Default 10-26-2016, 02:57 PM
Added initial maps to the first post.
Default 10-26-2016, 03:00 PM
Originally Posted by jturboawd
What I am looking for is a optimized full e85 PI PS2 set up. I need all the tables close to dialed in and I can modify with tuner pro if needed. This is what terry is giving us.
The way we've setup the JB4 system very little custom tuning should be required across a very wide power and modification range. You do not need to pay for maps, custom mapping, or tuning support with a JB4. Load up the latest free BEF maps and start posting some logs. Steve, Jon & I use that customer data to evaluate the JB4 maps, back end maps, and learning algorithms, and ensure we're delivering optimal performance and convenience across all ranges of modifications. If your car is having problems then we're particularly interested in checking it out to improve the maps and learning functions for everyone.
In terms of the VANOS changes and big improvements that might not be realistic. I'd expect subtle improvements like we see with the N54. A little better spool, fewer timing drops up top, etc. But who knows as we are in development now. We'll see how it all pans out.
Default 10-26-2016, 03:40 PM
We still have not solved the PS2 high HP misfire issue (from my experience). I know some have but at a certain boost level it seems to always come back. So far the most likely culprit mentioned sounds like excessive back pressure.
I am hoping that playing around with variables like lobe separation could help this issue. Really I am hoping someone can strap down a maxed out PS2 and see if any of the new tables allow us to raise the ceiling. There was a guy that did this for the N54, but honestly I am afraid I could really mess something up if i go it alone.
Default 10-26-2016, 06:44 PM
We've actually made some good progress on that. On our car it was a combination of plugs and increasing fuel volume via port injection that solved it. Back pressure is also an issue but not until you get north of 25-26psi on a stage2 turbo.
Once you load the current BEF and I start seeing your logs I can probably point you in the right direction.
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 10-26-2016, 07:00 PM
We plan to add mode 4/4 option in the latest N55 E ISO firmware to allow for flash only operation. Currently it's 4/2 for BEF, 4/3 for normal operation.
I know you said this is in the works but would meth still be controlled by the JB4 on this 4/4 option?
2011 E92 335i Auto
12.0 @ 125MPH JB4
Sold
Default 10-26-2016, 07:15 PM
Meth would be mapped out but with no safety system or progressive control (e.g. waiting for meth to flow before raising boost, etc).
I get there is some interest in trying out the new flash only maps but really once we finalize this BEF along with the JB4 features you're never going to stay with them anyway.
Peen Peen is offline
Car: 2011 BMW 335i
Default 10-26-2016, 07:21 PM
Terry, posted some E85 logs over here.
http://www.n54tech.com/forums/showth...649#post504649
Was for sure a lot smoother then PPK.
Default 10-26-2016, 07:28 PM
To speed up development for the N55 BEF logs just email them to terry@burgertuning.com for now. I will reply with firmware updates as needed.
sd306 sd306 is offline
Car: 2011 e92 N55 335i Coupe M-Sport
Default 10-26-2016, 11:01 PM
Terry,
For Pure Stage 1 PWG, TBI, S2 LPFP, and 100% E85 - would I use E85_PI or E85_PI_ST?
Bomba474's Avatar
Bomba474 Bomba474 is offline
Car: 335i N54 E92
Default 10-27-2016, 03:33 AM
Originally Posted by MHD
The xdf is available at https://github.com/dmacpro91/BMW-XDFs. Download everything as .zip.
The app allow you to generate a 98g0b bin for your car (and the xdf).
Dear,
How can I generate a 98g0b bin with app? I'm from Brazil and our fuel is terrible, so we need to customize maps looking better results. Maps from US came with a higher timing than our fuel support....
335i, MHD E65 Custom flash, Intercooler, Chargerpipe, MM Performance inlets, LPFP Walbro 450, HPFP BMW review, full exhaust
bloked97one bloked97one is offline
Car: 335i n55 2011
Default 10-27-2016, 05:29 AM
Hi terry.
what firmware for me and bms backend flash.
335i n55
T map sensor 3.5b
93oct
Lflp 340 aeromotive
Afe power .
Merci
hz_diesel hz_diesel is offline
Car: 2012 e92 xdrive
Default 10-27-2016, 05:36 AM
Which BEF would you use with METH? still the 93 pump?
Would there be any issues passing emissions with the MHD flash?
flexbrah flexbrah is offline
Car: 335i n55
Default 10-27-2016, 06:30 AM
Does the BEF include the exhaust burbles that the MHD has?
Car: 2011 e92 335i
Default 10-27-2016, 07:19 AM
Originally Posted by bloked97one
Hi terry.
335i n55
T map sensor 3.5b
93oct
Lflp 340 aeromotive
Afe power .
Merci
Pump flash
Pump flash
Originally Posted by Bomba474
Dear,
You will select Stock maps operations then generate updated backup.
2011 E92 335i Auto
12.0 @ 125MPH JB4
Sold
Default 10-27-2016, 07:41 AM
It's a flash time option.
Car: 2011 e92 335i
Default 10-27-2016, 09:08 AM
The steps I took were to select custom flash, find the file on the device, and the flash started. There were no options before or after the flash. Did I do something wrong?
2011 E92 335i Auto
12.0 @ 125MPH JB4
Sold
Default 10-27-2016, 09:21 AM
At some point after selecting the file but before flashing there is a button for "options", I thought. Martial?
Car: 2011 BMW 335i
Default 10-27-2016, 09:25 AM
I get options after selecting custom firmware. Base and Sport burble duration (Not sure what difference is though), Cold Start, N20 TMAP.
Car: 2011 e92 335i
Default 10-27-2016, 09:31 AM
I guess I will do their flash to stock option retaining MHD and flash it again to see if options come up.
**EDIT**
I don't know if I missed it or what happened but it worked for me the second time around. I am loving the cold start delete.
2011 E92 335i Auto
12.0 @ 125MPH JB4
Sold
Bomba474's Avatar
Car: 335i N54 E92
Default 10-27-2016, 09:35 AM
When I enter on app mhd n55 connected with kdcan it shows 0v when I'm looking the "read me codes" can i upload bin file with 0v showed on device?
Bomba474's Avatar
Car: 335i N54 E92
Default 10-27-2016, 11:23 AM
JB4 is on map0 but it is the new one, and to acess obd2 port I need to remove JB4's conector.
canadarob canadarob is offline
Car: 2011 bmw 135i, 2004 Nissan 350z
Default 10-27-2016, 12:19 PM
Mine showed 0V as well for the cable on the mhd app. I had a Battery Charger separately watching the voltage so I was not to worried. it worked fine.
Bomba474's Avatar
Car: 335i N54 E92
Default 10-27-2016, 12:36 PM
Good to know! Ty
Acess dash board to change 4/2 option using volume and change down is not working too... anyone knows what it can be?
Default 10-27-2016, 12:43 PM
Make sure NOT to select 3.5bar TMAP with a JB4 installed. The JB4 does the TMAP conversion for you.
M1353000 M1353000 is offline
Car: M135i
Default 10-27-2016, 05:06 PM
Nice work guys, sooooo keen on F series Can't wait!!!!!!!
M135i LCI 8sp, ******* DP, ER FMIC, ER Charge pipe, ER turbo to Intercooler pipe, Muffler & Resonator delete, BMS Filter, JB4, 30% E85 with 98, Stage 2 Fuel It LPFP.
1/4 Mile 11.8 @ 119mph
