DoobiieDripp's Avatar
DoobiieDripp DoobiieDripp is offline
Car: 2010 BMW 535i
Default Engine Malfunction after JB4 Install - 06-29-2016, 09:44 AM
Yesterday I Installed a JB4 and Rev 3 kit in my 2010 535i. The only other mod I have is a DCI. I put it in map 1 after I installed it and took it for a spin. Well my first 4 pulls were amazing! But that 5th pull is where I got the Engine Malfunction/Reduced Power message on the iDrive. Here are the codes I got:
2ACC
2E8E
30FE
3100
Before I read the codes I tried driving in map 0 and at WOT it still gave me the Engine Malfunction message. However after I read and cleared the codes I ran Map 0 and at WOT I didn't get any messages. But as soon as I switched to Map 1 and went WOT I got the message.
Where should I start my investigation? I've already checked my JB4 wires and made sure everything was connected properly. Are all 4 codes related to eachother? I know 30FE and 3100 are related to eachother and 2ACC and 2E8E can possibly be related to eachother. Any help would be great guys.
Default 06-29-2016, 09:56 AM
Could be a simple setting. Make sure menu 4 in dash is set to 3. If the problem continues do a JB4 log.
Car: 2010 BMW 535i
Default 06-29-2016, 10:52 AM
Just want to double check, to set menu 4 to 3 the Speedo should be at 40 and the Tach should be at 3 right?
Car: 2010 BMW 535i
Default 06-30-2016, 02:41 AM
If the previous owner of the JB4 had a 2-Step connected to it would that effect any of my settings? Like is there anything I should change because I'm not using the 2-step? Or do the settings automatically reset? I'm going to post a log later today.
Car: 2010 BMW 535i
Default 06-30-2016, 09:44 AM
Update on the codes. Before I read them with the speedo, and this time I read with the Jb4 app.
30FE - Boost Over Target
3100 - low boost mode engaged
2D2E - Angle of throttle Valve - intake pipe underpressure, correlation
30FF - Boost Under Target - Possible boost leak.
I drove with the car in Map 1 and did some pulls and the engine malfunction light did not come on. Is it possible the problem has corrected itself? Attached are two logs I did this morning.
Default 06-30-2016, 09:47 AM
Everything looks good here. Although the gas pedal is only going to 90%, make sure nothing is blocking it.
Car: 2010 BMW 535i
Default 07-02-2016, 03:37 PM
I was finally able to log when my car gives me the Engine Malfunction message. Attached is a log of me running Map 1(Malfunction.csv) and another log running Map 5(the other attached log). I'm no longer getting the 3100 code but I'm getting 2D2E and 30FF. How can I solve this problem?
Car: 2010 BMW 535i
Default 07-02-2016, 03:43 PM
Also I went in through the JB4 Mobile app and changed all of the JB4 setting back to there default settings. When I first installed it the settings were modified a little bit. I changed the settings before my log in Map 1. Running Map 5 everything was fine. I'm only getting the malfunction message when running Map 1 or Map 0 and only at WOT.
Stoolz Stoolz is offline
Car: 11 135i
Default 07-02-2016, 03:49 PM
Check your charge pipe is not broken?
Car: 2010 BMW 535i
Default 07-02-2016, 04:16 PM
Just checked it, it's not broken.
Car: 11 135i
Default 07-02-2016, 04:27 PM
I kinda think its a boost leak somewhere, can you get the car smoke tested?
Car: 2010 BMW 535i
Default 07-02-2016, 04:56 PM
I won't be able to get it smoke tested for 2 weeks because of my schedule. Is there anything else I can do in the mean time?
Default 07-04-2016, 10:17 PM
A lot of timing corrections and your FF had to learn up which it did in the next log.
