DavidAKL DavidAKL is offline
Car: 2009 e82 135i
Default n54,G5 BOARD,MHD e85 flash,TBI+Stage 2,little bit slow? - 07-03-2016, 04:17 AM
Hi all
First i wanna say thanks to steve,you really helped me a lot for past few weeks.
I was doing dyno run last week and only got 317kw atw which was disappointed me, my friends 135 got 319kw ,same mods as mine but without TBI+Stage 2 LPFP, he was running bimmerboost BEF,only E30 blend with factory LPFP,here is the log,anything wrong or any ideas if can make my car faster?
I was on map7,E75 mix.
Thank you
Mods:
Stock snails.ER FMIC
ER C/P TIAL BOV
Injen DCI
Mishimoto OCC
N54 tuning D/P+DE *** MIDPIPE+REMUS AXLE PIPE
Fuel it TBI+Stage 2 LPFP
Alpina b3 flash
NGK .022.
Default 07-04-2016, 10:28 PM
I'd verify you don't have a boost leak. Your PWM is pretty much maxed out.
I'd also recommend lowering your FOL to 20 and enabling 6-cyl timing.
What flash are you running? May need to switch the flash or decay the scalars.
Car: 2009 e82 135i
Default 07-04-2016, 11:25 PM
Hi steve,im running MHD E85 Flash which was released by Terry on 01/06/2016.Thank you
Car: 2009 e82 135i
Default 07-04-2016, 11:46 PM
I'm a newbie here so forgive me if this is a stupid question...how do i enabling 6-cyl timing?thanks..
Default 07-05-2016, 05:04 PM
No problem.
6-cyl timing is enabled by setting the value to 5 on the user adjustment tab.
Try lowering your FOL to 20, post a log, and we'll go from there.
Car: 2009 e82 135i
Default 07-05-2016, 05:45 PM
No problem.
Here they are
At first pull,jb4 detected 2c2d Lambda probe in front of catalytic converter,thrust control,but nothing display on speedo cluster.
Second pull,engine light flashing instantly,big explosive sound from engine bay,misfiring cylinder 4,5,6---those misfire codes came back again,All coils and spark plugs were raplaced 100kms ago
Any suggestions?Thanks.
Default 07-06-2016, 09:05 AM
looks like you had a misfire on bank 2. Also make sure you didn't have a coupler or anything on the charge pipe come disconnected.
Send me a copy of the flash you are currently running and I'll decay the scalars for you.
steve@burgertuning.com
