't think it's safe to push more boost, need a flash
Default 04-08-2018, 09:34 AM
Terry,
What are your thoughts on this.
https://youtu.be/Yxh4x9eEr-U
Default 04-08-2018, 09:39 AM
I'm less interested with the dynos floating around and looking forward to some more 60-130 and 1/4 mile results. But seems like 600whp stock is plausible. And hopefully, 700whp JB4 tuned is doable. Would be enough for mid 10s in a well launching setup.
Default 04-08-2018, 09:47 AM
Good, that is what I'm shooting for, a solid 10.5 DD. Eagerly looking forward to your test results.
sheharyar_rr sheharyar_rr is offline
Car: 2014 335i M sport
Default 04-08-2018, 09:43 PM
Can't wait for the tuning to begin. Whats the ETA on the test car?
2018 BMW M550i
BMS JB4
1/4 mile 11.0 @ 125
Default 04-09-2018, 08:51 AM
Looking like early May. Boat was delayed for some reason.
On the plus side, a special order was the only way to get no options but the speed limiter raised. So will be worth the wait.
Default 04-14-2018, 11:19 AM
Jay Lane from Sewell BMW in TX posted this time slip on FB today. WannaGofast Half mile event. Impressive!!
2018 BMW M5
Speed 154.5330mph
Iíll post the picture of the slip when I can get to my desktop.
Default 04-14-2018, 11:38 AM
Not bad for a stock car in the 1/2 mile. Hopefully with mods, 165mph+
Default 04-14-2018, 01:31 PM
Updated time 155.7094mph. That’s amazing for stock in my opinion. You can see the other slips by looking at his FB page.
Default 04-14-2018, 07:12 PM
Updated time 155.7094mph. Thatís amazing for stock in my opinion. You can see the other slips by looking at his FB page.
the link?
Default 04-15-2018, 04:40 AM
https://www.facebook.com/202501785
